Re: BB Water Pump
[Re: Jerry]
#2451242
02/13/18 04:24 PM
02/13/18 04:24 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
summit racing. although I believe theirs is only a six vane. Edited for attitude You might try talking to Stewart Components and see what they have, their catalog doesn't seem to be working but their LA pump is nice.
Re: BB Water Pump
[Re: Rhinodart]
#2451272
02/13/18 05:46 PM
02/13/18 05:46 PM
Supercuda
About to go away
About to go away
up yours
Not aluminum No anti-cavitation plate and the list grows
Re: BB Water Pump
[Re: Jerry]
#2451280
02/13/18 05:57 PM
02/13/18 05:57 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
summit racing. although I believe theirs is only a six vane. Looks to me most are 8 vane. So now the 'list' is shrinking.
Re: BB Water Pump
[Re: B5 Bee]
#2451284
02/13/18 06:04 PM
02/13/18 06:04 PM
Supercuda
About to go away
About to go away
up yours
summit racing. although I believe theirs is only a six vane. Looks to me most are 8 vane. So now the 'list' is shrinking. Nope, the req was an aluminum, 8 vane, with built in anti-cavitation plate. If it doesn't hit them all it is a fail. the list stays the same.
Re: BB Water Pump
[Re: 71birdJ68]
#2451379
02/13/18 09:02 PM
02/13/18 09:02 PM
Posts: 25,777 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Maybe there's a reason nobody offers the anti-cavitation plate.
Re: BB Water Pump
[Re: 71birdJ68]
#2451462
02/13/18 11:50 PM
02/13/18 11:50 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
as far I know, at least from factory, AC cars got 6 vanes with small pulley, and non AC got 8 vanes with big pulley.
Re: BB Water Pump
[Re: 71birdJ68]
#2451485
02/14/18 12:32 AM
02/14/18 12:32 AM
RapidRobert
Guess I could get a Mildon, which has 8, and add a plate. that is what I would do & get the pulley to spin it as fast as you can tho finding a pump pulley with the dia in your wanted range (~6") AND having the right depth for pulley/belt alignment ain't gonna be (too) easy.I would do the rest of the system: shroud/fan with many blades/fan spacing in the shroud/stiff lower hose or hose with a spring/proper timing/proper A/F ratio/good high flow stat, 180F or higher/good/clean 3 core radiator as wide a one as possible.
Re: BB Water Pump
[Re: 71birdJ68]
#2451493
02/14/18 12:54 AM
02/14/18 12:54 AM
Posts: 31,018 Oregon
AndyF
There are several 6 vanes with a anti cal plate. I'm looking to up grade. Guess I could get a Mildon, which has 8, and add a plate. 8 blades is not necessarily an upgrade from 6 blades. All depends on what speed you run the pump. If you look at what the factory did with the pumps you'll see that they didn't want to run the pump to fast or use too many blades when the pumps ran fast.
Re: BB Water Pump
[Re: 71birdJ68]
#2451497
02/14/18 01:06 AM
02/14/18 01:06 AM
RapidRobert
Is it running hot right now? (with what you have).
Re: BB Water Pump
[Re: 71birdJ68]
#2451572
02/14/18 06:56 AM
02/14/18 06:56 AM
Posts: 956 Chicago
PurpleBeeper
Chicago
You might consider lowering your antifreeze blend from 50/50 to something like 30/70 or 40/60 (more distilled water) depending on how cold it could possibly get in your area. There are freeze protection charts on a lot of antifreeze bottles and 50/50 goes to -34F. More water cools better.
Add a little Water Wetter (maybe 1/2 bottle) along with your increased water blend.
Maybe use some engine degreaser & power washer on the radiator's outside while it's out & you can get at the whole thing. Maybe flush the cooling system too before putting in your new coolant.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
