Page 3 of 6 1 2 3 4 5 6
Re: 72 duster [Re: RustyM] #2445503
02/03/18 04:28 AM
02/03/18 04:28 AM
[quote=RustyM]Ok- mini tub set up/ spring move allows me a 15x10 with 3.5 backspace.
Tire size recommendations as well as Rim.
Weld’s are pretty normal of course.
Lot of rim companies out there but /quote]
As far as rim width and tire to use is your rear end a stock width A body 8 3/4?
On moving and stretching the wheel wells I cut up three other junk Dusters rear 1/4 panels to use in having mine widen, the darn multiple angles on the rear 1/4 panel sheet metal makes it harder to make it look factory than the other Mopars I have had done whiney
Re: 72 duster [Re: RustyM] #2445578
02/03/18 12:27 PM
02/03/18 12:27 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
Wholly cow - that's an impressive build schedule! green
Check out this thread for some pictures of stretching the rear wheel wells:
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2399290/1.html
Re: 72 duster [Re: humpty] #2445684
02/03/18 04:03 PM
02/03/18 04:03 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
no connection to the pics guys- I think they must time out or something- never can pull up older pics.
Re: 72 duster [Re: Cab_Burge] #2445690
02/03/18 04:12 PM
02/03/18 04:12 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Cab: 50 wide, wheel flange to wheel flange .
Re: 72 duster [Re: RustyM] #2445706
02/03/18 04:45 PM
02/03/18 04:45 PM
I had my B body 8 3/4 narrowed one inch less than the stock A body where which is what your using, I think confused I used Welds that had one inch negative, one inch less offset on the inside than the width of the wheels, 10 inch wide with 4.0 inch inset on the inside, 5 inch on the 12 inch wide rims up Maybe they where 4.5 and 5.5 confused
Re: 72 duster [Re: RustyM] #2446025
02/04/18 02:07 AM
02/04/18 02:07 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
RustyM - you have a PM.
Re: 72 duster [Re: humpty] #2446574
02/04/18 11:28 PM
02/04/18 11:28 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Thank you!
Studying the pics now.
Nice work!
Re: 72 duster [Re: RustyM] #2446582
02/04/18 11:40 PM
02/04/18 11:40 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
As we are going to run Andy’s motor plate and only have a bit over 650 hp , was thinking about using an electric water pump since car will really only see strip time.
Suggestions that don’t break the budget but are reliable/ functional?
Best place to get alternators for the motor plate ?
I see the powermastwrs / Denso’s in a range of prices- some too low to be correct and some to high to buy- grin.
Frame shop tomorrow to make sure the old girl is straight before we start welding steel in.
4 cornered car yesterday and weights/ distro looked good empty so- if she’s bent / torqued , it’s not much at all.
Parts start piling in tomorrow .
One just plain dumb mistake: Ordered wrong slicks !!!
Looked at so many/ so much data on my sheet I ordered the wrong pair.
I snapped later that night and rushed to look at my order - yep, wrong section width and rollout.
Too late- already shipped.
Ordered correct ones and got an RA for the wrong ones- sheesh!!
Haste makes waste and over thinking things makes me plumb stooopid!
Grin
Re: 72 duster [Re: RustyM] #2446606
02/05/18 12:45 AM
02/05/18 12:45 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
[quote=RustyM]As we are going to run Andy’s motor plate and only have a bit over 650 hp , was thinking about using an electric water pump since car will really only see strip time.
I would use a remote pump like a Meziere, to free up space on the front of the motor.
"Just a Bracket car dressed up like a streetcar"
Re: 72 duster [Re: RustyM] #2446655
02/05/18 02:04 AM
02/05/18 02:04 AM
I used one of Andy AR Engr. alternator mounting kits with a 100 amp Powermaster single wire alternator on my tube chassis Cuda with a stock single groove early 440 pulley up
Re: 72 duster [Re: RustyM] #2446875
02/05/18 03:09 PM
02/05/18 03:09 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
"Anyone know exactly where to cut, or, take a pie cut out of the front of the rear quarters at the front of rear wheel wells for slick clearance ?
I think I know where I want to make the cut but would like to confirm.
It’s just really tight on the front side of the tire on the lowest side of the wheelwell.
I know I have seen pics, read an article but danged if I can find either."
I just followed the wheel well body line straight off to make the wedge or pie cuts.
Re: 72 duster [Re: Biginchmopar] #2446880
02/05/18 03:17 PM
02/05/18 03:17 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
How much tire is that?
Re: 72 duster [Re: Biginchmopar] #2446885
02/05/18 03:21 PM
02/05/18 03:21 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
She’s beautiful !
Re: 72 duster [Re: RustyM] #2446887
02/05/18 03:26 PM
02/05/18 03:26 PM
Carson City, Nevada
Carson City, Nevada
32.5 x 16
Re: 72 duster [Re: RustyM] #2446900
02/05/18 03:44 PM
02/05/18 03:44 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Wheel openings: to my eye, the trick is to make them look unaltered and related so to speak to the front openings.
My old SS Duster and the current project both retain the upper flared contour, but are cut starting about 2-3" below the center body line. Bottom of cut is to/flush ft of the tub. The racecar is also cut at the rear, and with minitubs & 3" relocation, 13x31s on 15x12 4BS fits fine, 14x32s would be a bit tight. Narrowed D60.
Project is cut almost the same in front, none at rear, measures like it should just accept a 295/65R15 on a 15x10 (ideally 5.0BS) with stock tubs & 3/4" relocation. Stock 8.75.
Both have upper lip rolled up, excess flange cut - take a good look at that area - racecar being thinner than project because I didn't want to cut the wheelhouse itself. Its flange is about 1/2" because of the stock wheelhouse contour. Racecar eliminated that and filler welded in.
Contours at front/inside of tub are another interference point at around 31/32" tire.
Pie-slice allows retaining the stock flange, a tight cut affect clearance only about 3/16".
Re: 72 duster [Re: RustyM] #2449706
02/10/18 07:43 PM
02/10/18 07:43 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Got the ole girl back from the frame shop.
She looked/measured pretty good here, just a little different door gab from right to left side.
Sure enough- get it on the frame table and- bam! There it is- twisted across from section from left to right, high on left, low on right and- just a tiny tad low on left rear corner.
All fixed up now- likely better than factory but- who knows.
main thing for us- we know she is plumb/square in all planes.
When i got there to pick her he still had instruments on her so i got to see where she was.
Door gaps good now side to side, front to rear.
Needless to say one can see clean old paint at fender bolt locations from re-setting fenders, grin, that old yellow wasn't so bad when new!- grin
back to building the car now.
Highly recommend having a relationship with a good frame shop- as of this date, never had one truly straight when it got on the table.
just sayin
Re: 72 duster [Re: RustyM] #2449717
02/10/18 07:55 PM
02/10/18 07:55 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
I would like to know a few duster set-ups and what they run at what weight: 1/8, 1/4 , mph in both and 60 ft times.
This would help me greatly in building/setting up the car.
I have been using Wallace calculators for some things but not sure how accurate the data is one gets from these type calculators because we don't have air temps/dew points /drag coefficiants etc.
Open to advice as usual and any data folks are willing to share is greatly appreciated.
thanks,
rusty
Re: 72 duster [Re: RustyM] #2449838
02/10/18 11:03 PM
02/10/18 11:03 PM
My old street car, 1971 Duster, weighed 3450 Lbs. with me in it ready to race with full 3.0 inch exhaust to the rear bumper and air cleaner on. Ladder bars with double adjustable coil overs and a diagonal link,
M/T ET Street Radials 315x60x15 mounted on 10 inch wide Weld Pro rims. Stock gas tank with a Magnafuel 275 pump with a # 10 AN feed to the pump, #8 AN bypass and #8 AN (1/2 O.D. soft aluminum line to the regulator mounted up front in front of the carb.)
That motor was a 400 block bored to 4.375 and stroke was 4.300, Comp Cams custom ground solid roller 260@.0500 intake side, 266 @.050 exhaust side with Harland Sharp 1.6 ratio rockers that netted .700 + a tiny bit at the retainers on a set of Indy SR Max wedge size intake port heads and a Indy 400- intake and a Holley 1050 CFM Dominator.
It ran a bunch of 10.00 through the exhaust on 91 octane non ethanol Oregon pump swill, the motor made 727 HP the last time it was a decent engine dyno in Klamath Falls ,Oregon at 4300 Ft. in the spring up
Re: 72 duster [Re: RustyM] #2449932
02/11/18 02:57 AM
02/11/18 02:57 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I've had two 72 Dusters - the first was a big tire SS spring, 451ci BB that made 677hp, 590tq, built 727 with Turbo Action Transbrake, 8" Dynamic 5000 converter, 4.10's, spool, slicks, 8 point bar, stock front suspension, 3300lbs with me at the line, 6.65@103 1/8mi, 10.40@128 1/4mi, best 60' was 1.45.
The second is in my sig - 408ci, iron W2's that made 605hp, 540tq, built low gear 904 with A&A Transbrake, 8" PTC 5500 converter, 6 point bar, front coil overs, 4.10's, spool, 275 drag radials, stock location cal tracs with split mono leafs, da AFCO's on all corners, 3160lbs with me at the line, 6.47@107 1/8mi, 10.18@131 1/4mi, best 60' is 1.41.
Cheers
Re: 72 duster [Re: humpty] #2450052
02/11/18 02:07 PM
02/11/18 02:07 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
My back half duster was around 3000 lbs 499 CID with Indy SR head ran 9.80 in 5000 foot air running 100 LL. This is with all pretty standard stuff 727 with griner transbrake and a Lupo converter.
76 Duster work in progress
