Page 1 of 4 1 2 3 4
Engine oil #2451499
02/14/18 01:11 AM
02/14/18 01:11 AM
CA
62SAVOY Offline OP
62SAVOY  Offline OP
CA
It seems not to long ago there was a topic on this. I have used the search but can not seem to find it. People were telling about what they ran. I have a 440 blown engine and run solid lifters usually with additive. Just wondering what is good to use. Uncle needs to know for his car also he just got.
Todd
Re: Engine oil [Re: 62SAVOY] #2451508
02/14/18 01:22 AM
02/14/18 01:22 AM
I use Valvoline VR1 10x30 Wt. in my race motors now, I use to use Pennzoil 20/50WT racing but not anymore.
On your deal Valvoline VR1 10x30 should work very well, especially with medium valve spring pressures up twocents
Re: Engine oil [Re: 62SAVOY] #2451515
02/14/18 01:27 AM
02/14/18 01:27 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Lot of Brad Penn used in these parts...
Re: Engine oil [Re: 62SAVOY] #2451548
02/14/18 02:46 AM
02/14/18 02:46 AM
Texas
RustyM Offline
RustyM  Offline
Texas
Hey Cab_: Could you elaborate on the change?
I have realized to some degree the hp loss with thicker oils.
do you think oils are just better and thus we dont need to be as thick as before?
Re: Engine oil [Re: RustyM] #2451566
02/14/18 05:32 AM
02/14/18 05:32 AM
When Shell Oil CO. bought Pennzoil they change the formula to make it better with some different additives, a friend of mine who crew chiefs a winning SCCA spec. car told me about it around 15 yrs ago.
Valvoline now has the exact same feel when rubbing it between my fingers and probably the exact same additives as Pennzoil used to make their race oil slicker with less resistance work Valvoline VR oil is a lot easier for me to buy than Pennzoil racing oil also.
I have seen power gain by running hotter oils or thinner oils, hence using the 10W30Wt now versus the 20W50 WT oils up
If Valvoline or Pennzoil offered a 5W10 racing oil I would use it up
I use 5W20 WT Valvoline in all of my hot street motors with zinc additives, if needed for the cam and lifters. Same weight oil on street roller cam motors with no additives thumbs
I'm not completely sold on synthetic oils yet, maybe some day confused
Re: Engine oil [Re: Cab_Burge] #2451621
02/14/18 12:11 PM
02/14/18 12:11 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
This is a timely post for me. I have been running 20-50 VR-1 for a long time and my oil pressure was 80lbs hot. I have been trying some 10-30 while the weather is cold and I am not beating on the car as hard.
I believe that the 10-30 is a better choice for the engine. But since I have ran the 20-50 for years with no problems, I have been a bit hesitant to change.
But if it works for Cab, I'm in.
Master, again and still
Re: Engine oil [Re: 62SAVOY] #2451643
02/14/18 01:25 PM
02/14/18 01:25 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
In my race engines usually use Valvoline vr-1, street cars with older cast iron engines I use shell rotella. I am going to try some amsoil in my street car after reading this log post from another forum.
http://speedtalk.com/forum/viewtopic.php?t=28365
http://speedtalk.com/forum/viewtopic.php?f=1&t=36565
Re: Engine oil [Re: 62SAVOY] #2451645
02/14/18 01:30 PM
02/14/18 01:30 PM
warren, mich.
dwayne welder Offline
warren, mich.
Go to www.Bobistheoilguy.com 👍👍👍
Re: Engine oil [Re: 62SAVOY] #2451646
02/14/18 01:31 PM
02/14/18 01:31 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Brad Penn for the bracket cars and street cars for me. The Heads up car uses Driven, by Joe Gibbs.
Re: Engine oil [Re: Al_Alguire] #2451652
02/14/18 01:51 PM
02/14/18 01:51 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
10-30 Brad Penn user here with a zinc additive because I have a solid lifter cam in my small block.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Engine oil [Re: 62SAVOY] #2451670
02/14/18 02:40 PM
02/14/18 02:40 PM
jersey
Spaceman Spiff Offline
jersey
What are your bearing clearances?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Engine oil [Re: 62SAVOY] #2451675
02/14/18 02:54 PM
02/14/18 02:54 PM
an8sec70cuda Offline
I use Valvoline VR-1 in all our cars. 10w30 or 20w50 depending on which particular engine.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Engine oil [Re: 62SAVOY] #2451683
02/14/18 03:18 PM
02/14/18 03:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Regular Valvoline 10x30 syn. or Mobile-1 syn. and a Isky solid roller w/2.5+ on the rods and 3.3+ on the mains and hold good pressure and bearings look great after my 7-8 year tear downs........... beer
Re: Engine oil [Re: 62SAVOY] #2451689
02/14/18 03:44 PM
02/14/18 03:44 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I am about to put in a large Amsoil order for car, boat and harley. Amsoil is giving me 25% off + free shipping. I use the Dominator oil in the car.
Re: Engine oil [Re: mopar dave] #2451699
02/14/18 04:07 PM
02/14/18 04:07 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I've decided to just buy a 55-gallon drum of fish oil. Oil is oil, right?
Re: Engine oil [Re: 62SAVOY] #2451713
02/14/18 04:32 PM
02/14/18 04:32 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
We ran Valvoline 10w30 racing oil for years. Switched to Amsoil and saw a big difference in the appearance of the parts when we did our winter freshen and in the trash coming out of the filter, which we looked at after every weekend-even with the oil restricted to the cam and the top end. Also went from changing oil every dozen runs to every 50 or so, based on the appearance and smell of the oil.
With the Amsoil, we tried different weights from 10w30 to 0w20. The oil pressure with the water thin stuff got to be a little concerning, so we settled on 10w30, rather than tighten up the clearances. Clearances and internal leaks have to be adjusted and/or fixed depending on which weight oil you are using.
Re: Engine oil [Re: BradH] #2451732
02/14/18 05:29 PM
02/14/18 05:29 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I think my message would be oil is not oil. Looks to me that some has more additives than others and pass testing with higher marks as well.
Re: Engine oil [Re: 62SAVOY] #2451746
02/14/18 06:10 PM
02/14/18 06:10 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I use Joe Gibbs 10W40 in my street/strip car but I just checked Summit's site and it looks like it went up to $9.49 a quart.
Re: Engine oil [Re: mopar dave] #2451747
02/14/18 06:12 PM
02/14/18 06:12 PM
BradH Offline
BradH  Offline
My message is that the majority of oil discussions on here turn into big stinkin' piles of opinions without any empirical data to back them up.
Oil, religion, politics... possibly The Big Three of things which can never be discussed objectively.
I'll wait and see where this goes before I decide step back in here again. popcorn
Re: Engine oil [Re: BradH] #2451750
02/14/18 06:16 PM
02/14/18 06:16 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
LAT racing oil is what I run in the motor trans and and rear end
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Page 1 of 4 1 2 3 4
