Page 3 of 3 1 2 3
Re: trans case number on 69 cuda m-code cars [Re: JohnRR] #244597
03/08/09 07:17 PM
03/08/09 07:17 PM
USA
big-block-dave Offline
USA
Dan,thanks! My car has it! As for the last poster, my car has 6759 original miles and the rubber seal IS orange!!!!! Back in '88-'89 when my car was put back to street duty it only had 3291 miles and i HIGHLY dought it was changed!!! My car was first REGISTERED for the street in April '89. Sold to a private collector in Dec. '89 never to be registered or driven for 17 years!!!!! Then i bought it in Nov '06!! http://www.andy440.com/com_July_2008.htm Yes i have changed the RED pie tin to the correct ORANGE! Dave
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
Re: trans case number on 69 cuda m-code cars [Re: big-block-dave] #244598
03/08/09 07:21 PM
03/08/09 07:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Dan,thanks! My car has it! As for the last poster, my car has 6759 original miles and the rubber seal IS orange!!!!! Back in '88-'89 when my car was put back to street duty it only had 3291 miles and i HIGHLY dought it was changed!!! My car was first REGISTERED for the street in April '89.I could ask that person if needed! Dave
did you call them yet ???
Re: trans case number on 69 cuda m-code cars [Re: JohnRR] #244599
03/08/09 07:31 PM
03/08/09 07:31 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have the factory docs on the wire clip somewhere, it may take me awhile to find it though. Lets not forget that the 69 440 cars were built from the allotment of 383 cars, just like the 68 Mr. Norms GSS cars were taken off the 383 line and an "M" code VIN attached to the dash. If you take the number of big block automatics built, which is 1128, then subtract the 488 true 383 autos built, that makes 640 proportedly built 440 GTS's. Once again this means that they started life as 383 cars, and the line needed to know that all the 383 components MUST be in place before convertering to 440 power, it makes sense then.
JB Rhinehart, Realist
A-Body's RULE!
Re: trans case number on 69 cuda m-code cars [Re: big-block-dave] #244600
03/08/09 07:37 PM
03/08/09 07:37 PM
Mass
charge70 Offline
charge70  Offline
Mass
Dave,the orange steering coupler seal wasn't available from Mopar till the late 70's or early eighties,so it has definitely has been replaced. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: trans case number on 69 cuda m-code cars [Re: Rhinodart] #244601
03/08/09 07:39 PM
03/08/09 07:39 PM
USA
USA
Jim, so you believe that 640 M-code Darts were built? There is question that maybe only the same number Darts were built as 'cudas, about 360??? BUT i believe that there needed to be 1000 cars produced to compete in factory super stock class. Therefore 640 Darts and 360 'cudas equals the 1000 needed??
Re: trans case number on 69 cuda m-code cars [Re: cudaman1969] #244602
03/08/09 10:39 PM
03/08/09 10:39 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
well i'm back with some nagging questions that need clearing up. 1, why did the cars come down the line with 383s on the vin tag then have to change, why didn't it just start as a 440? it wasn't like they didn't know they where making them. my fender tag has the 383 number. 2, that wire clips only purpose is to hold that joint lid on,leads me to think it was removed after assembly for some reason. i haven't seen them on any other car in these numbers. any ideas
"Package cars" as in this case the 1969 A13 Dart/Cuda and the A12 "Package" '69 B-body RM, WM models were just that an optional "Package" that was ADDED to a base model. Product planning (PP) made a list of additions ("Package" contents) and deletions (Items not necessarily in the "Package" but not used like hub caps or wheel covers on the A12's ) and then PP got together with the "Fleet Engineering" (FE) department and determined when and what could be done on the normal production line. They (FE) would set a best target date for the start of production (302-A13, 329/426-A12) knowing not all planned units could be built in one day or on those dates. If space (canceled other car orders) became available then Fleet Engineering slotted package cars into those available openings. With the A12 cars the package was added to a 383 base RM/WM car so that some of the base items were in place at Body-in-White and when it came to installing the 383 the broadcast sheet dictated the deletion of the 383 and the addition of the 440's.
The PP/FE addition and deletion list pretty much had every nut, bolt, screw, washer, and items that was added or deleted and anything that couldn't be put on during normal assembly was left up to Fleet Engineering to figure out how to get done. In the case of the A12's that seemed to be the intake, carbs, hood and hood pins. With the A13's IMO there wouldn't be much that couldn't be done on the standard assembly line?
BTW, I thought the standard differential for the A13 was an 8-3/4 3.55:1............and the reason for only the 3.91: 8-3/4 and no 4-speed trans was there wasn't a Dana narrow enough to fit the '69 A-body???
MikeR
Re: trans case number on 69 cuda m-code cars [Re: A12] #244603
03/08/09 11:24 PM
03/08/09 11:24 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
hey dave my coupler has the black gasket, no rust or scale on joint, just grease and dirt. wish we had a time machine
Re: trans case number on 69 cuda m-code cars [Re: cudaman1969] #244604
03/09/09 09:53 AM
03/09/09 09:53 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: trans case number on 69 cuda m-code cars [Re: big-block-dave] #244605
03/09/09 07:08 PM
03/09/09 07:08 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That is the 64K question. It is kinda hard to believe that many were built, did most get used up? I have seen many more 383 cars, but I have also seen many 440 cars coming out of the woodworks lately. I checked a B5 Blue and a Bronze M code Dart and they both had 093 trans! I have a 69 Cuda fastback and coupe I can look at also, the coupe was never modified though thoroughly rusted. I cannot find the paperwork I had on the clip, but I don't believe it was available in 69, I can barely remember it came out later, but need to find the paperwork.
A-Body's RULE!
Page 3 of 3 1 2 3
