Big bore small block head gasket #2450796
02/12/18 06:37 PM
02/12/18 06:37 PM
East Brunswick New Jersey
N
NoFrills Offline OP
NoFrills  Offline OP
N
I have a 4.185 bore r3 with w2 heads. I only head gasket that i see listed with big enough of a bore is one with more head bolt holes. I can get 4.180 gaskets in a few different thicknesses. I know they say the gasket should be at least .01 bigger then the bore. My piston is .01 in the hole. Just wondering some different thoughts.
Re: Big bore small block head gasket [Re: NoFrills] #2450799
02/12/18 06:44 PM
02/12/18 06:44 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Cometic will make a bigger bore and whatever thickness you need as well
Just give them a call
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Big bore small block head gasket [Re: B3422W5] #2450815
02/12/18 07:14 PM
02/12/18 07:14 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
iagree
Re: Big bore small block head gasket [Re: Biginchmopar] #2450837
02/12/18 07:43 PM
02/12/18 07:43 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
iagree
X3
Re: Big bore small block head gasket [Re: justinp61] #2450888
02/12/18 09:25 PM
02/12/18 09:25 PM
N
NoFrills Offline OP
NoFrills  Offline OP
N
I guess I should call cometic
