Re: Intake centerline advance/retard
[Re: RATTRAP]
#2452682
02/16/18 06:16 PM
02/16/18 06:16 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
IMO
I would use offset keys to bring it to the cams recommended setting. Not me. I haven’t put a cam straight up in years. If it was mine it would be in around 109 but I’m strictly a drag racer and if you can get it to 60 foot that sucker will run a good number. Heavy cars need all the help they can get.
[Re: RATTRAP]
#2452850
02/16/18 11:40 PM
02/16/18 11:40 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
I thought all the new cams were ground with that accounted for in the grind. Do you know what ASSUME(ASS U ME) means Never assume any mass made after market automotive parts, especially race parts, are ever made dead nuts accurate The timing set can be mismarked, I've seen that a lot with Cloyes timing sets for both BB and early Hemi and L.A. motors The first custom ground solid roller cam I bought(Chrysler 392 hemi boat motors) was ground 8 degrees retarded I installed it and use a degree wheel to check the cam timing at .020, it was off around 3 degrees so I assumed that was good enough, which of course wasn't That bad cam did end up teaching me how to check the LSA the quick way and that helped me under stand a lot more about how camshafts work with hands on experiences
[Re: 70satelliteguy]
#2453116
02/17/18 05:24 PM
02/17/18 05:24 PM
Posts: 4,206 New York
polyspheric
New York
This^^^. If you advance it too much the intake valve will crash.
Boffin Emeritus
#2453164
02/17/18 07:21 PM
02/17/18 07:21 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Have already verified plenty of clearance at max valve lift. The intake valve is usually closest to the piston at around 10ATDC during the intake opening. With the intake valve at full lift, the crank is at around 113ATDC(in your case ...... which has the piston about 3" away). On a different train of thought...... What are the lobe numbers for that cam? I'm trying to think of a combo like yours where I'd feel a 115lsa would be the preferred choice.......
[Re: AndyF]
#2453177
02/17/18 07:57 PM
02/17/18 07:57 PM
Posts: 1,301 Penna
70satelliteguy
Penna
Gross valve lift intake 800 exhaust 766 duration@ 050 283 294 lobe separation 115.0 lobe lift .4710 intake .4510 exhaust Mike
