Re: 4 hole Spacer or Open Hole on a 4500 Dominator
[Re: Sammy]
#2450019
02/11/18 01:10 PM
02/11/18 01:10 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Post a picture looking down into the top of the intake
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Sammy]
#2450024
02/11/18 01:17 PM
02/11/18 01:17 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
If your Dominator still has internal linkage, at minimum you need a 4 hole shear plate. It keeps linkage parts from mixing it up with your valves and pistons.
[image][/image]
[Re: Sammy]
#2450030
02/11/18 01:30 PM
02/11/18 01:30 PM
Posts: 12,244 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The only way to know for sure which one the engine will like, is to test.
Master, again and still
[Re: DaveRS23]
#2450127
02/11/18 03:59 PM
02/11/18 03:59 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
The only way to know for sure which one the engine will like, is to test. Buy both of them and then sell the one you don't like Don't forget to stack them together also before deciding
[Re: Sammy]
#2450136
02/11/18 04:15 PM
02/11/18 04:15 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
You don't need a shear plate for an internal linkage Dominator, you do need a safety plate, if you use an open spacer to make sure if anything happens it don't get in the engine. A 4 hole spacer does the same thing. 20ish bucks from summit or jegs
As for which spacer you need, there is no magic formula. If it is a street strip deal Id likely just use a 4 hole, wont need the safety plate that way. As for which will work best a lot of factors in that equation, as stated only way to know is try both. One will give you a better signal to the booster the other ads to plenum volume.
[Re: Sammy]
#2450752
02/12/18 05:13 PM
02/12/18 05:13 PM
Thumperdart
State of confusion
I run a minimum of a 1/2 wood four hole then if you have room an open for the mid/upper power but like stated, it's a trial n error deal.......
[Re: Sammy]
#2450756
02/12/18 05:24 PM
02/12/18 05:24 PM
Al_Alguire
Las Vegas
I like the small 4 holes wood ones as well. Need a safety plate anyway so may as well get some heat sink benefit from that
