Tri-Castle Nuts #2448314
02/08/18 01:51 AM
02/08/18 01:51 AM
cbusters Offline OP
cbusters  Offline OP
69 Road Runner. working on the front suspension detailing and can not find any reference on the color of the Tri-Castle nuts used on the Ball Joints, Steering Arm, Idler Arm and Tie Rod Ends.
Natural?
Black Phosphate?
I believe I have the cotter pins figured out though.
Re: Tri-Castle Nuts [Re: cbusters] #2448359
02/08/18 05:26 AM
02/08/18 05:26 AM
Cut and Shoot, TX
kentj340 Online penguin-006
kentj340  Online Penguin-006
Cut and Shoot, TX
See page 46, part number B-11486 with pentastar logo here:
http://www.amkproducts.com/Catalog_PDF/39-55.pdf
The S2 finish is "Phosphate & Oil (gray - black)", page 4 of the AMK catalog.
Re: Tri-Castle Nuts [Re: cbusters] #2448387
02/08/18 10:24 AM
02/08/18 10:24 AM
cbusters Offline OP
cbusters  Offline OP
Is AMK always on with their coatings? I have only gotten a few things from them in the past.
Re: Tri-Castle Nuts [Re: cbusters] #2448417
02/08/18 11:39 AM
02/08/18 11:39 AM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
I recently installed these AMK nuts on my vehicle and in my opinion the shoulder where you would put the cotter pin through is too high. There was no way a regular cotter pin (like they one they send you) could be used. The hole in the shaft was barely showing. I had to torque a little tighter then spec and use a very thin cotter pin that I luckily had some stock of.
The parts being installed on were Moog with the exception of the pitman arm, which was original. The pitman arm was the worst with fit.
Re: Tri-Castle Nuts [Re: njmopar] #2448419
02/08/18 11:46 AM
02/08/18 11:46 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Why wouldn't it have worked if the base of the nut was made a little thinner? shruggy
Re: Tri-Castle Nuts [Re: njmopar] #2448448
02/08/18 12:41 PM
02/08/18 12:41 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Remember that this was on an assembly line where they did it as fast as they could. Torque with an air gun, and if the hole didn't line up, keep going till it did.
Re: Tri-Castle Nuts [Re: 71birdJ68] #2448478
02/08/18 01:31 PM
02/08/18 01:31 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
The new tri castle nuts are too tall. You either need to get originals or take a die grinder to the repops.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Tri-Castle Nuts [Re: 71birdJ68] #2448480
02/08/18 01:33 PM
02/08/18 01:33 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
OEMs shoulder was not as thick.
NS1AAR
Re: Tri-Castle Nuts [Re: cbusters] #2448667
02/08/18 08:02 PM
02/08/18 08:02 PM
cbusters Offline OP
cbusters  Offline OP
Lucky that I already have the nuts, I just need the coating information.
Re: Tri-Castle Nuts [Re: cbusters] #2449386
02/10/18 02:28 AM
02/10/18 02:28 AM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
I was going to say, can't you just grind down the bottom part of the castle nut giving you the clearance you'd need for getting the cotter pin through?
inherited a 69 roadrunner from my grand pop.
Re: Tri-Castle Nuts [Re: fuelishnsilly] #2449440
02/10/18 11:28 AM
02/10/18 11:28 AM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
Yes, but then you risk removing the coating and mess with the bevel shown in the photo. If I didn't have the thinner cotter pins, would have had to grind.
Re: Tri-Castle Nuts [Re: cbusters] #2449753
02/10/18 09:02 PM
02/10/18 09:02 PM
Greenwood Lake, NY
Greenwood Lake, NY
True, but at least that coating would be the bottom side of the nut and could be touched up with paint or even have RPM put on it to prevent rusting.
Re: Tri-Castle Nuts [Re: cbusters] #2450111
02/11/18 03:32 PM
02/11/18 03:32 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Re: Tri-Castle Nuts [Re: cbusters] #2450408
02/11/18 11:49 PM
02/11/18 11:49 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
When I installed aftermarket tie rod ends (moog) the ball stud was just a hair shorter than the oem and the hole was drilled lower in the stud compared to an oem tie rod. Could not get the cotter pin in with original nuts or reproduction amk’s. The moog nuts obviously fit fine but we’re not tri-castle.
Re: Tri-Castle Nuts [Re: 340cpe] #2450477
02/12/18 02:14 AM
02/12/18 02:14 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
File out 3 of the 6 towers
NS1AAR
Re: Tri-Castle Nuts [Re: ns1aar] #2451660
02/14/18 02:08 PM
02/14/18 02:08 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Not to hijack the original posters thread, but what are these castle nuts worth anyway?
I have never thrown anything on the ground, and left it there, when picking suspension parts, off cars since they invented U Pull It wrecking yards, around here, back in the early 1980's.
I probably have a storage container with about 30 pounds of castle nuts in it, and probably handfull's of those original 3 tower ones.
Think i should start selling them, to all the guys that are anal freaks for original castle nuts?
I remember when NS1AAR got a handfull of them from me, as we have known one another, for decades.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Tri-Castle Nuts [Re: cbusters] #2451923
02/15/18 12:03 AM
02/15/18 12:03 AM
cbusters Offline OP
cbusters  Offline OP
Don't know if it is an anal freak thing, but it is one of those little things that get overlooked and they are kind of obvious when wrong. I have extras from past cars but they are not impossible to duplicate. If you look at them the have just had a mill take a pass and remove three of the points. The repop is just not quite right. It may be a GM or Ford part that the depth is wrong on. I imagine if you had a supply of them and had them plated correctly they would be easy to sell. Not having them would be like say a perfect breast enhancement and someone left off the nipple.
Re: Tri-Castle Nuts [Re: cbusters] #2453399
02/18/18 12:00 PM
02/18/18 12:00 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
...but you have to leave off 3 nipples to make a new replacement part look like an original
drumhit
Re: Tri-Castle Nuts [Re: cbusters] #2453599
02/18/18 07:42 PM
02/18/18 07:42 PM
cbusters Offline OP
cbusters  Offline OP
Three nipples on and three nipples off. Now modern looks vintage.
Re: Tri-Castle Nuts [Re: hemi71x] #2453774
02/19/18 02:57 AM
02/19/18 02:57 AM
Cut and Shoot, TX
Cut and Shoot, TX
You helped me out with a 9/16 "hex tri-slot nut" once upon a time. Thanks again!
Keep in mind that there are 7/16, 1/2 and 9/16 sizes, but only the 1/2" is reproduced AFAIK. You could command the entire intergalactic market for the other 2 sizes...
