2806301 383 intake...worth upgrading? #244751
03/06/09 03:29 AM
03/06/09 03:29 AM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
I have a 1969 383 with 10:1 CR, 452 heads, and a 600CFM carb. The bigger summit cam and headers.
Not counting weight..is there any performance to be had with going to a Ebrock RPM or other after market intake? From what i read the stock intake isnt all that bad.
thanks.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: 2806301 383 intake...worth upgrading? [Re: CrAlt] #244752
03/06/09 03:43 AM
03/06/09 03:43 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Definately worth an upgrad to the performer RPM, plus a larger CFM carb. Do you have hood clearance for it?
Re: 2806301 383 intake...worth upgrading? [Re: NANKET] #244753
03/06/09 03:55 AM
03/06/09 03:55 AM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
Its a '69 B-body... stock hood
Re: 2806301 383 intake...worth upgrading? [Re: CrAlt] #244754
03/06/09 09:27 AM
03/06/09 09:27 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thanks.
Really , where did you read that ??? If you look at the dyno test fast68plymouth did on his 383 the stock intake leaves about 40HP on the table vs. the RPM , no other changes .
Re: 2806301 383 intake...worth upgrading? [Re: JohnRR] #244755
03/06/09 10:31 AM
03/06/09 10:31 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I dont think the stock 4 barrel intakes are too great, maybe theyre decent in comparison to an old school Offy or a crappy Weiand or something, but the RPM is a far better intake. Its been proven on the dyno and at the track. Even on a stock 383 I'd bet its worth 20 horse.
Re: 2806301 383 intake...worth upgrading? [Re: CrAlt] #244756
03/06/09 10:48 AM
03/06/09 10:48 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
thanks.
Just depends on your intentions.
Re: 2806301 383 intake...worth upgrading? [Re: JohnRR] #244757
03/06/09 12:36 PM
03/06/09 12:36 PM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
Anyone have a link to that study?
Re: 2806301 383 intake...worth upgrading? [Re: CrAlt] #244758
03/06/09 12:43 PM
03/06/09 12:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's in the tech archive ...
This is the best I could find , alot got lost on the cutting room floor . I remember 40-50 HP with the intake change but that may have also been with the carb change to the carter 750 because I would have run that exact combo on my motor most of the time ??? , but the chart here is showing almost 26 ??? I read thru this real quick and didn't see that actual test and what Dwayne had to say .
383 dyno results
Re: 2806301 383 intake...worth upgrading? [Re: JohnRR] #244759
03/06/09 01:25 PM
03/06/09 01:25 PM
USA
CrAlt Offline OP
CrAlt  Offline OP
USA
383 dyno results
Thanks john.
I read that but it looks like they cut out the intake comparisons and focused on the carbs.
im reluctant to buy stuff that wont swap over to my 440..i guess ill just keep a eye out for a used RPM.
Re: 2806301 383 intake...worth upgrading? [Re: CrAlt] #244760
03/06/09 01:55 PM
03/06/09 01:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
383 dyno results
Thanks john.
I'm guessing now after reading it all it was the intake carb combo that gained the HP I remember . The big thing is his cam and headers do also make a difference in the grand scheme of things . I have an RPM in my pile o'intakes for a low deck , hopefully I get it on a running engine this year
Re: 2806301 383 intake...worth upgrading? [Re: CrAlt] #244761
03/06/09 06:51 PM
03/06/09 06:51 PM
Cincinnati area
sch1966 Offline
sch1966  Offline
Cincinnati area
Is there one stock intake that is better than the others? Or are there any tricks that can be done to improve stock unit?
Re: 2806301 383 intake...worth upgrading? [Re: sch1966] #244762
03/07/09 04:54 PM
03/07/09 04:54 PM
dogdays Offline
dogdays  Offline
why bother? unless you are going for numbers-matching. Pick up that cast iron manifold, it is heavy. Save maybe 40 lb high over the front wheels with an aluminum intake, makes for a better handling car.
R.
Re: 2806301 383 intake...worth upgrading? [Re: dogdays] #244763
03/07/09 05:50 PM
03/07/09 05:50 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Stock intake weighs about 40 lbs. aluminum will be about 15 lbs. dp4b will work pretty decent if you dont have room for a perf rpm.
Re: 2806301 383 intake...worth upgrading? [Re: dogdays] #244764
03/08/09 09:56 PM
03/08/09 09:56 PM
Cincinnati area
sch1966 Offline
sch1966  Offline
Cincinnati area
I realize the benefits of an aluminum manifold but I am looking for creativity with what Ma Mopar gave us. I'm curious about how much port matching would help, also what difference would it make to mill down the plenum dividers? Are there other "tricks" such as air dams that would make a difference? I'm the type of person that likes to optimize what I have before moving on.
Re: 2806301 383 intake...worth upgrading? [Re: sch1966] #244765
03/09/09 09:48 AM
03/09/09 09:48 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
port matching won't do much , I had an intake wit hthe plenum divider removed , nenver tryed but it was down to knock down bottom end torque , I'm doing another one , I'll be dynoing it to see what gain it does or does not give , but don't hold your breath waiting on the results .
Re: 2806301 383 intake...worth upgrading? [Re: JohnRR] #244766
03/09/09 07:21 PM
03/09/09 07:21 PM
MO
cdp Offline
cdp  Offline
MO
High Performance Mopar magazine did an article on this in their 65 Coronet 500 that they had a 383 magnum motor in. I think they had a stock intake and manifolds, then extrude honed them and got about 5HP. Then went to an Eldebrock and got huge gains. Something like high 13's with a stock magnum exhaust system (compared to mid-low 14's)
I'm sure the Dp4b and the Weiand 8008 are better choices and look stock. The 8008 has a stock coil location, where the DP4B is righ in front of the carb. Which is in the way for my stock 70 Holley.
Maybe a 72 T-quad would be a better improvement?
Re: 2806301 383 intake...worth upgrading? [Re: JohnRR] #244767
04/17/10 11:31 PM
04/17/10 11:31 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
383 dyno results
Hughes Engines does studies on the various Mopar
SB and BB intakes, usually to improve on the
flow characteristics. They seem to be on the right
track with the Eddy RPM for the 383.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: 2806301 383 intake...worth upgrading? [Re: cdp] #244768
04/17/10 11:43 PM
04/17/10 11:43 PM
Desert Tracker
Desert Tracker
Could be. the TQ offers a bit more torque in the
lower rpm's as well as better fuel atomization/
fuel efficiency. The key is the multi-venturi
primary barrels. The carb can also be made to scream too, since they are legal for the Super
Stock/Stock Eliminator classes. A TQ Strip Kit,
some time + some patience = fast fun/good times
Re: 2806301 383 intake...worth upgrading? [Re: NANKET] #244769
04/18/10 12:13 PM
04/18/10 12:13 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
on B blocks the hood clearence is less critical than on RB blocks
A friend of mine is running a RPM intake over a 400 with stock flat hood on a 73 Charger... non clearence problem. And is using a spacer.
Re: 2806301 383 intake...worth upgrading? [Re: cdp] #244770
04/25/10 10:00 PM
04/25/10 10:00 PM
Desert Tracker
Desert Tracker
Try the one off of the 72 400 Magnum (approx. 800
cfm)and jet it appropriately. Air door adjustment is a big help.
