body side moulding replacement 1972 Scamp #2451286
02/13/18 06:08 PM
02/13/18 06:08 PM
VIRGINIA
71SCAMP Offline OP
71SCAMP  Offline OP
VIRGINIA
I'm getting ready for a repaint on my 1972 Plymouth Scamp which has body trim molding from the factory. Is replacement trim available? Is my current molding installed with screws or glue? Thanks
Re: body side moulding replacement 1972 Scamp [Re: 71SCAMP] #2451476
02/14/18 12:19 AM
02/14/18 12:19 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
My 70 Dart came with holes down the sides, and the 71 Dart I used to own way back had studs that were welded to the panels to hold the trim clips on. I'm guessing that your 72 would have the welded studs???
I doubt anyone reproduces the moldings. A nice used set off a Duster would work for the front fenders, and the doors and quarters would be the same as a Dart if you can't find another Scamp.
