6-Pack Rods on 1969??? #2447132
02/05/18 10:56 PM
02/05/18 10:56 PM
Holly/MI
Dean_Kuzluzski Offline OP
Holly/MI
Did the 1969 A-12 6-pack cars have the 6-Pack rods? Or they came out in 70?
Re: 6-Pack Rods on 1969??? [Re: Dean_Kuzluzski] #2447146
02/05/18 11:10 PM
02/05/18 11:10 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Originally Posted By Dean_Kuzluzski
they came out in 70
Re: 6-Pack Rods on 1969??? [Re: Dean_Kuzluzski] #2447190
02/06/18 12:25 AM
02/06/18 12:25 AM
Chicago
PurpleBeeper Offline
Chicago
From what I understand the 69 440 six packs have the smaller LY rods, just like rs23u1g says. I believe the larger "6-pack" rods came on 70-71 six pack AND 70-73 HP 4bbl. 440's
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 6-Pack Rods on 1969??? [Re: Dean_Kuzluzski] #2447244
02/06/18 02:05 AM
02/06/18 02:05 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
The 69 A12’s came with LY Rods. (The A12’s also had standard 440 nylon cam timing gears in case you were wondering). You can use the heavier 70 sixpack rods but you have to add a lot of weight to balance the crank and reciprocating mass. The LY rods are fine unless you are building a monster motor. You would be better off buying lighter and stronger aftermarket rods than going with the heavier 70 rods.
Re: 6-Pack Rods on 1969??? [Re: RoadRunnerJD] #2447443
02/06/18 04:32 PM
02/06/18 04:32 PM
Chicago
Chicago
You know, I've had "big rod" & "small rod" cranks side by side & they sure look the same. I "thought" all the extra weight for balancing the big rods was in the harmonic balancer + flywheel/torque converter???
Re: 6-Pack Rods on 1969??? [Re: PurpleBeeper] #2447670
02/06/18 09:54 PM
02/06/18 09:54 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It is. The big rod motors are "externally" balanced
Re: 6-Pack Rods on 1969??? [Re: Dean_Kuzluzski] #2447784
02/07/18 12:11 AM
02/07/18 12:11 AM
Warrenton, VA
Warrenton, VA
If you are working on a 1969 A12, I assume you would not want to externally balance it.
Re: 6-Pack Rods on 1969??? [Re: RoadRunnerJD] #2447905
02/07/18 09:20 AM
02/07/18 09:20 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
How does one explain the 440 motor home engines that have the big rods (6 pack?) and a normal small steel crank type balancer? I have at least 2 of them. shruggy
Yeah, it's hopped up to over 160...
Re: 6-Pack Rods on 1969??? [Re: jt4406] #2447924
02/07/18 11:13 AM
02/07/18 11:13 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
http://www.440source.com/dampers.htm
Re: 6-Pack Rods on 1969??? [Re: 6PakBee] #2447938
02/07/18 11:45 AM
02/07/18 11:45 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
OK, thanks for the link, lots of good info there up
But, if I understand it correctly, it states:
3614371, used on forged crank engines from 1972-75. Appearance and dimensions are the same as above, the only difference is the pulley bolt pattern in the 72 and later, which is symmetrical. These continued to be used as part 3830183 for 1976-79. Another important fact is that even though six pack rods continued to be used up until 1975 in HP and truck 440's with steel cranks, they did NOT use this damper (#3512017, commonly known as a "six-pack" damper). any 73-75 steel crank 440 (with either six pack or standard rods) would have come with the 3614371 damper. We have found this to be absolutely true.
So, I still don't understand, UNLESS maybe the reduced weight of the pistons ( due to a shorter distance from pin cl to top to reduce compression ?) offset the weight of the rod? shruggy
jess
Re: 6-Pack Rods on 1969??? [Re: Dean_Kuzluzski] #2448063
02/07/18 04:18 PM
02/07/18 04:18 PM
Chicago
Chicago
WOW!....JT & 6pack this is new information for me. What I'm getting from all this is confusing me.
1. I have a '73 big-rod motor in my car right now with modified TRW pistons.
a. I remember buying the short block without a balancer
b. I bought a balancer WITH the offset weight and put it on this motor
c. I recall "something" about crank pulley bolt holes not lining up
d. I balanced the motor, so regardless I should be OK
e. My engine is a hodge-podge of various years....so who knows what any of this means.
2. I don't know squat about balancer part numbers, just weight, no weight and thick cast crank (with weight)
3. I wish I had a little bit more info from "above" in JT's quote.
4. If I'm interpreting this correctly (?) then...
a. 3614371 (72-75) + 3830183 (76-79, likely truck/industrial) balancers are symmetrical (no weight) and are for internally balanced, forged crank engines.
b. 3512017 "six pack" dampener must have only been used in '70-'71 big rod 440's (either 6-pack or 4bbl. HD)
c. 3614371 (73-75 HD) steel crank/truck with big OR small rods must be symmetrical (no weight) and:
c1) This pistons must be so much lighter vs. the older pistons that you achieve "balance" without the dampener weight (? -this doesn't make sense)
c2)big rod vs. small rod 73-75 HD 440's got VERY different pistons so the big rod motors had much lighter pistons (total piston + rod weight = same for big rod & small rod)
c3) MORE LIKELY - the torque converters must have more weight on them for big rod motors in 73-75 (or flywheels? - did they make big-rod '73 440 4spd's?)
This hurts my head.... what am I missing?
Re: 6-Pack Rods on 1969??? [Re: PurpleBeeper] #2448105
02/07/18 05:40 PM
02/07/18 05:40 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
WOW!
For a definitive answer, forward this manifesto to Bob K...
AKA 'Mr. SixPack'...
Re: 6-Pack Rods on 1969??? [Re: jt4406] #2448133
02/07/18 06:34 PM
02/07/18 06:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Bingo.
Re: 6-Pack Rods on 1969??? [Re: John_Kunkel] #2448383
02/08/18 10:04 AM
02/08/18 10:04 AM
FL
moparwizard Offline
moparwizard  Offline
FL
73-up 440s with big rods have a large notch cut out of one crank throws to achieve balance.
Re: 6-Pack Rods on 1969??? [Re: moparwizard] #2449258
02/09/18 09:33 PM
02/09/18 09:33 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
I cannot argue with this.....comparison pics?
Re: 6-Pack Rods on 1969??? [Re: jt4406] #2449468
02/10/18 12:36 PM
02/10/18 12:36 PM
Chicago
Chicago
You know, I do seem to recall a big notch out of the one of the crank throws on my 73 big rod motor. So I didn't need to buy that offset weight balancer after all, huh? I just had the oil pan off, but unfortunately I didn't take any pictures frown
Re: 6-Pack Rods on 1969??? [Re: Dean_Kuzluzski] #2449679
02/10/18 06:50 PM
02/10/18 06:50 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I've used the heavy rods and .030 over TRW replacement slugs without the offset balancer numerous times...The machine shop didn't have any issues balancing the assembly and there's never been any harmonic vibrations... twocents
