Page 2 of 3 1 2 3
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2445734
02/03/18 05:51 PM
02/03/18 05:51 PM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
Yes I have the Super Victor #2891. In fact I bought it from Andy a few years ago. You fellas have made my day. I was thinking that to change heads was a money pit that my better half would squawk about. If I can use my bolt on parts I have then I will have new heads on the way shortly.
If I decide to port the manifold, how far up will I need to go in the runner?
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2445737
02/03/18 05:53 PM
02/03/18 05:53 PM
AndyF Offline
AndyF  Offline
About the only reason to use B1BS heads these days is if you work for the Koffels or Brodix. Other than that I can't think of a single reason why anyone would spend twice the money for something that requires custom headers and special rockers and doesn't make any more power. Koffel and Brodix should just admit it was an evolutionary dead end and move on to better things.
I see the same thing going on in the FE world. Over time, guys have created expensive FE heads that work okay, but now the new Trick Flow head is much less expensive and just as good or better.
Re: Victor or Trickflow heads most bang for the buck? [Re: 451Mopar] #2445772
02/03/18 06:41 PM
02/03/18 06:41 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Originally Posted By 451Mopar
) B1Bs head only flows 295 cfm a
My heads didn't get close to that number. OOTB. Mine were in the 270 range, ootb.
They are respectable after DP worked them. But no way Id buy another set, ever.
They had their place...many moons ago.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Victor or Trickflow heads most bang for the buck? [Re: Von] #2445783
02/03/18 07:00 PM
02/03/18 07:00 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
My good friend has been running 8.60’s-8.80’s for years in his charger so B1BS heads in the right hands work pretty good
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2445806
02/03/18 07:19 PM
02/03/18 07:19 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I think the OP should consider a different cam to go with the new heads, etc.
Re: Victor or Trickflow heads most bang for the buck? [Re: BradH] #2445858
02/03/18 08:56 PM
02/03/18 08:56 PM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
What cam would you recommend?
Right now I am thinking that I need to concentrate on the heads then do more upgrades at a later date. I was thinking about some 1.6 or even 1.7 rockers with the cam that I have?
Digger73 (Mike)
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2445899
02/03/18 10:03 PM
02/03/18 10:03 PM
That cam is way bigger than I have ran in any of my own bracket motors that are above 500 C.I. with both 440 size and all out CNC ported 440-1 heads work I'm thinking maybe 260 to 275 @.050 ground on a 108 to maybe 111 LSA installed on the intake lobes 3 to 6 degrees advanced with as much lobe lift that you can get and use either 1.5 or 1.6 ratio rockers up
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2445921
02/03/18 10:42 PM
02/03/18 10:42 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I agree that 280*/283* @ .050 is rather large for your 11.5 comp.
With a mechanical roller, something between 265/270 on the intake with .650 lift should be a better fit. IMO I wouldn't even Try to use that big cam you have, don't bother IMO. up
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2445929
02/03/18 11:07 PM
02/03/18 11:07 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
EZ choice to make
Re: Victor or Trickflow heads most bang for the buck? [Re: AndyF] #2446063
02/04/18 04:24 AM
02/04/18 04:24 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Originally Posted By AndyF
Read the 270 articles that I've written and study the pictures. You'll see that I used standard offset rocker arms on the 270 heads and that I've used a standard port intake on the 270 heads.
It might not be "ideal" but it can get you up and running and then6 you can upgrade from there.
Andy ,
You say you used an offset rocker . Trickflow on Summit show Harland Sharp S70015KE , which lists for a Edelbrock rpm on HS site
Victors are listed as using S70015EVK which are .650 offset
So do the 270s use non offset or offset ?
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Victor or Trickflow heads most bang for the buck? [Re: tex013] #2446127
02/04/18 12:09 PM
02/04/18 12:09 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Andy ,
Tex
Not offset. S700115KE supposedly corrects geometry issues with the Trick Flos. Just bought a set.
Re: Victor or Trickflow heads most bang for the buck? [Re: tex013] #2446214
02/04/18 02:26 PM
02/04/18 02:26 PM
AndyF Offline
AndyF  Offline
Andy ,
Tex
I said "standard offset".
Re: Victor or Trickflow heads most bang for the buck? [Re: Sport440] #2446219
02/04/18 02:30 PM
02/04/18 02:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mikey's 470 that Pettis built w.11.7? comp has a monster(to some)cam and I think is even bigger than this one and he's flying w/an 1150 dommy I did and has a string of 6.0's and 9.50's...........My turd has 276-281 @ .050 and is an easy docile car to drive street/strip........... drive
Re: Victor or Trickflow heads most bang for the buck? [Re: Von] #2446397
02/04/18 06:48 PM
02/04/18 06:48 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I was quoting the flow advertised from Brodix. I was a bit curious about the 295 cfm rating too, but maybe they made a few changes in the last 25+ years from when I bought my set. I think the heads I bought were from the second batch of castings, and were not drilled in the front for accessories. I bought them from Koffels with stage I porting (kind of like port and bowl clean-up work), 1.6:1 ratio rocker arms, and cut to length pushrods and I think the bill was right about $3,000 (around 2001?) A few years ago I had them tested on the flow bench, and I think they flowed about 298 cfm?
Re: Victor or Trickflow heads most bang for the buck? [Re: AndyF] #2446406
02/04/18 06:56 PM
02/04/18 06:56 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Andy ,
I misunderstood .
"What rocker arms do you have now? The 270 uses standard rocker arms so what you have might work."
OP has Crane rockers for standard port Stealth heads .
Thanks for your input
Tex
New best MPH 130.32
Re: Victor or Trickflow heads most bang for the buck? [Re: markz528] #2446410
02/04/18 07:02 PM
02/04/18 07:02 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Andy ,
Tex
Thanks markz528
So you could possibly use the Crane standard rocker if geometry works ?
I know it sounds like I am beating this to death BUT if I go this way I am looking at over $1300 of my quality Aussie dollars plus shipping .
Tex
New best MPH 130.32
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2446419
02/04/18 07:16 PM
02/04/18 07:16 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Just to keep things off topic.......
I haven't had a B1BS in the shop in quite a long time.
As I recall, ootb they did flow close to 290...... But didn't get near that until .700 lift.
One thing I remember about the first one I tested was, the low/mid-lift flow was so bad I stopped about 1/2 way through the test to make sure there wasn't a problem with the bench.
I couldn't believe that an aftermarket head with a 2.20 intake valve could be that bad.
I ended up getting them to work pretty well...... Around 320@.700 while keeping the runner fairly small, and making some nice improvements in the low/mid flow.
On a flat top 446 in a 3900lb car they were good enough to let the car run high 10.40's with a single 850, and high 10.20's@130 with the MP TR and 2 x 750's on it.
Re: Victor or Trickflow heads most bang for the buck? [Re: tex013] #2446461
02/04/18 08:21 PM
02/04/18 08:21 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Andy ,
Tex
Thanks markz528
Tex
You can use them if you can tolerate the geometry. The Harlan Sharp are expensive - around $950 standard price!
Re: Victor or Trickflow heads most bang for the buck? [Re: Digger73] #2446492
02/04/18 08:57 PM
02/04/18 08:57 PM
So. Burlington, Vt.
So. Burlington, Vt.
“ in theory” the HS “E” rockers are basically the same length as the Crane golds.
Re: Victor or Trickflow heads most bang for the buck? [Re: fast68plymouth] #2446495
02/04/18 09:02 PM
02/04/18 09:02 PM
AndyF Offline
AndyF  Offline
Yes or use the Mancini rocker arms. The Mancini rocker arms are a copy of the old Crane rocker arms. They are made by Harland for Mancini as a low end rocker arm. They work on the Trick Flow heads but are unbushed and probably won't last a super long time. But some race cars only make a few passes a year so in a situation like that they could last a life time.
Page 2 of 3 1 2 3
