2003 5.7 in 2007 Ram 2500 #2445314
02/02/18 06:37 PM
02/02/18 06:37 PM
Canada
WO23Coronet Offline OP
Canada
I have an 07 2500 with a popped 5.7. I found a complete but rough 03 2500 with a good running 5.7. I’m thinking this should work as a replacemt as they’re both non MDS(but I have to change over the valvecovers/coils). Just making sure I’m not missing something like a difference in a reluctor wheel etc
Re: 2003 5.7 in 2007 Ram 2500 [Re: WO23Coronet] #2445378
02/02/18 09:27 PM
02/02/18 09:27 PM
Kalispell Mt.
HotRodDave Online content
HotRodDave  Online Content
Kalispell Mt.
should bolt right in like you planning
Re: 2003 5.7 in 2007 Ram 2500 [Re: WO23Coronet] #2447210
02/06/18 12:49 AM
02/06/18 12:49 AM
western PA
mopar4ya Offline
mopar4ya  Offline
western PA
03 is a time bomb unless it has already been fixed. They were known for breaking the valve springs, dropping the valve and destroying the piston and cylinder wall. Just a heads up.
Re: 2003 5.7 in 2007 Ram 2500 [Re: WO23Coronet] #2447567
02/06/18 07:32 PM
02/06/18 07:32 PM
Canada
Canada
The truck has 330K kms (200K miles) and the engine was supposedly rebuilt at 150K kms (90K miles). It runs extremely well and has absolutely no hemi tick. If it hasn’t blown up yet I’m doubtful it will at this point. I’m probably going to use the whole motor/trans/transfer case
Re: 2003 5.7 in 2007 Ram 2500 [Re: WO23Coronet] #2448130
02/07/18 06:31 PM
02/07/18 06:31 PM
Kalispell Mt.
Kalispell Mt.
Valve springs are easy and cheap to replace and can be done without pulling the heads, they typically start breaking around 100,000-150,000 miles and just because someone somewhere rebuilt the engine does not mean they were replaced then if they were not broken yet. The only time I have seen seats fall out is if they fell out when the engine overheated. Rods can randomly break on 03-08 hemis and I have seen them go between 90,000 and 300,000 without breaking, seems totally random. I have a bucket of broken rods and bearings mostly look brand new.
Re: 2003 5.7 in 2007 Ram 2500 [Re: HotRodDave] #2448142
02/07/18 06:52 PM
02/07/18 06:52 PM
Canada
Canada
I hear you, but when we’re dealing with old miled out vehicles like this you have to take a leap of faith. I’ll probably do valve springs and a timing chain while it’s out.
Re: 2003 5.7 in 2007 Ram 2500 [Re: WO23Coronet] #2448224
02/07/18 10:09 PM
02/07/18 10:09 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Reluctor wheel was changed in 09.
your good to go.
Re: 2003 5.7 in 2007 Ram 2500 [Re: WO23Coronet] #2448264
02/07/18 11:35 PM
02/07/18 11:35 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I took that leap a few months back... 14 miles later I had a rod knock. I highly recommend checking all the bearings.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
