Re: 295/65R15 M/T ET rim size
[Re: topside]
#2451030
02/13/18 12:30 AM
02/13/18 12:30 AM
Posts: 12,156 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have 295/65s on 10" Cragars. The edges are pulled up off the pavement with 18-20 lbs. I have to let them down to 12 lbs or so to get them to lay the full face on the pavement. And 12 lbs is too low.
What rims are you considering? Most companies will build your backspace on a special order. Cragar did mine.
You may want to consider the 275/60 Rs on a 10" rim. They would lay better with the 10" rims IMHO. The only reason I don't do that myself is because I like the look of those huge 295s on the back of the Cuda.
Master, again and still
[Re: topside]
#2451069
02/13/18 02:08 AM
02/13/18 02:08 AM
Posts: 4,209 New York
polyspheric
New York
One of the decisions is do you want the tire diameter to grow (like you may run out of gear)? If yes, narrower rim will get bigger at speed. Otherwise, rim width = sidewall width is safe. 295mm = 11.6".
Boffin Emeritus
[Re: topside]
#2451070
02/13/18 02:16 AM
02/13/18 02:16 AM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
295 I would run on a 10 inch wheel minimum, a 12 inch would be better. I run 275’s on a 10 inch wheel and to me it’s a great combo....
A new iron curtain drawn across the 49th parallel
[Re: topside]
#2451109
02/13/18 10:59 AM
02/13/18 10:59 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
M/T recommends an 8.5" wide rim for that tire, but most agree wider is better. I run 8.5" wide rims on my cuda w/ the 295-65 radial basically b/c of my stock width rear, a 10" won't fit. Seems to work ok though. Best 60 foot footbraking on motor is 1.320. Best on nitrous so far is a 1.30 w/ a very delayed nitrous hit.
[Re: topside]
#2451112
02/13/18 11:14 AM
02/13/18 11:14 AM
Posts: 214 Hamburg / Germany
Den300
Hamburg / Germany
same size but hoosier radials on 8" rims. no problem
Hamburg/Germany
69 Chrysler 300 446cui Dual Quad 12.64 @ 110.7
[Re: Den300]
#2451127
02/13/18 11:46 AM
02/13/18 11:46 AM
Posts: 468 Dirty Dena, Maryland
dodge turbo
I run mine on a 10. It spread the tire out more then the 8 I used to run
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
[Re: dodge turbo]
#2451133
02/13/18 11:58 AM
02/13/18 11:58 AM
Posts: 4,569 Motor City
6PKRTSE
Motor City
I had them stretched onto my 12" wide rims at one time. I now currently have 315's & they fill the wheel well much better.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#2451168
02/13/18 01:28 PM
02/13/18 01:28 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
same tire on a 10" rim, contact patch looks good to me...
Looks small compared to the 315 or 325 I used run
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: topside]
#2451755
02/14/18 06:25 PM
02/14/18 06:25 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I had them on a 10" rim on my Dart.
[Re: topside]
#2451803
02/14/18 07:53 PM
02/14/18 07:53 PM
Posts: 860 lancaster,california
johnnycuda
My 'Cuda has the MT 295/65-15 drag radial,on a 10" rim, 6.5" BS, stock width E-body 8.75, springs inboarded 3", stock wheel tubs, drives great, rides nice, mid-10 3800lbs.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: topside]
#2451915
02/14/18 11:46 PM
02/14/18 11:46 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I am shooting for a 295/65 on a 10" wheel on my Bee. My signature pic is 276/60/15 on an 8"(I think)wheel. I like the width of a 315, but I don't like the short tire.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: OhioMopar]
#2451955
02/15/18 01:05 AM
02/15/18 01:05 AM
Posts: 43,223 Bend,OR USA
Cab_Burge
I think that both of the sets of the M/T Street radials tires I ran(295x65x15, 315x60x15) had the same circumference when measure with a seamstress tape, but maybe not as that was a long time ago I have 96.0 inch circumference for both in my mind, the 315x60x15 on a ten inch wide rim and the 295x65x15 on the 12 inch wide rims I ran 4.10 rear gears in the car most of the time and I would see a 500 RPM drop switching from the 315x60x15 E.T. Street radials to the larger diameter 10.5x31x15W M/T slicks which had right at 102 inch circumference on the ten inch rims, no real MPH change in the 1/4 mile though that I remember, just RPM recorded on the VDO playback tach in the car
[Re: Cab_Burge]
#2452017
02/15/18 04:58 AM
02/15/18 04:58 AM
OhioMopar
Mt.Gilead, Ohio
I think that both of the sets of the M/T Street radials tires I ran(295x65x15, 315x60x15) had the same circumference when measure with a seamstress tape, but maybe not as that was a long time ago I have 96.0 inch circumference for both in my mind, the 315x60x15 on a ten inch wide rim and the 295x65x15 on the 12 inch wide rims I ran 4.10 rear gears in the car most of the time and I would see a 500 RPM drop switching from the 315x60x15 E.T. Street radials to the larger diameter 10.5x31x15W M/T slicks which had right at 102 inch circumference on the ten inch rims, no real MPH change in the 1/4 mile though that I remember, just RPM recorded on the VDO playback tach in the car Turns out it was 315/50/15 that are shorter. 315/60's are 29.88 vs. 30.1 on the 295/65.
[Re: topside]
#2452081
02/15/18 12:29 PM
02/15/18 12:29 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I taped a piece of cardboard on the floor and then drove the car on it, positioning a rear wheel on it. Then I pulled the wheel and used a plumb bob to mark out everything on the cardboard.
The spring, hub, wheel well, etc. That is the most accurate way I have found to KNOW where everything is and to have a constant reference when researching wheels.
And be sure to do both sides to catch any differences.
[Re: Uncle Barry]
#2452094
02/15/18 01:06 PM
02/15/18 01:06 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I run an 8" wheel. I know it's probably too narrow but it's what I can fit with the b body Dana and offset shackles. I'd like to go to a 10" wheel but I don't want to hack on my car.. What he said. I'm starting to wonder if I would be better w 275/60s (drop gear a tick) on 8s over 295/65s on 8s.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Uncle Barry]
#2452241
02/15/18 06:07 PM
02/15/18 06:07 PM
Posts: 247 Brisbane Australia
crash520
Brisbane Australia
I run an 8" wheel. I know it's probably too narrow but it's what I can fit with the b body Dana and offset shackles. I'd like to go to a 10" wheel but I don't want to hack on my car.. I have a B body Dana, 1”spring relocation kit from Dr Diff, NO Fender lip modifications or any other body mods and 15x10 5.5 bs with 295’s fit without rubbing under my 73 Cuda
[Re: Von]
#2452337
02/15/18 10:39 PM
02/15/18 10:39 PM
Posts: 1,070 Big Western Pencilveinya
Uncle Barry
I run an 8" wheel. I know it's probably too narrow but it's what I can fit with the b body Dana and offset shackles. I'd like to go to a 10" wheel but I don't want to hack on my car.. What he said. I'm starting to wonder if I would be better w 275/60s (drop gear a tick) on 8s over 295/65s on 8s. I just run the 295 because it looks better than a 275. I do use a 275 at the track tho.
[Re: crash520]
#2452339
02/15/18 10:43 PM
02/15/18 10:43 PM
Uncle Barry
I run an 8" wheel. I know it's probably too narrow but it's what I can fit with the b body Dana and offset shackles. I'd like to go to a 10" wheel but I don't want to hack on my car.. I have a B body Dana, 1”spring relocation kit from Dr Diff, NO Fender lip modifications or any other body mods and 15x10 5.5 bs with 295’s fit without rubbing under my 73 Cuda It seems pretty tight under my car. I may look into a 10" wheel but I can't see it fitting in there.
[Re: Uncle Barry]
#2452416
02/16/18 01:56 AM
02/16/18 01:56 AM
Posts: 280 GEORGIA
barracuda7199
GEORGIA
I run an 8" wheel. I know it's probably too narrow but it's what I can fit with the b body Dana and offset shackles. I'd like to go to a 10" wheel but I don't want to hack on my car.. I have a B body Dana, 1”spring relocation kit from Dr Diff, NO Fender lip modifications or any other body mods and 15x10 5.5 bs with 295’s fit without rubbing under my 73 Cuda It seems pretty tight under my car. I may look into a 10" wheel but I can't see it fitting in there. 15x10 5.5 backspace fits my 71 cuda great with a b body rear and dr diff relocators. I ran a 325-50 with rolled lips before I took the car apart.
