Victor or Trickflow heads most bang for the buck?
#2445465
02/03/18 02:20 AM
02/03/18 02:20 AM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
Hi all, I am trying to decide on Victor or Trick flow heads. The engine is a 500" 440 based engine with 11.5:1 compression. I have a solid roller cam forget the specs right now. I have a Super Victor intake and a 1050 Dominator. Crank trigger with a 7al ignition. The converter is an 8" 5500 in a 727. The rear is a Dana with 4:30 gears. The car is strip only and weighs 2800 with driver. Not sure which heads to look at. So I am putting this out to get opinions. I know the compression is down a bit but the engine was going to be used as a street strip thing when originally built.
Thanks, Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Victor or Trickflow heads most bang for the buck?
[Re: '72CudaRacer]
#2445469
02/03/18 02:33 AM
02/03/18 02:33 AM
Digger73
Portland, Oregon
Why the Trick Flow? I am so up in the air that I am just fishing for information at this point. The season is getting closer and I want to get this settled so I can race...
[Re: AndyF]
#2445475
02/03/18 02:49 AM
02/03/18 02:49 AM
Digger73
Portland, Oregon
Thanks for the input Andy. I forgot to put in the original post that I am now set up for standard 440 ports. Is the choice still for the Trick Flows?
[Re: Digger73]
#2445504
02/03/18 04:38 AM
02/03/18 04:38 AM
Posts: 43,163 Bend,OR USA
Cab_Burge
If you want the car to go as fast as possible go with the biggest port size heads you can get like the Trick Flow 270 or the Indy SR M.W. or 440-1 with the best intake to match the head port size I have a set of Victor M.W. heads on my bracket motor, I'm not impress with them The next motor for that car has a set of CNC ported big valve 440-1 with a Jesel paired shaft rocker arms on them How fast do you want to go and how soon? Don't forget that the head combustion chamber size and head gaskets used affect the true compression ratio
[Re: Digger73]
#2445589
02/03/18 12:48 PM
02/03/18 12:48 PM
Digger73
Portland, Oregon
Thanks all for the comments and suggestions. I found the cam information. Comp Cams 315R grind duration @.050 Int. 280. Exh. 284. Lobe lift Int. .420 Exh. .401. I have 1.5 Crane Gold roller rockers. The head gasket compressed height is .051". They are Fel-pro black. The compression ratio was calculated using these head gaskets and Stealth heads. I know the Stealth heads are not the best but they are what I could afford at the time. I am now stepping up to a better head package so that is why the post. If it helps the Stealth heads have been worked over pretty good they flow 292 @.600 lift on the intake.
Thanks,
Digger73 (Mike)
[Re: Digger73]
#2445620
02/03/18 02:01 PM
02/03/18 02:01 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Std port Victors, when properly modified work very well....... But they are pretty far down the "bang for the buck" list.
Much higher up that particular list, while staying with the Victor theme would be the std port CNC ported Pro Comp head. Buy them bare, have the valve job redone, install quality parts..... And you'd be good to go.
However, if you really want to wake up that 500" motor, especially for drag use only......... just step away from the std port heads.
Get the TF 270's and a MW manifold to go with them.
[Re: WedgeFED]
#2445625
02/03/18 02:09 PM
02/03/18 02:09 PM
fast68plymouth
So. Burlington, Vt.
I just gotta ask why does nobody like or recommend the B1BS head? Hope I am not asking in the wrong place. Compared to what else is available now, they just aren't very high on the bang for the buck list anymore. They have a few quirks that some other choices don't........ And IMO, they don't do anything "better" than other current choices. That, along with them being about the worst for header fitment/spark plug access in a regular door car doesn't help the sales volume. They can make good power and are well made......I just feel for whatever the application.....some other head would make a better option.
[Re: Digger73]
#2445649
02/03/18 02:44 PM
02/03/18 02:44 PM
Posts: 31,029 Oregon
AndyF
Thanks, Digger73 (Mike) Standard port would be the Trick Flow 240 heads. Max Wedge is the Trick Flow 270 heads. If you have a standard port Super Victor then it could be opened up to a MW Super Victor without a huge amount of work or just sell it and buy a MW Super Victor. The MW setup would make more power in a race car, especially with a Dominator carb and a big cam. The 270 heads are also easier to work with since they overlap the valley plate for a good seal. The 240 heads require some "trickery" to get them to seal to a solid valley plate. Trick Flow 270 heads right out of the box with a Super Victor intake, a big roller cam and a Dominator carb should make a solid 700 hp. It should be a bolt together setup. Here is a comparison between the heads: http://www.hotrod.com/articles/dyno-day-trick-flow-270-mopar-heads/I'll have this 470 with 270 heads back on the dyno next week testing some new valve springs. I'm shooting for 800 hp on pump gas so my compression is less than yours.
[Re: Digger73]
#2445667
02/03/18 03:15 PM
02/03/18 03:15 PM
Digger73
Portland, Oregon
So if I am reading this right the 270 heads are the way for me to go. I will need to get new rocker arms and intake to make the swap. Would you recommend 1.6 over 1.5? As long as I am having to redo the manifold is there a better choice than the Super Victor?
BTW, Andy would you like to buy your Super Victor std port back? LOL
[Re: Digger73]
#2445678
02/03/18 03:45 PM
02/03/18 03:45 PM
Digger73
Portland, Oregon
Andy,
Thank you so much. This is great information. I was under the impression that I had to change the intake to a MW for the heads to work period. I also thought that with the MW runners that the rockers had to be upgraded to offset intakes. You just made my decision that much easier. 270 Trick Flow here I come!
Forgot to add, I have Crane gold roller 1.5 rockers now.
[Re: Digger73]
#2445713
02/03/18 04:55 PM
02/03/18 04:55 PM
fast68plymouth
So. Burlington, Vt.
As was mentioned, the std port SV can be opened up to MW size. No need to buy another manifold.
[Re: Digger73]
#2445716
02/03/18 05:07 PM
02/03/18 05:07 PM
fast68plymouth
So. Burlington, Vt.
We are all talking about the same thing, right?
A "Super Victor", #2891........ Not a "Victor" #2954.
From what I can gather, the 2893(MW size SV) is just a 2891 with the port openings CNC'd out to the MW size.
[Re: Digger73]
#2445724
02/03/18 05:19 PM
02/03/18 05:19 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I think the Trick flow heads a are a good bang for the buck head. I like the 240 I got, but that is a mild street engine. For a 500"+ engine with a big cam, that is used for racing, the larger ports is what you want.
On the B1BS head question, The heads are a nice quality part, but are not as price competitive as most of the other heads. For Example the basic unported (standard port opening) B1Bs head only flows 295 cfm and costs $1,069.84 bare, $1,354.03 with springs and steel retainers, and $1,465.40 with springs and Ti retainers. Price per each head. The thing with the standard B1Bs is it has nice small 65cc chambers that help boost compression on stock engines, but it also can make compression too high in many performance or stroker builds. The B1BS head also requires an offset intake rocker arm design adding cost to a head that unported flows about near same as an Edelbrock RPM or milidly ported Stealth head that do not require the offset rocker arms.
The STS CNC ported version of the B1BS flows 348 cfm, and costs $2,475.15 with springs and Ti retainers. That is the cost for one cylinder head. It had been awhile since I looked into those heads, but I thought they are opened up to Max Wedge port size, and the chambers opened up too a larger 80 CC volume.
The CNC ported B1BS is actually more expensive than the B1 MO head that flows 396 cfm, and costs $2,032.58 with springs and Ti retainers.
I haven't look at the price of the Stage V hemi conversion heads in several years, but likely not much more than the STS CNC ported heads?
[Re: Digger73]
#2445730
02/03/18 05:34 PM
02/03/18 05:34 PM
fast68plymouth
So. Burlington, Vt.
The STS CNC ported version of the B1BS flows 348 cfm, and costs $2,475.15 with springs and Ti retainers. That is the cost for one cylinder head. Roughly twice as much as a TF270 with comparable hardware, and it flows about the same...... but doesn't require the offset rockers or special headers.
