2x4 on Hemi vs 1x4 ?
#2445369
02/02/18 09:03 PM
02/02/18 09:03 PM
Posts: 1,377 Houston,Tx.
Lee446
Houston,Tx.
I asked in another post about true cfm flow on large 4150 carbs and never got a really straight answer. Maybe if I explain my situation better, I can get the info that will help me make a decision on carburetion choices. I have a 528 Hemi, built for me by Dave Dudek that produced 712 hp on the dyno at Modern cylinder heads. We had some issues with the 800 cfm AFB's that were on the highly modified factory 2x4 intake. We switched to Daves 900+ cfm F.A.S.T carbs, and the HP jumped from 650 to 712. I sent my new 800's to Dale Cubic and he went thru them and said he could not really find anything wrong with them and he ran them singly on his test engine and called them good. I got them back and with a lot of testing with my Fast dual o2 sensor A/F finally got the jetting and metering rod combo right, it runs well, idles well, has acceptable cruise (13.8). I keep thinking of trying the Indy 4150 1x4 intake and was wondering how running a approx 1000+ cfm 4150 carb will work, performance wise, to running 1600cfm that I have or the 1800 cfm that we used on the dyno? I really am not interested in a Dominator as I don't really think they have improved them to where you would say that they are a GREAT street carb, but I try to be open minded. My car is 98% street and highway driven, so that is where I am coming from and looking for solid advice as I don't want to give up any horsepower for the simplicity of a single carb. Thanks, Lee.
Re: 2x4 on Hemi vs 1x4 ?
[Re: Lee446]
#2445372
02/02/18 09:11 PM
02/02/18 09:11 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Some of the benefits of a dual carb application is that there is one venturi feeding each intake port and each port runner is usually a lot straighter shot to the head than any given X style single four manifold. Depending on venturi bore and booster design & size, you might be able to squeeze some more flow out of a set of 4150's. The question is can your engine take advantage of it.
[Re: Lee446]
#2445386
02/02/18 09:50 PM
02/02/18 09:50 PM
Thumperdart
State of confusion
I asked in another post about true cfm flow on large 4150 carbs and never got a really straight answer. Maybe if I explain my situation better, I can get the info that will help me make a decision on carburetion choices. I have a 528 Hemi, built for me by Dave Dudek that produced 712 hp on the dyno at Modern cylinder heads. We had some issues with the 800 cfm AFB's that were on the highly modified factory 2x4 intake. We switched to Daves 900+ cfm F.A.S.T carbs, and the HP jumped from 650 to 712. I sent my new 800's to Dale Cubic and he went thru them and said he could not really find anything wrong with them and he ran them singly on his test engine and called them good. I got them back and with a lot of testing with my Fast dual o2 sensor A/F finally got the jetting and metering rod combo right, it runs well, idles well, has acceptable cruise (13.8). I keep thinking of trying the Indy 4150 1x4 intake and was wondering how running a approx 1000+ cfm 4150 carb will work, performance wise, to running 1600cfm that I have or the 1800 cfm that we used on the dyno? I really am not interested in a Dominator as I don't really think they have improved them to where you would say that they are a GREAT street carb, but I try to be open minded. My car is 98% street and highway driven, so that is where I am coming from and looking for solid advice as I don't want to give up any horsepower for the simplicity of a single carb. Thanks, Lee. If you call 15+ mpg and winning Drag Week with a Dommy "not improved" I'm not sure what is but the RIGHT t-rams make great power and have nice distribution..........
[Re: Lee446]
#2445630
02/03/18 02:18 PM
02/03/18 02:18 PM
Lee446
Houston,Tx.
Thumper,I know you build a hell of a good carb, and I honestly just don't know that much about Dominators, BUT, My street car gets driven on Power Tours(2) Road trips to Woodward in Detroit (5) The last Woodward trip with the Hemi and a Mopar cross-ram with two 770 Holleys that still squeezed out 8 mpg at a 65 mph cruise cross-country. This is what I do with my car with nothing but a change of rear tires. Are you telling me a Dominator is a very good choice for that and if you are, could you please help me understand which type would work best? 2 circuit, 3 circuit, old/new.... Cause I would not know where to start.
Andy, when you first posted the results on the FE build, I posted that I would be looking forward to seeing info on setting up and tuning a dual throttle body FI, as yours is the first story I have seen on Duals.... lots of stories on singles out there, but my experience with setting up dual 4 barrels properly was a big learning experience over single quad and 6 packs that I am familiar with. I know you have a lot on your plate, but if you ever write an article on just what all is involved in tuning that set-up for max performance on the street, I will buy that book/magazine in a minute and I am sure many others would too!
Dave, your reply really puzzles me? I worked long and hard to get my dual quad setup right, it performs really well. There is always room for improvement, there is always something to be learned. If we all had the "Good Enough" attitude, we would all be driving our old Mopars around in mid 14 second trim. No Demons, Hellcats, Z06 vettes, who would have thought, 10 years ago, that we would see 9 and 10 second factory cars on the showroom floor? I guarantee you that our hobby was instrumental in driving this trend. The day I stop experimenting on my old Mopars will be the day they put me in the ground, I've been at it for over 45 years and I'm not done yet!
I have been running/bracket racing RB six pack cars for years. I can't tell you how many times at local Mopar events, a Hemi car would venture out on the track and make a pass blowing black over rich exhaust on the way to a underwhelming 15 second pass, it was embarrassing to see. I always said that if I ever got the money to build a Hemi, if it would not run at least mid 10's in street trim, I would sell it. I have not sold it. With Demons running 9's though, I would like to hold up for our side a bit better! Lee.
[Re: Lee446]
#2445689
02/03/18 04:11 PM
02/03/18 04:11 PM
Posts: 4,209 New York
polyspheric
New York
w/r/t highly modified factory 2x4 intake: which one? What mods?
Boffin Emeritus
[Re: Lee446]
#2446010
02/04/18 01:49 AM
02/04/18 01:49 AM
polyspheric
New York
I'll just assume, by the general lack of response, that one of two things is true: 1. I'm wrong because [insert famous name here] said so, or 2. everyone already knew that
Less work for me.
Boffin Emeritus
[Re: Lee446]
#2446011
02/04/18 01:49 AM
02/04/18 01:49 AM
Posts: 3,505 DFW
mr_340
DFW
A friend put a Dominator on his Buick GSX clone. It idled well and made great power for a pump gas engine. He had Scotty McLendon do the carb. http://www.amfibi.com/us/c/2915160-c781f367
Floyd Lippencott IV
[Re: Lee446]
#2446071
02/04/18 05:12 AM
02/04/18 05:12 AM
Posts: 43,232 Bend,OR USA
Cab_Burge
I have a new 572 C.I. pump gas street Hemi with a set of Stage V heads and intake with dual 1150 dry EFI throttle bodies that will have the Holley Dominator EFI system on it. Rich at Fastman EFI will tune it for me soon, I'm waiting for the Stage V cast aluminum valve covers to get engraved and polish so I can finish the final assembly, plumbing and wiring on it before trying to dyno it. I'll post the results on here when it is done This is for street driver E body 1970 Challenger show type car, not a fast street and strip car, dang it This will be the first N/A EFI Hemi motor I've built and had tuned for straight pump gas, I'm hoping for 800 + HP at or below 7500 RPM
[Re: Lee446]
#2446198
02/04/18 01:58 PM
02/04/18 01:58 PM
Posts: 12,174 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
When I built the 540 for my Cuda, I knew based on my wedge experience that it would want a Dominator sized carb. I didn't want the additional complexity of duals and didn't want to spend the extra coin on an EFI system that would be obsolete (and maybe unsupported) in a few years (months?).
So the big question was which intake. I talked to quite a few people whom I felt knew what they were talking about. The big Barton was many guy's first choice for a single application.
At the Indy Cylinder Head show a couple of years ago, I stopped and talked to Ken about his recommendation. With my build info and a table full of different intakes, he recommended the Dominator flanged, dual plane.
I was skeptical. Enough so that I bought both a single and a dual plane intake and ran them back to back on the dyno.
The dual made over 30 lb more torque and only gave up 11 hp @ 6,800.
For my street car, that rocks. With that intake and ThumperDart's tune in the carb, the thing idles great and the throttle response is very crisp.
Master, again and still
[Re: DaveRS23]
#2446283
02/04/18 03:52 PM
02/04/18 03:52 PM
Lee446
Houston,Tx.
Dave Hall, you have contributed absolutely nothing to this post, in the spirit of your contributions, my advice to you is sell your race car and buy a Prius. That, and run a survey on Moparts about who can't feel 50 hp and who is willing to give it up cause Dave says you don't need it. Polyspheric, I read the post before you deleted it!!??!! You brought up many good points, and one reason I have been thinking about going to a single 4 or trying out the new Edelbrock 2x4 is that, even with my limited knowledge of intake modifications, I know that distribution issues, puddling, etc, are almost assuredly occurring, it makes power at the top, but is not the best choice on a street car and yes, originally I had the manifold modded to keep everything appearing stock, just like you can't tell a 426 from a 528 on the outside. You can't take the old street racer out of me and stealth was the name of the game back in the day.
Merc, thanks for all the great info! I would be thrilled to have a 9 second street car, you are my hero! Very good facts, you have a bit bigger Roller than I do, heads flow almost identical, now ya got me thinking! Trouble is, my car with me in it is 4200 lb. race weight and I'm not taking the A/C or the PS out(69 Satellite)and my 225 lb could use a 20 lb. trimming!
Cab, As usual, I will be waiting eagerly to hear how your build comes out, you always make good and interesting contributions to help everybody out.
DaveRS23, I appreciate your input and real world experience, it is very helpful! I have looked at the indy and the Barton, not really a whole lot of choices for modern single 4 intakes for gen 2 Hemi's. You spent the money to find out what was best for you and you share this info to help everyone else out and I really appreciate it, gives me direction! Lee.
