C body discs on a B body #244947
03/06/09 02:17 PM
03/06/09 02:17 PM
San Antonio, TX
CurYellowBird Offline OP
San Antonio, TX
I found a 68 chrysler imperial out at the junk yard that has discs but its a C body. Will these spindles fit on my 71 roadrunner?
I ran into problem trying to find discs because my car doesn't have that rubber biscuit between the K frame and the frame rail. I also found a 73' satellite and 74' charger that had discs but they both had that rubber biscuit. I dont know if i can use those spindles because they might be taller. So I need some advice if I can use the spindles off that imperial and if I could use the spindles off those mopars that have that rubber isolator in order to fit on my 71 roadrunner that doesn't have that rubber isolator (metal to metal bolt in, no isolator).
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: C body discs on a B body [Re: CurYellowBird] #244948
03/06/09 02:35 PM
03/06/09 02:35 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The c body disc will not work , the 73 B body setup can work. The spindle is about 3/8" taller , otherwise everything is the same. Though there is sligthly more angle on the ball joint (I think) at full extension of the suspension there are no known, at least to me, ball joint failures because of it. I think Firm Feel has a modded ball joint for those to scared to run it ??? That taller spindle is used on F,J,M and R bodies .
If you can find a 73 up a body that has the same spindle as you would want on your 71 .
Re: C body discs on a B body [Re: CurYellowBird] #244949
03/06/09 02:39 PM
03/06/09 02:39 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You can't use Imperial or C-body brakes.
The best junkyard disc brake brake swap is 73'-'76 A/E body brakes, or the more common (taller) '73 and newer B/F/M/J/R body stuff.
The 3/8" taller knuckles work fine.
Re: C body discs on a B body [Re: DoctorDiff] #244950
03/06/09 04:19 PM
03/06/09 04:19 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
will they work for putting disc on my 70 gran coupe barracuda with drums on it now????
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: C body discs on a B body [Re: toplescuda] #244951
03/06/09 04:23 PM
03/06/09 04:23 PM
JohnRR Offline
JohnRR  Offline
what , the C body brakes ???
Re: C body discs on a B body [Re: JohnRR] #244952
03/06/09 04:27 PM
03/06/09 04:27 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
no will spindels for a f body work for putting disc on my 70 gran coup(e body)
1971 charger
Re: C body discs on a B body [Re: toplescuda] #244953
03/06/09 04:28 PM
03/06/09 04:28 PM
JohnRR Offline
JohnRR  Offline
yes
Re: C body discs on a B body [Re: toplescuda] #244954
03/06/09 06:08 PM
03/06/09 06:08 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If you run slider calipers toward the front of the car, you can use off-the-shelf '73-'76 A-body disc brake hoses.
If you end up with late model B-body pin calipers, run them toward the rear of the car and use a DOT stainless 15" flex hose with 7/16" banjo fitting. This set up works nicely on pre '70 B and A bodies equipped with stock front sway bar.
Re: C body discs on a B body [Re: CurYellowBird] #244955
03/06/09 07:11 PM
03/06/09 07:11 PM
AndyF Offline
AndyF  Offline
I have the design for a bearing that will allow the use of a C body rotor on an B (or A/E/FMJ) spindle. The nice thing about that is the C body rotor is 1.25 thick so the Viper calipers fit without any pad spacers. I'm not sure if I'll ever get any of the bearings made or not though. It costs some money to get a special bearing made even if the modification is easy to do.
Re: C body discs on a B body [Re: AndyF] #244956
03/06/09 08:28 PM
03/06/09 08:28 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Too bad there isn't an off-the-shelf bearing that would work. Then the Viper caliper setup would be even more trick. How much do the C-body rotors weigh in comparison to the 11.75 inch B-body rotors?
Re: C body discs on a B body [Re: MoparMarq] #244957
03/06/09 08:40 PM
03/06/09 08:40 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Even if you make the adapter for C body to B the Imperial stuff still wont work.The brakes were strictly Imperial.They even had If I remember from my 66 a 5 inch bolt pattern.Plus Imps took the huge ball joint.Rocky
Chrysler Firepower
Re: C body discs on a B body [Re: therocks] #244958
03/06/09 10:00 PM
03/06/09 10:00 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: C body discs on a B body [Re: MoparMarq] #244959
03/06/09 10:07 PM
03/06/09 10:07 PM
AndyF Offline
AndyF  Offline
Yep, the C body rotors are heavy but at least the weight is in the correct location. With C body rotors and Viper calipers a person would have a pretty good track setup that would fit inside of 15 inch rims. That would be a cool deal for a NASCAR type setup with steel rims.
Re: C body discs on a B body [Re: AndyF] #244960
03/07/09 11:40 AM
03/07/09 11:40 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Imperials (I think up to 71?)do have the 5" bolt circle tho....
Re: C body discs on a B body [Re: AndyF] #244961
03/07/09 02:00 PM
03/07/09 02:00 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
I thought the C-body rotor were pretty expensive and hard to find expect the 73 and up ones that are shared with the light duty 71? and up D-100 trucks? Is that the rotor you are thinking about Andy?
Anyway to do the project with bearing adapters?
Re: C body discs on a B body [Re: autoxcuda] #244962
03/07/09 02:31 PM
03/07/09 02:31 PM
AndyF Offline
AndyF  Offline
Yes, the 1973 C rotor uses the same inner wheel bearing as the A body rotor. The outer wheel bearing is slightly larger on the C body. The length is basically the same.
Re: C body discs on a B body [Re: AndyF] #244963
04/13/11 09:21 AM
04/13/11 09:21 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I just put 73 C-Body spindles and Viper calipers on my Challenger. I had to make a custom caliper bracket and slot the lower ball joint holes. It all worked out great! I'm very happy with it! Sorry for the link but I'm too lazy to type it all out again! LOL
http://www.cuda-challenger.com/cc/index.php?topic=73985.0
Re: C body discs on a B body [Re: brads70] #244964
04/13/11 09:55 AM
04/13/11 09:55 AM
JohnRR Offline
JohnRR  Offline
Brad , good read , where did you get the rotors and how much are they ?
Re: C body discs on a B body [Re: brads70] #244965
04/13/11 05:17 PM
04/13/11 05:17 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I got the rotors off E-Bay. I offed and paid $170 for the pair . The seller is open to offers.
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=350445239266&ssPageName=STRK:MEWAX:IT
Re: C body discs on a B body [Re: brads70] #244966
04/13/11 06:08 PM
04/13/11 06:08 PM
JohnRR Offline
JohnRR  Offline
I'm not up on the 72 C barge rotor , does it have a separate hub ?
