#2448677 - 02/08/18 05:24 PM 1970 Roadrunner airgrabber 4 bbl vs 6bbl.
Highwaystar2 Offline
Loc: S. Central PA
Is there any differences in the rubber to air cleaner lid on a 70 roadrunner 4 barrel vs. 6 pac set up? I currently have a 4 barrel and i'm looking into putting a 6 pac on my 383. Is there any differences in the air-grabber under hood construction to line up with the larger oval air cleaner lid, if so where can I find.
Thanks.
#2448679 - 02/08/18 05:29 PM Re: 1970 Roadrunner airgrabber 4 bbl vs 6bbl. [Re: Highwaystar2]
Morty426 Offline
Loc: Sacramento CA
No. The air cleaner bases are what are different. There are four different ones; 383, 440, 440+6 and Hemi
#2448696 - 02/08/18 05:52 PM Re: 1970 Roadrunner airgrabber 4 bbl vs 6bbl. [Re: Highwaystar2]
flypaper Offline
I hate Texas
Loc: jersey shore
if you are putting a 6 pack on a 383 under a airgrabber hood..
you will have height issues with the aircleaner to the hood
fit as the 440 engines will sit a bit higher
then a 383 engine will.
they had 2 different 4bbl airgrabber aircleaner versions for that reason.
they don't have 2 different 6 pack aircleaner versions that I'm aware of as they only were used with a 440 from the factory.
#2449476 - 02/10/18 09:49 AM Re: 1970 Roadrunner airgrabber 4 bbl vs 6bbl. [Re: Highwaystar2]
PurpleBeeper Offline
Loc: Chicago
These guys are correct, but I have a very simple solution for you...
1. Morty426 is correct about 4 air-grabber air cleaners. The 383 4bbl. and 440 4bbl. have the same lid, but the 383's base is about 1" taller in the area where the base slides on the top of the carburetor. Setting on the ground, the 383 bases will stand up off the ground & 440 bases will set flat.
2. I don't believe the shorter 383 will hurt your too much (if at all). It might actually HELP you since you will have about 1" extra hood clearance to play with....just enough for some nitrous plates, some vapor lock resistant carb spacers, or just regular carb spacers. GO FOR IT
3. And to answer your specific question, the 4 bbl. air cleaner lids are round in 1970 & the six pack air cleaners are big/oval. The 69 4-barrel air cleaner will fit in a 70 hood, but not the 69 six pack air cleaner, fyi.
Edited by PurpleBeeper (02/11/18 06:42 PM)
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
25,696 Registered Members
196,730 Topics
Are cassettes making a comeback?
by DUFFMAN
01/18/19 10:34 PM
Indoor (home) emergency heating, kerosene, propane, other??
by A12
01/18/19 10:31 PM
Basic ignition question, using MSD-6AL and MSD-8680 boxes
by Fab64
01/18/19 10:29 PM
318 head flow
by skrews
01/18/19 09:35 PM
