Re: Hemi Vanke Intake
[Re: Dragula]
#2446670
02/05/18 02:34 AM
02/05/18 02:34 AM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
I Dyno tested the vanke vs the stock intake on a 484" hemi. It was a long time ago, so I don't remember the exact numbers, but the vanke did very well. If it needs to look stock, do it. Otherwise the stage v and the Edelbrock will both kick it's but.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2446774
02/05/18 12:34 PM
02/05/18 12:34 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Yall, I'm pretty sure Dragula is referring to the dual plane single 4500 hemi manifold that Arlen Vanke had made back in the day and Indy is now making new. Not a street hemi dual quad manifold w/ the Vanke modification. Here's a link to a build that used one... https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2145697/re-revamped-472-crate-hemi.htmlLooks like this one...
[Re: an8sec70cuda]
#2446876
02/05/18 03:10 PM
02/05/18 03:10 PM
Posts: 4,585 Motor City
6PKRTSE
Motor City
I work with an old Super Stock 60's racer from "back in the day" I had a dual inline four bbl street Hemi intake that I modified & did the "Vanke" treatment to it & drove it all over the street for years with dual Edelbrock 1407 (750 CFM) Carbs. The +.060" over Hemi loved the induction set up. No back to back comparison over a stock intake though. He says it is worth 40-50 H.P. at higher RPM.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Dragula]
#2446979
02/05/18 06:12 PM
02/05/18 06:12 PM
an8sec70cuda
Lee446...I've never run one myself, but it sure seems like the single 4500 Indy/Vanke manifold would be an awesome street hemi intake. Obviously lacking the upper rpm power for a big inch motor, but very strong low and mid range.
Just remember, like I mentioned in your post, there are 2 versions of Indy single plane/single 4500 manifolds. The Barton manifold is kind of in the middle power-wise b/t the 2 Indy pieces. I'm partial to Dominators, so if I had a milder street hemi...I'd definitely want to try the Indy/Vanke manifold. I have a 540" hemi I will assemble one day for my dad's road runner (4 speed and 3.54 geared Dana, 100% street driver). Pretty mild hydraulic roller, unported Edelbrock/MP heads, and a factory street hemi dual quad intake w/ the Vanke mod done to it. If he wasn't dead set on running 2 carbs on a hemi, I'd get one of the dual plane 4500 Indy/Vanke manifolds for it in a heartbeat.
[Re: Lee446]
#2446986
02/05/18 06:31 PM
02/05/18 06:31 PM
an8sec70cuda
Lee...Fast68plymouth (Dwayne Porter) is an Indy dealer.
The Indy 426-3 is 6 and 1/2" tall. The Barton is 7 and 9/16" tall. The Indy 426-4 is 8 and 1/4" tall. Measured w/ the manifolds sitting flat on a table.
From my own testing on my 572" hemi, the Barton is equal or better to the Indy 426-3 down low in the rpm range and definitely better up top. Only downside to the Barton is it's tall and heavy. 10+ lbs. heavier than the Indy manifolds. The Indy 426-3 gets used a lot b/c it's short. The Indy/Vanke dual plane manifold will obviously be better down low and have better driveability, but at the expense of upper rpm power.
The big Indy 426-4 is a serious piece. My 572 lost a lot of lowend grunt w/ it and slowed down (naturally aspirated) compared to the Barton. It belongs on a serious engine.
Below is a pic showing the height difference b/t an Indy 426-3 and the Barton manifold.
[Re: an8sec70cuda]
#2446991
02/05/18 06:39 PM
02/05/18 06:39 PM
an8sec70cuda
For comparison, here's a pic of the big Indy 426-4 on the left and the Indy 426-3 on the right. At the time, I didn't have a Barton manifold in the shop to compare.
Sorry for the post picture hijack Dragula!
[Re: Dragula]
#2447091
02/05/18 10:04 PM
02/05/18 10:04 PM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
I use to have all that information on rejetting of the carbs and stuff like that with a Dual Four Vanke modified intake. I think I still have the intake. FHO did some testing on this intake and others. I think the gains were not great but that would depend on how much you are looking for and the application you are using it for. 30 to 50 HP would be nice for stock type street car.
1971 HEMI E BODY REGISTRY
