Engine oil #2451952
02/15/18 01:00 AM
02/15/18 01:00 AM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
Found this interesting on engine oil test. Search Pantera international. Click on technical info. Click on find, then type in engine oil test results. Scroll down to engine oil test results by 1rocketship.
Re: Engine oil [Re: rickraw] #2451989
02/15/18 02:24 AM
02/15/18 02:24 AM
America
WedgeFED Offline
WedgeFED  Offline
America
Re: Engine oil [Re: WedgeFED] #2452002
02/15/18 03:33 AM
02/15/18 03:33 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
That guy is NOT a very reputable source and his methodology isn't an industry standerd. Just because it's on the internet doesn't mean it's true. Don't take my word for it either check for yourself.
Re: Engine oil [Re: rickraw] #2452014
02/15/18 04:47 AM
02/15/18 04:47 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Oh boy...
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Engine oil [Re: WedgeFED] #2452155
02/15/18 03:10 PM
02/15/18 03:10 PM
What I got from his blog is he is not sure of himself so he pats himself on the back a lot about being a Engineer and so on confused shruggy
Usually the test done for or by engineers results prove themselves with no debates or chance of errors work shruggy
