Re: Anyone use an Edelbrock CH-28 with the Vanke modification ?
[Re: GLR]
#2449685
02/10/18 07:04 PM
02/10/18 07:04 PM
Posts: 4,213 New York
polyspheric
New York
http://tinyurl.com/y9pbaea8Just a guess: peak power is up, idle quality and low speed response is down (needs more pump shot, richer primaries, smaller IAB). Mixture distribution probably worse than the original Edelbrock.
Boffin Emeritus
[Re: GLR]
#2449979
02/11/18 10:54 AM
02/11/18 10:54 AM
Posts: 214 Hamburg / Germany
Den300
Hamburg / Germany
Don Dulmage from Canada milled down the divider a bit but not completely. Just 3/8" down. Search the net for "old reliable". 11.5x at 118mph the quarter mile with a 74 Charger.
@AndyF: I am surprised the CH-28 (I am running one) makes the peak HP at higher rpm than the RPM. Based on all the theories it should be the opposite. Is there any explanation for this?
Thanks Dennis
Hamburg/Germany
69 Chrysler 300 446cui Dual Quad 12.64 @ 110.7
[Re: GLR]
#2450067
02/11/18 02:20 PM
02/11/18 02:20 PM
polyspheric
New York
My guess: the single ran out of CFM
Boffin Emeritus
[Re: GLR]
#2450069
02/11/18 02:22 PM
02/11/18 02:22 PM
fast68plymouth
So. Burlington, Vt.
I'm going with........ at wot the effective runner length of the CH-28 is shorter.
[Re: polyspheric]
#2450690
02/12/18 03:12 PM
02/12/18 03:12 PM
Den300
Hamburg / Germany
My guess: the single ran out of CFM so the solution to solve this "problem" would be a) intake with greater flow or b) a bigger carb (1000cfm is already big) or c) both? thanks! Dennis
Hamburg/Germany
