BB Water Pump #2451225
02/13/18 03:41 PM
02/13/18 03:41 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
I've looked around and can't find a aluminum pump with 8 vanes, and a built in cavitation plate. Does anybody make one? I'm not looking for a flowkooler type.
Re: BB Water Pump [Re: 71birdJ68] #2451240
02/13/18 04:15 PM
02/13/18 04:15 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
summit racing. although I believe theirs is only a six vane.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: BB Water Pump [Re: Jerry] #2451242
02/13/18 04:24 PM
02/13/18 04:24 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Edited for attitude
You might try talking to Stewart Components and see what they have, their catalog doesn't seem to be working but their LA pump is nice.
Re: BB Water Pump [Re: Supercuda] #2451269
02/13/18 05:42 PM
02/13/18 05:42 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
They make 10 vane marine pumps... panic
Napa 42032 is the 8-vane type I believe.
This is an interesting read on water pumps for RV's...
http://www.classicwinnebagos.com/forum/index.php?topic=737.25
JB Rhinehart, Realist
A-Body's RULE!
Re: BB Water Pump [Re: Rhinodart] #2451272
02/13/18 05:46 PM
02/13/18 05:46 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not aluminum
No anti-cavitation plate
and the list grows
Don't be the exception.
Re: BB Water Pump [Re: Jerry] #2451280
02/13/18 05:57 PM
02/13/18 05:57 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Looks to me most are 8 vane.
So now the 'list' is shrinking.
Re: BB Water Pump [Re: B5 Bee] #2451284
02/13/18 06:04 PM
02/13/18 06:04 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Nope, the req was an aluminum, 8 vane, with built in anti-cavitation plate. If it doesn't hit them all it is a fail.
the list stays the same.
Re: BB Water Pump [Re: 71birdJ68] #2451379
02/13/18 09:02 PM
02/13/18 09:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Maybe there's a reason nobody offers the anti-cavitation plate.
Re: BB Water Pump [Re: John_Kunkel] #2451389
02/13/18 09:25 PM
02/13/18 09:25 PM
Morristown Tn.
Morristown Tn.
There are several 6 vanes with a anti cal plate. I'm looking to up grade. Guess I could get a Mildon, which has 8, and add a plate.
Re: BB Water Pump [Re: 71birdJ68] #2451431
02/13/18 10:55 PM
02/13/18 10:55 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
next option would be an overdrive pulley and run the six vane. its harder to put the anti cavitation plate onto a big block pump. it has to got between the impeller and the water pump casting.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: BB Water Pump [Re: Jerry] #2451458
02/13/18 11:44 PM
02/13/18 11:44 PM
Morristown Tn.
Morristown Tn.
I have a 383 A/C pulley, but somebody said it wouldn't line up with the rest of my pulleys.
Re: BB Water Pump [Re: 71birdJ68] #2451462
02/13/18 11:50 PM
02/13/18 11:50 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
as far I know, at least from factory, AC cars got 6 vanes with small pulley, and non AC got 8 vanes with big pulley.
Re: BB Water Pump [Re: 71birdJ68] #2451485
02/14/18 12:32 AM
02/14/18 12:32 AM
that is what I would do & get the pulley to spin it as fast as you can tho finding a pump pulley with the dia in your wanted range (~6") AND having the right depth for pulley/belt alignment ain't gonna be (too) easy.I would do the rest of the system: shroud/fan with many blades/fan spacing in the shroud/stiff lower hose or hose with a spring/proper timing/proper A/F ratio/good high flow stat, 180F or higher/good/clean 3 core radiator as wide a one as possible.
Re: BB Water Pump [Re: 71birdJ68] #2451493
02/14/18 12:54 AM
02/14/18 12:54 AM
AndyF Online content
AndyF  Online Content
8 blades is not necessarily an upgrade from 6 blades. All depends on what speed you run the pump. If you look at what the factory did with the pumps you'll see that they didn't want to run the pump to fast or use too many blades when the pumps ran fast.
Re: BB Water Pump [Re: RapidRobert] #2451494
02/14/18 12:56 AM
02/14/18 12:56 AM
Morristown Tn.
Morristown Tn.
The rest of the system is up to snuff, the pump is the only thing that I didn't know anything about, it was already on the engine. It is an aluminum 6 vane with an anti cav plate. The pulleys are brand new, and are of the Hemi variety, so I don't want to buy a hole bunch of new stuff.
Re: BB Water Pump [Re: 71birdJ68] #2451497
02/14/18 01:06 AM
02/14/18 01:06 AM
Is it running hot right now? (with what you have).
Re: BB Water Pump [Re: 71birdJ68] #2451510
02/14/18 01:23 AM
02/14/18 01:23 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Or you could just pony up the coin and buy an edelbrock pump and call it a day. For engine driven, that is the pump.
I want my fair share
Re: BB Water Pump [Re: RapidRobert] #2451555
02/14/18 03:30 AM
02/14/18 03:30 AM
Morristown Tn.
Morristown Tn.
It will run 210/215 on a hot day. I know everybody says that that temp is ok, but I have the rad off for some other things, so I thought if a pump upgrade would lower it a few degrees, then I would give that a try.
Re: BB Water Pump [Re: 71birdJ68] #2451572
02/14/18 06:56 AM
02/14/18 06:56 AM
Chicago
PurpleBeeper Offline
Chicago
You might consider lowering your antifreeze blend from 50/50 to something like 30/70 or 40/60 (more distilled water) depending on how cold it could possibly get in your area. There are freeze protection charts on a lot of antifreeze bottles and 50/50 goes to -34F. More water cools better.
Add a little Water Wetter (maybe 1/2 bottle) along with your increased water blend.
Maybe use some engine degreaser & power washer on the radiator's outside while it's out & you can get at the whole thing. Maybe flush the cooling system too before putting in your new coolant.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: BB Water Pump [Re: 71birdJ68] #2451620
02/14/18 12:10 PM
02/14/18 12:10 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
if you're running 210/215 on a hot day and its not climbing over that you are fine.
basic setup you should have a shroud on rad with a large clutch fan that is engine driven, 16lb radiator cap on rad. if you really want it brought down, then you need to be able to dissipate heat faster. more flow won't help necessarily if the radiator cant remove the heat. so at that stage you need a big 2 core aluminum rad. does the temp go up our down as you drive? if you drive and temp goes down, then you need more air flow through your rad. electric fans might help.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
