Re: Lifters?
[Re: RV2]
#2447933
02/07/18 11:32 AM
02/07/18 11:32 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
you can fit SBs lifters on a BB but I think not the other way around due the oiling groove hight difference
At least in my experience the pushrod lenght change is not true. I'm using 2011s ( SB lifters ) on my BB without any length or fitting problem
several performance aftermarket brands offer the same lifters for both and they look like the 2011 kind lifters
Re: Lifters?
[Re: RV2]
#2448232
02/07/18 10:26 PM
02/07/18 10:26 PM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
I wondered about that. If the 2011 lifter fits LA, B and RB, Chrysler could have economized and used it for everything instead of the 976.
Before PAW shut down, ordered BB hydraulic lifters and got SSI 2011. Saving them for next cam change. As long as they work I don't care.
68 Roadrunner. 383 4-spd. Beat up.
Re: Lifters?
[Re: Mebsuta]
#2449357
02/10/18 12:54 AM
02/10/18 12:54 AM
NachoRT74
Valencia, España
I wondered about that. If the 2011 lifter fits LA, B and RB, Chrysler could have economized and used it for everything instead of the 976. agreed, but have not idea why they are diff being 2011s works
Re: Lifters?
[Re: RV2]
#2449533
02/10/18 02:52 PM
02/10/18 02:52 PM
Posts: 8,271 fredericksburg,va
cudaman1969
fredericksburg,va
Comp shows the same lifter for 273-360 and 68 up 383-440, #822-16. Back in the early 70s when working at the Dodge place, if we needed a lifter, there was only one they stocked, can't remember the #. Hec, you can use an AMC lifter also, oils through the pushrods to rockers.
