what type of rear shocks u running on e body #2445753
02/03/18 06:15 PM
02/03/18 06:15 PM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
HI,
I have a 71 cuda in need of rear shocks. I was wondering what you guys are running.
Re: what type of rear shocks u running on e body [Re: bugsydog] #2445758
02/03/18 06:22 PM
02/03/18 06:22 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
How much money do you want to spend, cause you are going to get recommendations anywhere from $50 to $300 dollars a each.
Re: what type of rear shocks u running on e body [Re: 71birdJ68] #2445765
02/03/18 06:29 PM
02/03/18 06:29 PM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
about $100 each
Re: what type of rear shocks u running on e body [Re: bugsydog] #2445835
02/03/18 08:19 PM
02/03/18 08:19 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I'm running the old mopar 50-50 drag shocks on my 70 convertible, has a smooth ride....not even sure if they make them anymore...
Re: what type of rear shocks u running on e body [Re: bugsydog] #2445859
02/03/18 08:57 PM
02/03/18 08:57 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Ok, then Koni is good brand. They make a classic shock for our cars that are adjustable, for around a $100 each
Re: what type of rear shocks u running on e body [Re: bugsydog] #2445933
02/03/18 11:18 PM
02/03/18 11:18 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I like Monroematic Plus shocks. Cheap and similar to OE police. Not a band-aid for weak/worn suspension or a racing shock though. I had KYBs and the car rode like a dump truck. Way too stiff.
Re: what type of rear shocks u running on e body [Re: bugsydog] #2445957
02/04/18 12:11 AM
02/04/18 12:11 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I need something smoother as well. I have summit drag shocks with 3 settings and all of them seem to want to chatter my teeth out. S/S springs may not be helping.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: what type of rear shocks u running on e body [Re: GoodysGotaCuda] #2446033
02/04/18 02:41 AM
02/04/18 02:41 AM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
I appreciate the info
Re: what type of rear shocks u running on e body [Re: bugsydog] #2446046
02/04/18 03:14 AM
02/04/18 03:14 AM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
do the shocks come with all attachments, plug and play?
Re: what type of rear shocks u running on e body [Re: bugsydog] #2446158
02/04/18 12:50 PM
02/04/18 12:50 PM
moparx Offline
moparx  Offline
nothing to include, really. unless you don't have anything now, you reuse the lower nut[s] and washer[s], as this is a rubber bushing with no insert that slides on the spring plate, and the upper bushing has a steel insert for the 1/2" through bolt[s] that attaches the upper shock to the crossmember [which you also reuse]. those items are repopped, i believe, so if you need [or want] to replace them, they will be an extra expense. i can't think of any rear shocks sold that include the hardware, unlike front shocks.
beer
Re: what type of rear shocks u running on e body [Re: GoodysGotaCuda] #2446220
02/04/18 02:33 PM
02/04/18 02:33 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
SS springs are rated for specific weight race cars. For a compliant ride on a street strip car, go with a SS spring rated at about 500 lbs lighter than your car.
I use a pair of 3200 lbs passenger side springs on both my 3700lbs A-Body and E-Body and the ride, handling and launch is the best I've found in decades of trying different set-ups. I also lubricate all suspension and shock mounts with synthetic disc brake grease, as it dramatically decreases sticktion and increases ride compliance without damaging rubber, polyurethane or plastic.
Billstein and Koni shocks are good choices. Expensive double adjustable shocks are hit and miss, as the range of adjustability can include the settings that will work for your car or miss them. Its not easy to adjust shocks properly in the first place.
Re: what type of rear shocks u running on e body [Re: bugsydog] #2446391
02/04/18 06:33 PM
02/04/18 06:33 PM
NC
1970A66 Offline
1970A66  Offline
NC
Check out Firm Feel, they sell a good Bilstein shock in your price range.
Got 4 of them on my Challenger. I'm happy with them.
Re: what type of rear shocks u running on e body [Re: bugsydog] #2446493
02/04/18 08:57 PM
02/04/18 08:57 PM
AndyF Offline
AndyF  Offline
Bilstein from Firm Feel should be a bolt on. The Koni shocks are excellent, but they do not bolt on. You'll spend a bunch of time and money getting Koni shocks to fit your car. I had to build my own shock plates before I could use Koni shocks on my B-body. Most people aren't set up to build their own shock plates.
Re: what type of rear shocks u running on e body [Re: AndyF] #2446513
02/04/18 09:34 PM
02/04/18 09:34 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
AndyF is your Koni B body reference to early B bodies?, as I run Konis on my 70 Charger, and they were a bolt on no mods needed, front and rear
Mike
Re: what type of rear shocks u running on e body [Re: bugsydog] #2446541
02/04/18 10:19 PM
02/04/18 10:19 PM
AndyF Offline
AndyF  Offline
I just ordered the Koni shocks from Summit that are listed for a B body car. 82-1255. Problem is they have a 5/8 lower eye so they will not fit on a typical Mopar shock plate. You have to buy new plates with smaller studs or cut off the existing studs and turn them down on a lathe.
https://www.summitracing.com/parts/kon-821255/
Re: what type of rear shocks u running on e body [Re: bugsydog] #2446544
02/04/18 10:34 PM
02/04/18 10:34 PM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
I have tried a few brands of lower priced units, Monroe, KYB and the other escapes me, the basic Monroes ride the best. KyB white ones were very harsh, I think GR1 was number. We put the GR2 silver ones on for a customer, much better ride. I'd like to try Koni adjustable ones next. Been cruising this thing since 1982, used up a few parts...
Re: what type of rear shocks u running on e body [Re: AndyF] #2446799
02/05/18 01:09 PM
02/05/18 01:09 PM
moparx Offline
moparx  Offline
on the shelf [somewhere biggrin] , i have a pair of studs that came from the "help" section at the parts store. they are 5/8 through the shock plate, and 5/8 for the shock itself. with those, a guy only has to cut off the original stud, grind flush, and drill a 5/8 hole in the shock plate. i don't know the brand, part#, or who made them. got them with a bunch of other "stuff".
beer
Re: what type of rear shocks u running on e body [Re: moparx] #2446848
02/05/18 02:18 PM
02/05/18 02:18 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
I have adjustable Fox shocks from Hotchkis on all 4 corners of my Cuda. They bolt in out of the box, but are somewhat above budget.
Re: what type of rear shocks u running on e body [Re: bugsydog] #2446861
02/05/18 02:46 PM
02/05/18 02:46 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I upgraded rear shocks on my Dart from Monroe Sensatrac's, to Bilstein Classic to adjustable QA1 shocks.
Every step was an improvement with better control as a result, but the step from Monroe to Bilstein was most noticable.
