71-72 vs. 73-74 b-body outer door handles #2451486
02/14/18 12:33 AM
02/14/18 12:33 AM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Does anyone know the “TRUE” difference between the 71-72 part number and the 73-74 version? I have them sitting side by side and virtually see know cosmetic difference. Is there a mechanical difference like maybe the pivot point? Any input from anyone?
Re: 71-72 vs. 73-74 b-body outer door handles [Re: 340cpe] #2451901
02/14/18 11:18 PM
02/14/18 11:18 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
No reply’s kind of confirms my findings of not much differance. If anyone should have any info it would be appreciated. At swap meets especially I’m told there is a differance. Like I said earlier I know the part numbers are different but not sure what is different in the handle itself.
Re: 71-72 vs. 73-74 b-body outer door handles [Re: 340cpe] #2451902
02/14/18 11:20 PM
02/14/18 11:20 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
The area where the rod hole is different.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 71-72 vs. 73-74 b-body outer door handles [Re: 340cpe] #2452364
02/15/18 11:31 PM
02/15/18 11:31 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Thank you my friend! Appreciate the input.
Re: 71-72 vs. 73-74 b-body outer door handles [Re: 340cpe] #2452375
02/16/18 12:10 AM
02/16/18 12:10 AM
moparmarks Offline
moparmarks  Offline
Do you see what I'm talking about? I don't have any in front of me and it has been a while but IIRC the 73-4 handle won't fit into the 71-2 door or something like that.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 71-72 vs. 73-74 b-body outer door handles [Re: 340cpe] #2452761
02/16/18 08:20 PM
02/16/18 08:20 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
the handle's lever hole length is different between the two also...One has a longer travel than the other...EDIT:Mabe we're both saying the same thing {?}
Re: 71-72 vs. 73-74 b-body outer door handles [Re: 340cpe] #2452785
02/16/18 09:17 PM
02/16/18 09:17 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Here are some Nos 71-2 and 73-4 door handles. They are exact on the outside. It's the difference on the inside mechanism part. The 73-4 have longer plates on them where the lock rod attaches. I believe they both fit in the door openings as they are the same openings 71-4 if I remember. Hope that helps...71-2 is blue box and 73-4 is the tan cardboard one...
Re: 71-72 vs. 73-74 b-body outer door handles [Re: 340cpe] #2452814
02/16/18 10:14 PM
02/16/18 10:14 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Also 71/72 has 2 return springs along with the shorter linkage rod lever,thats how I used to ID them before I knew about the lever length difference.
Re: 71-72 vs. 73-74 b-body outer door handles [Re: 340cpe] #2452900
02/17/18 01:30 AM
02/17/18 01:30 AM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Thanks everyone, unfortunately I am going to confuse things yet again. I have my 74 handles from a car that I have owned since 77 that look identical to the handles on the blue box which you say are 71-72. This whole thing is just a bit confusing.
Re: 71-72 vs. 73-74 b-body outer door handles [Re: 340cpe] #2453083
02/17/18 03:49 PM
02/17/18 03:49 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
I think they will work as long as you use the right lock rod for the year handle you are using...
Re: 71-72 vs. 73-74 b-body outer door handles [Re: 340cpe] #2453340
02/18/18 02:52 AM
02/18/18 02:52 AM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Thanks again!!
Re: 71-72 vs. 73-74 b-body outer door handles [Re: 340cpe] #2454009
02/19/18 04:56 PM
02/19/18 04:56 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
What about coupe vs sedan? Any difference front or back?
