Page 80 of 159 1 2 78 79 80 81 82 158 159
Re: Paint job on a budget!? CONTINUED..page 44........ *DELETED* #26038
10/09/06 08:40 PM
10/09/06 08:40 PM
Spokane, WA USA
Wyl E Coyote Offline
Spokane, WA USA
Post deleted by Wyl E Coyote
Re: sprayed [Re: 69DartGT] #26039
10/09/06 09:05 PM
10/09/06 09:05 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Dave what did you thin with? My plan is to shot all the hard to reach area's with a hvlp gun and roll the rest, depends on how well the sprayed area's come out.
Thinned with good old mineral spirits, and I measured the dosage, it was about 8-10%. Still a pretty thick mixture, and it took 5 seconds to go from a stream to a drip.
That sounds like a great plan you have, for spraying small areas it's bearable. Like I said with the right spray and breathing setup it would be OK but in my opinion it's not worth all that work when you could just roll.
Here are some pics. There's a lot of orange peel in this paint job also, so I will becoming friends with my sanding block again.
Here's the area I fixed up before repaint..
BEFORE...
Which was almost completely covered by the single sprayed coat.
AFTER...
some other after pics. by the way I didn't paint the hood since I'm not planning to use it but it's already a uniform canvas white.
Some orange peel
and some orange peel combined with not laying down enough material
A single roll coat should take care of it now, after a few hours with a spray bottle and 800 grit.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Wyl E Coyote] #26040
10/09/06 09:09 PM
10/09/06 09:09 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Coyote - probably any non-catalyzed metallic paint can be rolled on, the problem is when wetsanding it it will probably go all wacky on you. If you could roll it on and not worry about sanding it down to get rid of orange peel or imperfections, it would be OK. In fact I have some rustoleum aluminum color that I'm going to put/roll on an engine block, where I dont really care about smoothness.
I think someone in the past rolled on some metallic flakes, then did a coat over that, and the flakes were still visible but were not affected by the wetsand. Not sure who it was..
Re: Paint job on a budget!? CONTINUED..page 44........ *DELETED* *DELETED* [Re: Exit1965] #26041
10/09/06 09:40 PM
10/09/06 09:40 PM
Spokane, WA USA
Spokane, WA USA
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Wyl E Coyote] #26042
10/09/06 09:58 PM
10/09/06 09:58 PM
why hasn't anyone tried to roll on single stage auto paint? It shouldn't be any differnt, yes more expensive..but you get the mettallic look and b5 blue im sure.
Steve
Re: Paint job on a budget!? CONTINUED..page 44........ #26043
10/09/06 10:05 PM
10/09/06 10:05 PM
Steve
More expensive? $39. a gallon.
http://stores.ebay.com/Auto-Paint_acrylic-enamel-auto-paint_W0QQcolZ2QQdirZ1QQfsubZ2QQftidZ2QQtZkm
or $65. for a kit.
http://stores.ebay.com/Auto-Paint_acryli...9QQftidZ2QQtZkm
Re: Paint job on a budget!? CONTINUED..page 44........ #26044
10/10/06 04:16 AM
10/10/06 04:16 AM
venice, ca
admactanium Offline
admactanium  Offline
venice, ca
Steve
i don't think the issue is the type of metallic paints. i think it's just an issue that metallic paints can't be rolled by their very nature. they require fine atomization in order to distribute the flake evenly. when you open a can of metallic paint it really swirls and sticks together. i'd think that if you rolled on metallic paint it would leave streaks of metallic paint and streaks of non-metallic (or low density metallic) paints.
hell, when i was in high school my friend's dad restored and painted his beetle with metallic blue. the paint job looked pretty good from ten feet away but when you got closer you could see how swirly and splotchy the flake distribution was. and that was from spraying. maybe they sprayed too thick a coat or didn't mix the product well enough.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: admactanium] #26045
10/10/06 09:03 AM
10/10/06 09:03 AM
TY for your detailed post Admactanium. It motivated me to go out and purchase one of the Random Orbital Polishers. After a few hours with Harbor Freight Orbital Sander/Polisher, I am starting to see the gloss come out of the haze. I suspect, even with Turtle Wax products mind you, with a proper Polisher, and proper attachments/bonnets, I will get satisfactory results in less time. THANKS again all posters that have developed techniques that idiots like myself can follow.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: admactanium] #26046
10/10/06 09:36 AM
10/10/06 09:36 AM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
I've sprayed metallic lacquer years ago and we used to drop a couple of clean marbles or even 1/2 nuts in the cup and you would continue to shake these every so often to keep it mixed properly.
Re: Profesional Results? #26047
10/10/06 10:46 AM
10/10/06 10:46 AM
All my tremclad cars and the 1st one very soon to be tremclad'd white with a black roof with blue pearl. The red/black one i added 15g of red pearl into the base then sprayed tremclad clear..looks amazing when the sun hits it..the clear is rather hard to spray(i used a spray gun vs roller so i could use pearl) and you cant use mineral spirits with the clearcoat. The Black car i used flake..depending how you look at it it could appear like yellow flake green or blue...its a beater/joke car.
Very nice spray man. I'm from sauga too. I see you used Tremclad. I was going to use that, but am opting for the Brightside paint for more shine hopefully. What spray gun did you use?
Re: Profesional Results? #26048
10/10/06 11:20 AM
10/10/06 11:20 AM
toronto canada
69chargeryeehaa Offline OP
toronto canada
I'm in mississauga too
Re: Paint job on a budget!? CONTINUED..page 44........ #26049
10/10/06 01:47 PM
10/10/06 01:47 PM
venice, ca
admactanium Offline
admactanium  Offline
venice, ca
post some pics of the results. i think you could get good results using turtle wax. but if you have a pep boys nearby you could pick up some meguiars or 3m polishes that are really good. i've seen both of those lines pretty extensively at my local pep boys.
Paint Job #26050
10/10/06 08:58 PM
10/10/06 08:58 PM
440charger70 Offline
super street
super street
Is there a page were everything needed to get started and basic instructions are listed? 40 Pages is a lot of reading to get caught up on this process... Can someone give a quick lesson from the beginning or refer me to a page where this is (Supplies, mixing ratio, application)?
Re: Paint Job [Re: 440charger70] #26051
10/10/06 10:14 PM
10/10/06 10:14 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Rustoleum or brightside?
Either way, they are similar in application. Thin brightside with either their thinner, or mineral spirits. The ratio I'm going to use next is 15% thinned, since 10% sprayed levels out OK when sprayed in correct amounts. Then roll on.
Wetsand after each coat to get rid of orange peel and imperfections, with 800 grit. Last coat, let it set for a few weeks, then hit with 2000 grit wet, then polish and wax.
That's the basic recipe. The best thing to do is to buy the materials (fine foam rollers from home depot or lowes, in a 5 pack for about $6) and do a test piece. It's a pretty easy thing to do with a roller.
The worst thing you can do is waste paint. If anything goes terribly wrong you can just wetsand it down and paint again. Unless you're slathering the paint on too thick, you shouldn't get any runs or anything that would require the whole thing to be sanded off.
Re: Paint Job [Re: 440charger70] #26052
10/10/06 10:28 PM
10/10/06 10:28 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Re: Paint Job [Re: 440charger70] #26053
10/11/06 08:35 AM
10/11/06 08:35 AM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
In a way... I think every user who is thinking about doing this type of paint job on their car SHOULD be reading all the messages.
The problem with just reading a recipe is that you are not fully prepared for all the variables and 'Murphy Law' type events that 'might' happen.
By walking into this project fully informed, you will be in a better position to deal with any curves that might get thrown at you during the process.
I know that like many folks here, I began by reading the original thread and it kept me up for almost four hours as I read every tidbit of information in the thread.
Now that this topic is covering two complete threads, ( the original thread now being archived for posterity and non-deletion ) and ( the current thread which at this moment is touching on 40 pages )... It might be useful for new readers to this thread to at least start their studying at the beginning of this thread.
Not only will the new readers have a better understanding of this painting process, but as well MANY OF THE SIMPLE QUESTIONS will have already been answered and it will cut down on people re-asking questions that have already been fully responded to.
Re: Paint Job [Re: Exit1965] #26054
10/11/06 03:40 PM
10/11/06 03:40 PM
Really interested in how your White Brightside paint job turns out Exit. I was going through another forum where members were painting their Honda civics/Integras. One complaint they all had was the dull finish that Tremclad/Rustolean gave. Another thing I noticed was that the majority of people painting their cars chose the colour white since it hides defects well. My car is currently white, but going to black wouldn't be a bad idea if it turns out alright. Really interested in how well Aussie's paint turns out.
Is there anyone here painting their car Brightside Black using the roller technique and is complete? I've only seen the black sprayed.
Re: Paint Job #26055
10/11/06 04:48 PM
10/11/06 04:48 PM
On my car the gloss black Brightside has withstood the elements much better than the paint from my first attempt.
One of my collegues here at school (I'm a teacher) has a black VW Bora and she occasionally parks next to my car. The Brightside certainly doesn't look bad next to a factory paint job, and I'm still a couple of weeks away from my final wetsand and polishing.
So far my impressions of the Brightside are fantastic.
Re: Paint Job #26056
10/11/06 05:42 PM
10/11/06 05:42 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
My impressions are the same. The wet-look gloss is something else.
I plan to wetsand later this week then roll my 'final' coat of brightside on Saturday. It should end up being a smooth surface compared to how it is after the spray attempt.
It's a very cool site looking at my car now though, with a clean white shiny coat, and it's not even applied right. After I had rolled a coat on the fender, it looked great, but orange peely. With more thinner I hope to do away with most of that orange peel on my next roll.
Re: Paint Job [Re: Exit1965] #26057
10/11/06 06:13 PM
10/11/06 06:13 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Dave don't want to second guess you or anyone else I but I don't think I'll use the any thinner except what Interlux's brand either the 216 or 333 if I'm remembering right, but if its working for you can't knock that..
Mineral Spirits just doesn't in my mind seem right for polyurethane paint..
