Page 2 of 3 1 2 3
Re: trans case number on 69 cuda m-code cars [Re: charge70] #244577
03/07/09 01:46 AM
03/07/09 01:46 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
093 trans, and B-Bodies are just fat, like your ol' lady...
JB Rhinehart, Realist
A-Body's RULE!
Re: trans case number on 69 cuda m-code cars [Re: Rhinodart] #244578
03/07/09 10:32 AM
03/07/09 10:32 AM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
well i did generate some interest on these cars didn't i. tell me how to load an attachment,i scaned the paper,put in the pc then opened a post,it said add a file,i put it in the box ,came up a bunch of letters and numbers,is this rite? not sure what will come out. if this is corect i'll post the paperwork i have on who did the change. i'll look for the 093 case now
Re: trans case number on 69 cuda m-code cars [Re: cudaman1969] #244579
03/07/09 10:43 AM
03/07/09 10:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
as long as it's not to big a file it will load .
I like your descrition of what you saw
Re: trans case number on 69 cuda m-code cars [Re: Rhinodart] #244580
03/07/09 01:56 PM
03/07/09 01:56 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
And A bodies are just tire SMOKERS, like that tramp at the bar you hang out at.
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: trans case number on 69 cuda m-code cars [Re: AZ_A12_BEE] #244581
03/07/09 02:01 PM
03/07/09 02:01 PM
Mass
charge70 Offline
charge70  Offline
Mass
Yea,but the bar tramps are a lot more fun than the fat ole' lady you left at home.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: trans case number on 69 cuda m-code cars [Re: charge70] #244582
03/07/09 03:08 PM
03/07/09 03:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: trans case number on 69 cuda m-code cars [Re: JohnRR] #244583
03/07/09 04:49 PM
03/07/09 04:49 PM
fredericksburg,va
fredericksburg,va
heres the paper i have on where m-code a-bodys where built, there are some errors (trans number for one)
5076571-scan0003.pdf (222 downloads)
Re: trans case number on 69 cuda m-code cars [Re: cudaman1969] #244584
03/07/09 05:09 PM
03/07/09 05:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How about a FACTORY DOCUMENT to back that up ???
Re: trans case number on 69 cuda m-code cars [Re: JohnRR] #244585
03/07/09 07:21 PM
03/07/09 07:21 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Never trust anything that a Plymouth owner says or documents that said owner may posess. When I get home I will check my documents, and take a look at the original cars I have laying around...
A-Body's RULE!
Re: trans case number on 69 cuda m-code cars [Re: Rhinodart] #244586
03/07/09 08:48 PM
03/07/09 08:48 PM
fredericksburg,va
fredericksburg,va
one more thing, do your cars have the wire clip on the steering conector at the box? this clip was put on all 440 installs because the engine was put down in with manifolds installed so the column was removed then put back and the clip held the joint together better then just bending those little tabs.i was at the last reunion and all the 440 cars had them. and who do you think made that mount? not chrysler
Re: trans case number on 69 cuda m-code cars [Re: cudaman1969] #244587
03/07/09 09:11 PM
03/07/09 09:11 PM
Mass
charge70 Offline
charge70  Offline
Mass
I guess that you don't believe that MoPar built these cars on the line,so be it.Yes,my car has that clip on top of the coupler,and I believe that all M-code A-bodies have them,but the tabs on this clip go into the roll pin holes,so you need to remove or move it back to get the pin out of the coupler.So this clip would have nothing to do with holding the coupler together with the column out of the car,regardless of the reason.As far as the motor mount bracket,Chrysler doesn't produce many if any parts themselves,they are outsourced just like that bracket.These few things you've mentioned doesn't prove that Hurst built these cars.Until I see an official document from Chrysler or Hurst about who built these cars,I'm going with Chrysler.
Re: trans case number on 69 cuda m-code cars [Re: charge70] #244588
03/07/09 09:24 PM
03/07/09 09:24 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
XI (Axle ratios) According to Chrysler, you could also get 3:91s
PIB with 3:91 info
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: trans case number on 69 cuda m-code cars [Re: charge70] #244589
03/07/09 09:38 PM
03/07/09 09:38 PM
fredericksburg,va
fredericksburg,va
well i will be a man and admit i'm wrong. i just got off the phone with a friend who talked with the engineer involved and he told him they where built on the factory line. i did get my numbers and got rid of a lot of bad info and thats what we all want. good luck to all your projects
Re: trans case number on 69 cuda m-code cars [Re: cudaman1969] #244590
03/07/09 11:26 PM
03/07/09 11:26 PM
Santa Cruz, CA
1969cudaman Offline
1969cudaman  Offline
Santa Cruz, CA
^no worries, everyone learns something new here!
I can take a pic if needed since my car is apart
Re: trans case number on 69 cuda m-code cars [Re: 1969cudaman] #244591
03/08/09 12:08 PM
03/08/09 12:08 PM
USA
big-block-dave Offline
USA
Yes, lets see a pic of the wire clip!!!
As far as trans# i have a #'s matching guy checking his for us, i believe it's 093 but why not check another #'s match car!!!
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
Re: trans case number on 69 cuda m-code cars [Re: big-block-dave] #244592
03/08/09 03:25 PM
03/08/09 03:25 PM
Shelby, Ohio
2
2abodymcodes Offline
Shelby, Ohio
my 69 m-code cuda has 24,000 original miles and has been sitting since 1971 or 72. it is all original numbers matching. i checked yesterday and it does have a 093.
Re: trans case number on 69 cuda m-code cars [Re: big-block-dave] #244593
03/08/09 03:28 PM
03/08/09 03:28 PM
fredericksburg,va
fredericksburg,va
well i'm back with some nagging questions that need clearing up. 1, why did the cars come down the line with 383s on the vin tag then have to change, why didn't it just start as a 440? it wasn't like they didn't know they where making them. my fender tag has the 383 number. 2, that wire clips only purpose is to hold that joint lid on,leads me to think it was removed after assembly for some reason. i haven't seen them on any other car in these numbers. any ideas
Re: trans case number on 69 cuda m-code cars [Re: cudaman1969] #244594
03/08/09 04:22 PM
03/08/09 04:22 PM
Mass
charge70 Offline
charge70  Offline
Mass
This is my best guess,1st these cars aren't coded for 383's on the vin tag,only on the data plate and then only in the engine option box.The reason for the "M" designation on the vin is that the Dart line was never available with a 440 as a standard option,so I'm assuming that MoPar instead of using the regular B-body vin code for 440 they just decided to use the "M" code to designate these cars as special order/special build.The reason for the 383 coding is the rest of these cars are identical to a regular build 383 car,w/o the availability of a few regular 383 options. 2nd,the clamp on the steering box,I really can't answer this one,but all I can say is that there is a part# for it in the 69 parts book for usage on all car lines and models,and I have personally seen these before on some pick-ups. Anyone else with a theory.Here's a pic of my M-code GTS. John.
Re: trans case number on 69 cuda m-code cars [Re: charge70] #244595
03/08/09 05:33 PM
03/08/09 05:33 PM
Santa Cruz, CA
1969cudaman Offline
1969cudaman  Offline
Santa Cruz, CA
Here ya go Dave.
Re: trans case number on 69 cuda m-code cars [Re: 1969cudaman] #244596
03/08/09 06:59 PM
03/08/09 06:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Here ya go Dave.
someone was in there AFTER the fact , the factory used BLACK seals , that orange has been said to be later than 69 . the clip is something Chrysler came up with because once you pop that cover off after it's been put together the first time it's almost impossible to keep the cover from not popping back off .
When that was taken apart and for why ???
Also there was a member that was selling those clips for sometime .
Page 2 of 3 1 2 3
