Re: Stroker kit experience?
[Re: cudadoug]
#2447874
02/07/18 03:31 AM
02/07/18 03:31 AM
Posts: 1,828 houston texas
gremlinsteve
houston texas
I looked it over briefly It really doesn't look that bad I built many many engines using the mahle pistons. They seem to Hold up fine I have broken one stroker crank. But it was never determined why It broke
if You Like Gremlinsteve. Gremlinsteve Likes You.
[Re: cudadoug]
#2447875
02/07/18 03:33 AM
02/07/18 03:33 AM
gremlinsteve
houston texas
I did just use one of there kits for a sbc build. A 385 stroker For a customer /friend...
I have zero issues with the machine work and there balance work Also Every thing arrived on time and the build had no hiccups
So I would recommend doing business with them
[Re: cudadoug]
#2448139
02/07/18 06:44 PM
02/07/18 06:44 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I would rather spend a few hundred $ more and get a kit that needs a few hundred $ less correcting. I have seen really crappy machine work on all the eagle stuff I ever messed with, maybe they are better now? I won't waste another $ on em till I am convinced they have turned the ship around. SCAT tends to be similar price and much better out of the box machine work (not that you shouldn't check it either but its a lot better than eagle).
[Re: HotRodDave]
#2469990
03/21/18 09:03 PM
03/21/18 09:03 PM
Posts: 2,042 MD
RTSE4ME
MD
SCAT tends to be similar price and much better out of the box machine work (not that you shouldn't check it either but its a lot better than eagle). I have been shopping for a stroker kit and went on Scat's website and found a spreadsheet with their G3 kits. Summit carries their kits and the price isn't too bad. Comes with their I beam rods and Icon pistons. https://www.summitracing.com/parts/sca-1-48508
[Re: cudadoug]
#2470026
03/21/18 09:54 PM
03/21/18 09:54 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I saw on clegg engine they sell scat kits, unbalanced and balanced. Says I-beams and Icon pistons. The balanced price is around summits unbalanced kits.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: cudadoug]
#2470206
03/22/18 03:16 AM
03/22/18 03:16 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I went with Manley from Barton.
Mopar to the bone!!!
