Re: Indy hemi dual plane
[Re: Lee446]
#2450048
02/11/18 02:04 PM
02/11/18 02:04 PM
Posts: 12,053 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The divider has a notch cut out to connect the 2 sides. I tried a 4 hole spacer and an open spacer back to back on the dyno.
Not surprisingly, the 4 hole had more under 4,500rpm (10+/-) while the open had more over 4,500rpm (20+/-).
I ended up with a 1/2" wood open spacer. It really dropped the carb temp, too.
Master, again and still
