crank end play #2445864
02/03/18 08:59 PM
02/03/18 08:59 PM
England
fastfish451 Offline OP
England
what is the max you can run k1 crank 7500 rpm
Re: crank end play [Re: fastfish451] #2445886
02/03/18 09:49 PM
02/03/18 09:49 PM
If it was more than .015 I would find out why scope
The factory service manuals call from .004 to .010 with the stock forged steel BB cranks and the same on the Hemi motors work
Re: crank end play [Re: fastfish451] #2445889
02/03/18 09:51 PM
02/03/18 09:51 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I like to see .006-.008
RIP Monte Smith
Re: crank end play [Re: CompWedgeEngines] #2446084
02/04/18 08:56 AM
02/04/18 08:56 AM
England
England
I have 12 thou what do you guys think run or not thanks
Re: crank end play [Re: fastfish451] #2446126
02/04/18 12:04 PM
02/04/18 12:04 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Yes, I'd rather have 12 than 6. I shoot for 10 on race motors typically anyway. They, for me anyway, seem to hold up better with high thrust loads. I even put a slight bevel at the parting line from the oil groove on the upper bearing to the thrust side to send more oil that way too.
Re: crank end play [Re: fastfish451] #2446134
02/04/18 12:14 PM
02/04/18 12:14 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
That seems on the big side,they look good when you take them apart??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: crank end play [Re: hemi-itis] #2446276
02/04/18 03:41 PM
02/04/18 03:41 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I have run everything From 3 to 7 to 15 to 22..on a Max effort small-block.. I also had a 408 that somehow Wore into almost 30... no magic in the thrust.. I would say usually anywhere between 4 and 12 would be acceptable.. when the motor is running basically you have zero thrust on the back side..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: crank end play [Re: hemi-itis] #2446458
02/04/18 08:16 PM
02/04/18 08:16 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
They look better the wider I run them. Like the other guy said no magic there, unless there isn't enough, then presto. Lol. More oil helps with huge converter loads.
Re: crank end play [Re: fastfish451] #2447374
02/06/18 02:09 PM
02/06/18 02:09 PM
hemi-itis Offline
hemi-itis  Offline
Was this from being to tight?
Re: crank end play [Re: fastfish451] #2447465
02/06/18 05:17 PM
02/06/18 05:17 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Here's something I never understood about end play - What are you really supposed to do if you're not in spec? Buy another crank or block? The spec is a fairly narrow window for something you really don't have the ability to adjust. You would think that they would make thrust bearings available +/- .005 or .010.
How hard are you really supposed to pry the crank? If you pry enough it seems like they all have more than .010...
Re: crank end play [Re: hemi-itis] #2447488
02/06/18 05:54 PM
02/06/18 05:54 PM
Washington
madscientist Offline
Washington
I've lost thrust bearings over the years (who hasn't) and when they are too tight they smear. That bearing looks like it flaked off. Is it a clevite bearing?
Re: crank end play [Re: hemi-itis] #2448081
02/07/18 05:07 PM
02/07/18 05:07 PM
England
England
Bearing I took out had a bit of that flaking going on ??
Clevite. any ideas
Re: crank end play [Re: fastfish451] #2448175
02/07/18 08:14 PM
02/07/18 08:14 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Buy yourself a set of king bearings.
