Cam cores (flat tappet)
#2451113
02/13/18 11:22 AM
02/13/18 11:22 AM
Posts: 636 Graz, Austria
DGS
Graz, Austria
Since a few years flat tappet failures have been going up. There are several factors involved (new aggressive lobes, oil formulation etc.) and one of them is the quality of the cam core. Which companies are still making flat tappet cam cores? Which cam grinder uses which company? Or do Comp Cams, Lunati, Bullet, Mike Jones all use the same cores? Is there a reason why choosing one cam core over the other?
Re: Cam cores (flat tappet)
[Re: DGS]
#2451166
02/13/18 01:26 PM
02/13/18 01:26 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
For flat tappet cam cores that fit a traditional B/RB or 59* SB Mopar with std journals.......I'd be pretty surprised if there was more than one or two places supplying cores.
Engine Power or Camshaft Machine.
[Re: DGS]
#2451649
02/14/18 01:44 PM
02/14/18 01:44 PM
fast68plymouth
So. Burlington, Vt.
It's correct for something like SBC...... Not a BB Mopar.
For flat tappet cores for that platform, i suspect there is probably only one core choice...... Maybe two(one wide lsa, one tight lsa).
[Re: fast68plymouth]
#2451775
02/14/18 07:00 PM
02/14/18 07:00 PM
BradH
Engine Power or Camshaft Machine. Who was the "CW" that I used to see on my flat-tappet cams? Or am I confusing "CW" with "CM"?
[Re: DGS]
#2452678
02/16/18 06:07 PM
02/16/18 06:07 PM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I have a new unused Engle Hyd Flat tappet cam I bought in 2002 for my 360. Is this camshaft old enough to be of the better quality metal then todays cams?
Keep old mopars alive.
