Re: Ritter Block
[Re: 340Cuda]
#2452535
02/16/18 01:38 PM
02/16/18 01:38 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Definitely appear to be nice castings.. I can see several things that have changed for the good just in the photos that you've shown... what are your plans for these motors what cylinder heads.. and will you be Machining these yourself.. also I wish you the best of luck and if I can help you in any way give me a shout
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Ritter Block
[Re: Biginchmopar]
#2452539
02/16/18 01:58 PM
02/16/18 01:58 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
Whitedart, Thanks for the offer on help, I’m going to need it.
Anyway these are both going to be stroker W9 deals 1.) 468cid, Brett Miller W9’s, 4.250” Stroke x 4.185” Bore 2.) 451cid, Brett Miller W9’s, 4.100” Stroke x 4.185” Bore
I’m going to have a Shop do the machine work (Bore, hone, Line hone, deck) and I have no idea what it will cost.
Power-I believe by looking these over that they can handle whatever you want to throw at them. ProCharger, Turbo, Supercharger, Nitrous you name it.
The two I’m building are N/A 48* carburated.
Re: Ritter Block
[Re: Biginchmopar]
#2452540
02/16/18 02:01 PM
02/16/18 02:01 PM
Posts: 1,892 Spahn Ranch
RMCHRGR
Spahn Ranch
What is the lifter angle and deck height on these?
Woops, you beat me to it, 48*.
'71 Duster '72 Challenger '17 Ram 1500
Re: Ritter Block
[Re: Biginchmopar]
#2452545
02/16/18 02:11 PM
02/16/18 02:11 PM
Posts: 361 Canada
onig
Canada
What are the three holes beside the oil pump mounting on the rear main cap?
69 Dart
Re: Ritter Block
[Re: justinp61]
#2452562
02/16/18 02:35 PM
02/16/18 02:35 PM
Biginchmopar
Carson City, Nevada
Where does the oil return from the cam/lifter area? It returns the front bay through a drilled hole that goes to the timing chain area and the other bays by a hole in the rear that returns to the oil pan area. What I mean by bays is the cam bearing saddles kind of create a bay in between each cam bearing saddle. #2 through #5 have a channel that directs flow to the rear. I'll try and take a picture this weekend.
Re: Ritter Block
[Re: BradH]
#2452569
02/16/18 02:39 PM
02/16/18 02:39 PM
Biginchmopar
Carson City, Nevada
I haven't seen the phrase "pressure test" used, yet. Given the Ritter block's history, wouldn't that be a must-do operation before doing any machine work to one? Where did the older ones have problems? What should I be looking for, any idea?
