TF 904 street strip tips #2451749
02/14/18 06:14 PM
02/14/18 06:14 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
I'm going to rebuild the 904 in our street strip 68 'cuda. It has run a 14.2 & 98mph but it doesn't get into 3rd gear. I want to keep the rear at 3.23 so would a low gear set help here?
How would you build yours?
Re: TF 904 street strip tips [Re: Tig] #2451814
02/14/18 08:12 PM
02/14/18 08:12 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
It will give you you a better launch and a better 60' but you'll still be hard pressed to hit 3rd gear. That 2.74 will test your suspension. Have you tried a 26" tire maybe even a 26" tire with a 14" rim. That could be like moving to a 3.55/3.73.
Re: TF 904 street strip tips [Re: Tig] #2451899
02/14/18 11:13 PM
02/14/18 11:13 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Low gear set is the only way to fly in a mildly geared street car, especially with modest cubic inches.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: TF 904 street strip tips [Re: Tig] #2451951
02/15/18 12:58 AM
02/15/18 12:58 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
A low gear set drops the RPMS more between the 1-2 shift than a standard set because of the wider spread. Probably not a huge deal but something to think about.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: TF 904 street strip tips [Re: Tig] #2452022
02/15/18 05:44 AM
02/15/18 05:44 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Thanks for the reply's The car does have a 26" street tyre and a higher stall converter. Seems to stall around 1800 - 2000. The car is a bit doggy until it hits 3000 rpm or so then it picks up. Shifting at 60000 so as long as the shift rpms don't drop below 3000 we should be ok.
Any body tried a low gear set up?
Re: TF 904 street strip tips [Re: Tig] #2452084
02/15/18 12:41 PM
02/15/18 12:41 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Low gear set will help, in first it will basically turn your 3.23 rear gear to something closer to 3.65, Yes the gear spread is more but you can compensate for that by shifting the motor at a bit (a couple of 100) higher RPM. Put a good (Street/strip) shift kit in it, just a bit higher line presures will help firm the shifts as well. Might as well put new bands and clutches in it. Higher stall converters with low torque and 3.23's is probably not a good recipie, but the deeper gear set will increase your instantaneous torque alone and your final stays 1:1. Cuda A bodies are fairly light.
Recurving your distributor for a little more initial and less mechanical would probably help your acceleration as well. Switching to a set of bowl ported late model '302 casting number heads (heart shaped chambers) are worth a bunch without having to go into the short block.
With the right parts you can make a 318 perform very well and get very good MPG. Even swapping to the OEM replacement 360 cam (single pattern .410 lift moved up 4-6 degrees) works fantastic in a stock/near stock 318.
WIZE
In Car:
Re: TF 904 street strip tips [Re: Streetwize] #2452171
02/15/18 03:48 PM
02/15/18 03:48 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
When changing to a low gear set it will also have a lower 2nd gear ratio. Stock is 2.45/1.45 and Low gearset 2.74/154. The A&A gear set is 2.77/1.57
Re: TF 904 street strip tips [Re: Tig] #2452269
02/15/18 07:03 PM
02/15/18 07:03 PM
gregsdart Offline
gregsdart  Offline
You do have some room to increase stall speed and still have respectable slipage at cruise speeds. I would go both low gear set and a better converter. You have a relatively short tire which makes the 3.23 gear seem like a 3.55. A good converter builder can tell you just what you can do.
Re: TF 904 street strip tips [Re: gregsdart] #2452286
02/15/18 08:51 PM
02/15/18 08:51 PM
owasso ok
V
vindicator Offline
vindicator  Offline
V
owasso ok
I agree with gregsdart, I think a low gear set would help for sure. I also think a convertor with more stahl speed would not only help at the track but would also be better in traffic.
Re: TF 904 street strip tips [Re: Tig] #2452346
02/15/18 10:55 PM
02/15/18 10:55 PM
crlush Offline
crlush  Offline
I would definitely look into a higher stahl convertor.
Re: TF 904 street strip tips [Re: Tig] #2452642
02/16/18 05:11 PM
02/16/18 05:11 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Hi All.
Thanks for the replys, a little more info. The motor I'm guessing is around 300hp, we run ported '302 heads with the 360 (1.88 1.60?) size valves. Air gap intake with the ports opened to 360 size and a 600dp carb (I think it could go bigger here too) Compression worked out at around 10.5:1 with the .030 over bore and KB 167 pistons. (We built it a few years ago I have all the specifics written down somewhere but i forget where it is.... old age sucks!) These UK RHD 'cudas are heavier than the US counterparts, they come with all the H/D suspension and brake stuff it also has chassis ties and a big stereo! Converter is a hughes street / strip but it doesn't seem to stall that high.
OH the Cam is a comp 268 XE.
EDIT. it also runs the billet distributor with the lightest springs but I'm thinking it could do with more advance sooner too.
