Re: 295/65R15 M/T ET rim size
[Re: Uncle Barry]
#2452094
02/15/18 01:06 PM
02/15/18 01:06 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I run an 8" wheel. I know it's probably too narrow but it's what I can fit with the b body Dana and offset shackles. I'd like to go to a 10" wheel but I don't want to hack on my car.. What he said. I'm starting to wonder if I would be better w 275/60s (drop gear a tick) on 8s over 295/65s on 8s.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Uncle Barry]
#2452241
02/15/18 06:07 PM
02/15/18 06:07 PM
Posts: 247 Brisbane Australia
crash520
Brisbane Australia
I run an 8" wheel. I know it's probably too narrow but it's what I can fit with the b body Dana and offset shackles. I'd like to go to a 10" wheel but I don't want to hack on my car.. I have a B body Dana, 1”spring relocation kit from Dr Diff, NO Fender lip modifications or any other body mods and 15x10 5.5 bs with 295’s fit without rubbing under my 73 Cuda
[Re: Von]
#2452337
02/15/18 10:39 PM
02/15/18 10:39 PM
Posts: 1,070 Big Western Pencilveinya
Uncle Barry
I run an 8" wheel. I know it's probably too narrow but it's what I can fit with the b body Dana and offset shackles. I'd like to go to a 10" wheel but I don't want to hack on my car.. What he said. I'm starting to wonder if I would be better w 275/60s (drop gear a tick) on 8s over 295/65s on 8s. I just run the 295 because it looks better than a 275. I do use a 275 at the track tho.
[Re: crash520]
#2452339
02/15/18 10:43 PM
02/15/18 10:43 PM
Uncle Barry
I run an 8" wheel. I know it's probably too narrow but it's what I can fit with the b body Dana and offset shackles. I'd like to go to a 10" wheel but I don't want to hack on my car.. I have a B body Dana, 1”spring relocation kit from Dr Diff, NO Fender lip modifications or any other body mods and 15x10 5.5 bs with 295’s fit without rubbing under my 73 Cuda It seems pretty tight under my car. I may look into a 10" wheel but I can't see it fitting in there.
[Re: Uncle Barry]
#2452416
02/16/18 01:56 AM
02/16/18 01:56 AM
Posts: 280 GEORGIA
barracuda7199
GEORGIA
I run an 8" wheel. I know it's probably too narrow but it's what I can fit with the b body Dana and offset shackles. I'd like to go to a 10" wheel but I don't want to hack on my car.. I have a B body Dana, 1”spring relocation kit from Dr Diff, NO Fender lip modifications or any other body mods and 15x10 5.5 bs with 295’s fit without rubbing under my 73 Cuda It seems pretty tight under my car. I may look into a 10" wheel but I can't see it fitting in there. 15x10 5.5 backspace fits my 71 cuda great with a b body rear and dr diff relocators. I ran a 325-50 with rolled lips before I took the car apart.
