Dana 60 Chrome Cover Leaking #2451311
02/13/18 06:57 PM
02/13/18 06:57 PM
South San Francisco, Ca
70sixpkrt Offline OP
My Dana 60 Chrome cover is leaking a tad from the fill plug. Is it a good idea to use Teflon Tape on it or not? It is not over filled.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Dana 60 Chrome Cover Leaking [Re: 70sixpkrt] #2451351
02/13/18 07:36 PM
02/13/18 07:36 PM
BDW Offline
BDW  Offline
Yes, had to do that on mine
Re: Dana 60 Chrome Cover Leaking [Re: 70sixpkrt] #2451477
02/14/18 12:20 AM
02/14/18 12:20 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Pull the plug and wire wheel the threads to remove the chrome, chase the hole in the cover with a tap the to do the same. Use a bit of non hardening gasket sealant like Permatex #3 and it should be leak free pretty much forever.
.02
Re: Dana 60 Chrome Cover Leaking [Re: 70sixpkrt] #2451512
02/14/18 01:24 AM
02/14/18 01:24 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use white Teflon sealer from the tube, never a leak.
Doug
Re: Dana 60 Chrome Cover Leaking [Re: 70sixpkrt] #2451541
02/14/18 02:16 AM
02/14/18 02:16 AM
Thanks.
4-speed
3:54 Dana
Re: Dana 60 Chrome Cover Leaking [Re: dvw] #2451673
02/14/18 02:43 PM
02/14/18 02:43 PM
an8sec70cuda Offline
Doug
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dana 60 Chrome Cover Leaking [Re: an8sec70cuda] #2452086
02/15/18 12:43 PM
02/15/18 12:43 PM
moparx Offline
moparx  Offline
Doug
iagree
loctite 56765 up best teflon sealer i have ever used ! all material compatible as well.
beer
