Battery in the trunk, photo's? #2448304
02/08/18 01:31 AM
02/08/18 01:31 AM
W. Kentucky
justinp61 Offline OP
W. Kentucky
Most of the stuff to relocate the battery to the trunk in my Dart will arrive tomorrow and I'm curious to see where exactly you guys mounted yours. IIRC the NHRA rules state that it has to be bolted down through the frame, if that's the case it's going to move the battery way out in the trunk. I'd prefer to mount it as close to the fender as I can get it.
Anyone have any photo's they would share?
Re: Battery in the trunk, photo's? [Re: justinp61] #2448312
02/08/18 01:49 AM
02/08/18 01:49 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
1-ga positive all the way forward. 1-ga negative through the floor & bolted to the frame. Then 4-ga from that same point forward to the block, with a strap from that bolt back to the firewall stock location.
Charge wire from the alternator is IIRC 10 ga routed to the switched side of the battery cutoff. Switch is a summit 250 amp.
Re: Battery in the trunk, photo's? [Re: StealthWedge67] #2448330
02/08/18 02:38 AM
02/08/18 02:38 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Not the best,,but
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Battery in the trunk, photo's? [Re: hemi-itis] #2448351
02/08/18 04:45 AM
02/08/18 04:45 AM
I've mounted a bunch of battery the same way as hemitis is, if your using a older lead acid type battery make sure and mount is sideways so the G forces don't break the plates off inside up
Re: Battery in the trunk, photo's? [Re: justinp61] #2448368
02/08/18 08:19 AM
02/08/18 08:19 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have 2. Frame is fabbed fro 1" steel angle. Inner and front bolts go through the outer frame flange. Outer bolts are plated under the floor. 6 bolts hold the battery frame work. Bottom is spaced up with 1/2" tubing for the mounting bolts to keep it level. Fuel pump mount is integral as well.
Doug
Re: Battery in the trunk, photo's? [Re: justinp61] #2448437
02/08/18 12:17 PM
02/08/18 12:17 PM
W. Kentucky
W. Kentucky
Thanks for the photo's guys, I'll mount it as close to the quarter as I can. DVW your car is insanely clean, show off! lol up
Re: Battery in the trunk, photo's? [Re: justinp61] #2448446
02/08/18 12:39 PM
02/08/18 12:39 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Move it close to the quarter and then pretend you have to change it just to make sure its not to hard. I have a fastback barracuda with a small trunk. I have to take the battery and box out together to change the battery, its a real PITA! I wish I would have run that scenario through before I made it permanent.
68 Barracuda Formula S 340
Re: Battery in the trunk, photo's? [Re: Bad340fish] #2448458
02/08/18 12:51 PM
02/08/18 12:51 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
My '66 Charger is the same way. I used some 1" angle like Doug and a lap belt from a 68 Plymouth. The aluminum box '67 has is nice and looks to be three pieces.
On the subject of batteries internally collapsing - has anyone had to heard of this happening in the last 10 years?
Re: Battery in the trunk, photo's? [Re: Bad340fish] #2448461
02/08/18 01:01 PM
02/08/18 01:01 PM
W. Kentucky
W. Kentucky
This is something I hadn't considered, my box will be here this afternoon so I'll check it out. Thanks.
Re: Battery in the trunk, photo's? [Re: Jeremiah] #2448466
02/08/18 01:07 PM
02/08/18 01:07 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I had a friend have one act up on him due to this. It worked intermittently, sometimes it would start, sometimes it wouldn't. I don't think its a common problem but its worth consideration when you set the car up. This only applies to a conventional lead acid battery. It doesn't matter for any kind of AGM product like Optima or Odyssey etc.
Re: Battery in the trunk, photo's? [Re: Bad340fish] #2449110
02/09/18 02:49 PM
02/09/18 02:49 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Not much room in an E-body for all of this.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Battery in the trunk, photo's? [Re: justinp61] #2449907
02/11/18 01:45 AM
02/11/18 01:45 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I put mine in a marine case because since its a street car I put many things in my trunk. Including my jacket and clothes sometimes so I don't want any acid to get on anything in my trunk. Ron
Re: Battery in the trunk, photo's? [Re: justinp61] #2449988
02/11/18 11:40 AM
02/11/18 11:40 AM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
https://static.wixstatic.com/media/008a74_720378def1a641ed80e73bf0450982d9.jpg/v1/fill/w_750,h_563,al_c,q_85,usm_0.66_1.00_0.01/008a74_720378def1a641ed80e73bf0450982d9.webp
Re: Battery in the trunk, photo's? [Re: justinp61] #2450046
02/11/18 02:02 PM
02/11/18 02:02 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
A lot of guys have some type of mount attached to the frame and the battery attaches to the mount. Needs to be 3/8 hardware.
A couple of other things I might suggest are
A) Use Quality crimp terminals, a lot of the kits have cheap small lugs that don't have much surface area for a good connection. Industial wiring lugs are available with 2 bolt holes that can make a much better ground connection
B) Use good cable that is oil/high temp rated (some welding cable is not) type SGT (PVC) or better SGX (cross linked poly) Or spec cable. If it strips easy it nicks easy
C) A little high heat insulation sleeve can really save grief when routing cable by headers or hot sharp stuff
"Just a Bracket car dressed up like a streetcar"
Re: Battery in the trunk, photo's? [Re: justinp61] #2450142
02/11/18 04:30 PM
02/11/18 04:30 PM
CA
crackedback Online content
crackedback  Online Content
CA
EPDM jacketed welding cable is oil resistant and has the same heat rating as SGT wire. SGX has a higher rating at 125C compared to 105C for the sgt and most welding. I have seen one EPDM jacketed cable that was rated at 140C
There is cable that is sae J1127 rated 105C that is welding cable with an EPDM jacket. My guess, it's the same stuff as the non SAE rated wire, just with the SAE number on it. Same specs throughout. Wouldn't surprise me if the jacket between the two had no molecular composition changes. The 140C cable must have something different for jacketing.
Yes on something like TechFlex jacket when it passes near headers. Heat hurt load carrying capability of wire. That goes for any of the wires headed to a starter that is essentially captured by headers.
Re: Battery in the trunk, photo's? [Re: crackedback] #2450173
02/11/18 05:35 PM
02/11/18 05:35 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Sorry Crackedback. I should have said some welding cable not most.
I have seen cheap welding cable with soft rubber insulation used many times. Then the insulation can expand to 2 or 3 times it's original size when soaked with oil and becomes a soft gooey mess that is a delite to work with.
Re: Battery in the trunk, photo's? [Re: justinp61] #2450213
02/11/18 06:57 PM
02/11/18 06:57 PM
CA
CA
Agreed. All good.
The EPDM is the one to use. Nitrile rubber jacketed stuff doesn't play nice with oils, fuel, etc.
Re: Battery in the trunk, photo's? [Re: Just-a-dart] #2450292
02/11/18 09:27 PM
02/11/18 09:27 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
That's an easy fix. No leaks, done.
Doug
Re: Battery in the trunk, photo's? [Re: justinp61] #2450870
02/12/18 09:01 PM
02/12/18 09:01 PM
W. Kentucky
W. Kentucky
I'm going to route the rod for the master kill switch through the tail light lens/housing. Can I drill the lens or will need to use a rotary file in a die grinder? Some plastics don't drill well and I don't want to ruin my lens.
Re: Battery in the trunk, photo's? [Re: justinp61] #2450914
02/12/18 10:08 PM
02/12/18 10:08 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
