Page 1 of 5 1 2 3 4 5 >
#2452440 - 02/16/18 12:44 AM Ritter Block
Biginchmopar Offline
Loc: Carson City, Nevada
I received two new Ritter Blocks today. From what I can tell these blocks look really good. The casting is real good, even inside the water jacket. All the machine work looks good. It will need the be finish bored and honed, deck surface, and line honed.
#2452441 - 02/16/18 12:46 AM Re: Ritter Block [Re: Biginchmopar]
More pics
#2452442 - 02/16/18 12:47 AM Re: Ritter Block [Re: Biginchmopar]
Lifter Valley
#2452443 - 02/16/18 12:55 AM Re: Ritter Block [Re: Biginchmopar]
RAY1969CARS Offline
Loc: CA.
How much was it
#2452444 - 02/16/18 01:00 AM Re: Ritter Block [Re: Biginchmopar]
Right around $3000.00
#2452445 - 02/16/18 01:01 AM Re: Ritter Block [Re: Biginchmopar]
RAY1969CARS Offline
Loc: CA.
How much do you anticipate the machine work to cost ???
#2452456 - 02/16/18 05:59 AM Re: Ritter Block [Re: Biginchmopar]
justinp61 Offline
Loc: W. Kentucky
Where does the oil return from the cam/lifter area?
#2452457 - 02/16/18 06:21 AM Re: Ritter Block [Re: Biginchmopar]
ric3xrt Offline
Loc: Trumbauersville PA
That looks real nice, what kind of power do you think it could handle?
#2452463 - 02/16/18 08:19 AM Re: Ritter Block [Re: Biginchmopar]
racerx Offline
Loc: Mo.
Those look nice up 3000. bucks make it look even better.
#2452489 - 02/16/18 09:26 AM Re: Ritter Block [Re: racerx]
340Cuda Offline
Loc: Tulsa, Oklahoma
That's good news!
I have wanted him to succeed with this project.
Please keep us posted on these builds.
Bill
#2452492 - 02/16/18 09:29 AM Re: Ritter Block [Re: Biginchmopar]
340Cuda Offline
That's good news!
Bill
#2452535 - 02/16/18 10:38 AM Re: Ritter Block [Re: 340Cuda]
WHITEDART Online   laugh2
Loc: bean town
Definitely appear to be nice castings.. I can see several things that have changed for the good just in the photos that you've shown... what are your plans for these motors what cylinder heads.. and will you be Machining these yourself.. also I wish you the best of luck and if I can help you in any way give me a shout
In the 8s N/A.with Brett miller W8
5.42 1/8
#2452539 - 02/16/18 10:58 AM Re: Ritter Block [Re: Biginchmopar]
Whitedart,
Thanks for the offer on help, I’m going to need it.
Anyway these are both going to be stroker W9 deals
1.) 468cid, Brett Miller W9’s, 4.250” Stroke x 4.185” Bore
2.) 451cid, Brett Miller W9’s, 4.100” Stroke x 4.185” Bore
I’m going to have a Shop do the machine work (Bore, hone, Line hone, deck) and I have no idea what it will cost.
Power-I believe by looking these over that they can handle whatever you want to throw at them. ProCharger, Turbo, Supercharger, Nitrous you name it.
The two I’m building are N/A 48* carburated.
#2452540 - 02/16/18 11:01 AM Re: Ritter Block [Re: Biginchmopar]
RMCHRGR Offline
Loc: Spahn Ranch
What is the lifter angle and deck height on these?
Woops, you beat me to it, 48*.
Edited by RMCHRGR (02/16/18 11:02 AM)
'68 Coronet
'71 Duster
'76 D100
'17 Ram 1500
#2452545 - 02/16/18 11:11 AM Re: Ritter Block [Re: Biginchmopar]
onig Offline
Loc: Canada
What are the three holes beside the oil pump mounting on the rear main cap?
69 Dart, The BB is now gone, Soon to be Gen 3 Hemi...
#2452548 - 02/16/18 11:15 AM Re: Ritter Block [Re: onig]
BradH Offline
Loc: Valhalla... eventually
I haven't seen the phrase "pressure test" used, yet. Given the Ritter block's history, wouldn't that be a must-do operation before doing any machine work to one?
This space intentionally left blank... except where it says: "This space intentionally left blank"
#2452562 - 02/16/18 11:35 AM Re: Ritter Block [Re: justinp61]
It returns the front bay through a drilled hole that goes to the timing chain area and the other bays by a hole in the rear that returns to the oil pan area. What I mean by bays is the cam bearing saddles kind of create a bay in between each cam bearing saddle.
#2 through #5 have a channel that directs flow to the rear.
I'll try and take a picture this weekend.
#2452565 - 02/16/18 11:37 AM Re: Ritter Block [Re: BradH]
That is the very first step. iagree
#2452566 - 02/16/18 11:37 AM Re: Ritter Block [Re: RMCHRGR]
9.600" Deck height up
#2452569 - 02/16/18 11:39 AM Re: Ritter Block [Re: BradH]
Where did the older ones have problems? What should I be looking for, any idea?
25,344 Registered Members
190,211 Topics
Who's the Spring guy?
by fullmetaljacket
06/20/18 08:45 PM
Putting a deposit on a car?
by EV2Bird
06/20/18 08:44 PM
2011 hemi truck to pass emmisions
by HotRodDave
06/20/18 08:31 PM
Cragar
by jkwedge540
06/20/18 08:22 PM
