Leaf spring bracket 78 Aspen #2447942
02/07/18 12:02 PM
02/07/18 12:02 PM
Hamilton,Ohio
P
POZEST Offline OP
POZEST  Offline OP
P
Hamilton,Ohio
Looking for the metal u shaped piece that wraps around the bottom of the leaf spring ona stock 78 Dodge Aspen. This is for the drivers side if that matters. Looking for a nice used one. Not sure where to post this. Thanks. [img]https://brian-hendrickson.smugmug.com/Parts/i-fDvh7mw/A[/img]
"I'm not a Gynecologist, but I'll take a look."
Re: Leaf spring bracket 78 Aspen [Re: POZEST] #2447973
02/07/18 12:52 PM
02/07/18 12:52 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Re: Leaf spring bracket 78 Aspen [Re: POZEST] #2448028
02/07/18 03:05 PM
02/07/18 03:05 PM
CA
crackedback Online content
crackedback  Online Content
CA
Check with Jim at jims az parts.
He takes a bunch of F bodies apart.
http://www.jimsazparts.com/
Re: Leaf spring bracket 78 Aspen [Re: POZEST] #2448283
02/08/18 12:42 AM
02/08/18 12:42 AM
md
md
There are two different sizes. One size for 5 leaf springs and a shorter one for 4 leaf springs. I don`t think Jim has the 5 leaf one.
Re: Leaf spring bracket 78 Aspen [Re: POZEST] #2448698
02/08/18 08:53 PM
02/08/18 08:53 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I'm not sure the brackets are different, I wonder if the rubber bushing that surrounds the leafs are different between the 4 leaf and the 5 leaf.
Or, now that I think about it, I'm not sure the 4 leaf didn't have a short spring or spacer about the same length as the bracket, so Mopar only needed one set of brackets and rubber bushings. Chrysler was going broke at the time, a short piece of 1/4" thick 2" x 6" steel with a hole punched in it would have been pretty cheap. Gene
Re: Leaf spring bracket 78 Aspen [Re: POZEST] #2448834
02/09/18 12:18 AM
02/09/18 12:18 AM
md
md
No two different sizes for sure. The five leaf ones are hard to come by. They were on wagons and HD suspension. I had seen people use the shorter ones with homemade spacers.
Re: Leaf spring bracket 78 Aspen [Re: POZEST] #2449422
02/10/18 07:53 AM
02/10/18 07:53 AM
Europe
rory73 Offline
rory73  Offline
Europe
Correct, these where made by Jim because nobody has new or serviceable brackets for 5-leaf suspension setups:
http://www.aspenandvolare.com/showthread.php?1389-Rear-isolaters
5 leaf 8.25 used a specific deeper U channel. I do not have any of those in stock.
I do have the plate portion the shock attaches to which is also specific to the 8.25 rear.
you can use 3" axle tube leaf spring/shock brackets and U bolts to replace the isolators.
