trick flow head que #2450123
02/11/18 03:54 PM
02/11/18 03:54 PM
birdtracker Offline OP
do the trickflow 240 and 270 use the same rocker assembly? thanks Birdtracker
Re: trick flow head que [Re: birdtracker] #2450143
02/11/18 04:31 PM
02/11/18 04:31 PM
okla.
sam64 Offline
sam64  Offline
okla.
according to AndyF, yes.
Re: trick flow head que [Re: birdtracker] #2450224
02/11/18 07:15 PM
02/11/18 07:15 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
According to Trick Flow as well.
Re: trick flow head que [Re: fast68plymouth] #2450239
02/11/18 07:46 PM
02/11/18 07:46 PM
The reason behind the question is I thought the intake rocker would have more offset or perhaps a bigger spacer. Birdtracker
Re: trick flow head que [Re: birdtracker] #2450324
02/11/18 10:19 PM
02/11/18 10:19 PM
AndyF Offline
AndyF  Offline
The Trick Flow heads use a standard offset rocker arm. 50 year old nodular iron Max Wedge rocker arms should fit on a Trick Flow 270 head.
