4 hole Spacer or Open Hole on a 4500 Dominator #2450017
02/11/18 01:00 PM
02/11/18 01:00 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Just mounted up a new Holley Dominator and have a choice of either a open hole 3/4" Phenolic Spacer or a Hamburgers Billet 4 hole 1"Spacer.
What are the Pro's and Con's of each?
Re: 4 hole Spacer or Open Hole on a 4500 Dominator [Re: Sammy] #2450019
02/11/18 01:10 PM
02/11/18 01:10 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Post a picture looking down into the top of the intake
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: 4 hole Spacer or Open Hole on a 4500 Dominator [Re: Sammy] #2450024
02/11/18 01:17 PM
02/11/18 01:17 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
If your Dominator still has internal linkage, at minimum you need a 4 hole shear plate. It keeps linkage parts from mixing it up with your valves and pistons.
[image][/image]
Re: 4 hole Spacer or Open Hole on a 4500 Dominator [Re: Sammy] #2450030
02/11/18 01:30 PM
02/11/18 01:30 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The only way to know for sure which one the engine will like, is to test.
Master, again and still
Re: 4 hole Spacer or Open Hole on a 4500 Dominator [Re: DaveRS23] #2450127
02/11/18 03:59 PM
02/11/18 03:59 PM
iagree
Buy both of them and then sell the one you don't like twocents
Don't forget to stack them together also before deciding scope up
Re: 4 hole Spacer or Open Hole on a 4500 Dominator [Re: Sammy] #2450136
02/11/18 04:15 PM
02/11/18 04:15 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You don't need a shear plate for an internal linkage Dominator, you do need a safety plate, if you use an open spacer to make sure if anything happens it don't get in the engine. A 4 hole spacer does the same thing. 20ish bucks from summit or jegs
As for which spacer you need, there is no magic formula. If it is a street strip deal Id likely just use a 4 hole, wont need the safety plate that way. As for which will work best a lot of factors in that equation, as stated only way to know is try both. One will give you a better signal to the booster the other ads to plenum volume.
Re: 4 hole Spacer or Open Hole on a 4500 Dominator [Re: WHITEDART] #2450168
02/11/18 05:13 PM
02/11/18 05:13 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
iagree
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: 4 hole Spacer or Open Hole on a 4500 Dominator [Re: Al_Alguire] #2450332
02/11/18 10:30 PM
02/11/18 10:30 PM
sgcuda Offline
sgcuda  Offline
Originally Posted By Al_Alguire
You don't need a shear plate for an internal linkage Dominator, you do need a safety plate.
That's what I meant. Thanks, Al.
Re: 4 hole Spacer or Open Hole on a 4500 Dominator [Re: Sammy] #2450394
02/11/18 11:36 PM
02/11/18 11:36 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
4 hole is for torque,open for top end
Re: 4 hole Spacer or Open Hole on a 4500 Dominator [Re: Sammy] #2450752
02/12/18 05:13 PM
02/12/18 05:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I run a minimum of a 1/2 wood four hole then if you have room an open for the mid/upper power but like stated, it's a trial n error deal.......
Re: 4 hole Spacer or Open Hole on a 4500 Dominator [Re: Sammy] #2450756
02/12/18 05:24 PM
02/12/18 05:24 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I like the small 4 holes wood ones as well. Need a safety plate anyway so may as well get some heat sink benefit from that
