Re: Battery in the trunk, photo's?
[Re: justinp61]
#2448312
02/08/18 01:49 AM
02/08/18 01:49 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
1-ga positive all the way forward. 1-ga negative through the floor & bolted to the frame. Then 4-ga from that same point forward to the block, with a strap from that bolt back to the firewall stock location. Charge wire from the alternator is IIRC 10 ga routed to the switched side of the battery cutoff. Switch is a summit 250 amp.
[Re: justinp61]
#2448446
02/08/18 12:39 PM
02/08/18 12:39 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Move it close to the quarter and then pretend you have to change it just to make sure its not to hard. I have a fastback barracuda with a small trunk. I have to take the battery and box out together to change the battery, its a real PITA! I wish I would have run that scenario through before I made it permanent.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2448461
02/08/18 01:01 PM
02/08/18 01:01 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Move it close to the quarter and then pretend you have to change it just to make sure its not to hard. I have a fastback barracuda with a small trunk. I have to take the battery and box out together to change the battery, its a real PITA! I wish I would have run that scenario through before I made it permanent. This is something I hadn't considered, my box will be here this afternoon so I'll check it out. Thanks.
[Re: Jeremiah]
#2448466
02/08/18 01:07 PM
02/08/18 01:07 PM
Bad340fish
Tulsa OK
My '66 Charger is the same way. I used some 1" angle like Doug and a lap belt from a 68 Plymouth. The aluminum box '67 has is nice and looks to be three pieces.
On the subject of batteries internally collapsing - has anyone had to heard of this happening in the last 10 years? I had a friend have one act up on him due to this. It worked intermittently, sometimes it would start, sometimes it wouldn't. I don't think its a common problem but its worth consideration when you set the car up. This only applies to a conventional lead acid battery. It doesn't matter for any kind of AGM product like Optima or Odyssey etc.
[Re: Bad340fish]
#2449110
02/09/18 02:49 PM
02/09/18 02:49 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
Not much room in an E-body for all of this.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: justinp61]
#2450046
02/11/18 02:02 PM
02/11/18 02:02 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
A lot of guys have some type of mount attached to the frame and the battery attaches to the mount. Needs to be 3/8 hardware.
A couple of other things I might suggest are
A) Use Quality crimp terminals, a lot of the kits have cheap small lugs that don't have much surface area for a good connection. Industial wiring lugs are available with 2 bolt holes that can make a much better ground connection
B) Use good cable that is oil/high temp rated (some welding cable is not) type SGT (PVC) or better SGX (cross linked poly) Or spec cable. If it strips easy it nicks easy
C) A little high heat insulation sleeve can really save grief when routing cable by headers or hot sharp stuff
"Just a Bracket car dressed up like a streetcar"
[Re: crackedback]
#2450173
02/11/18 05:35 PM
02/11/18 05:35 PM
Just-a-dart
Glendora Ca.
Sorry Crackedback. I should have said some welding cable not most.
I have seen cheap welding cable with soft rubber insulation used many times. Then the insulation can expand to 2 or 3 times it's original size when soaked with oil and becomes a soft gooey mess that is a delite to work with.
[Re: Just-a-dart]
#2450292
02/11/18 09:27 PM
02/11/18 09:27 PM
Posts: 9,863 MI, usa
dvw
MI, usa
I have seen cheap welding cable with soft rubber insulation used many times. Then the insulation can expand to 2 or 3 times it's original size when soaked with oil and becomes a soft gooey mess that is a delite to work with. That's an easy fix. No leaks, done. Doug
