Performance Hyper pistons stronger than factory utectics?
#2444716
02/01/18 04:12 PM
02/01/18 04:12 PM
Posts: 274 Granbury TX
Prochargedmopar
Granbury TX
Are the KB and Speed Pro hypers stronger than a BONE STOCK LS cast aluminum utectic piston?
Or does the factory GMs kick the aftermarkets bootie??
I’m trying not to waste 4-$700 in my budget mopar build.
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
Re: Performance Hyper pistons stronger than factory utectics?
[Re: Prochargedmopar]
#2444736
02/01/18 04:53 PM
02/01/18 04:53 PM
crabman173
crabman173
Wiseco Street Protru is forged light weight 440 piston for street builds comes with rings and is BY Far the best value out there at around $450 a set that is less than KB cast junkers that weigh a ton so no need to compare heavy cast stuff
[Re: ]
#2444751
02/01/18 05:33 PM
02/01/18 05:33 PM
Prochargedmopar
Granbury TX
Wiseco Street Protru is forged light weight 440 piston for street builds comes with rings and is BY Far the best value out there at around $450 a set that is less than KB cast junkers that weigh a ton so no need to compare heavy cast stuff So yourcalling factory LS pistons cast junk? Maybe thise that come in a gen 3 hemi are but what makes a LS piston better than a KB or SP hyper?
[Re: merpar]
#2444854
02/01/18 08:55 PM
02/01/18 08:55 PM
Prochargedmopar
Granbury TX
Right on EV2Bird. The application is critical. United Engine & Machine who manufactures KB hypereutectic pistons and Icon forged pistons has an application chart in relation to silicon content. I have it but don't know how to load it on here. It may be on their web site by now. UEM was the innovators of the KB hypereutectic pistons. Their primary purpose is for performance street use. But can be used in race applications of limited rpm motors. Just remember, on any hypereutectic piston the ring end gaps are very critical. Follow the directions that come with the pistons. I would use a little extra gap so .032 to .034 Street supercharged on e85 https://www.uempistons.com/installation_instructions/kb_installation.pdf
[Re: Porter67]
#2444901
02/01/18 10:36 PM
02/01/18 10:36 PM
crabman173
crabman173
Hyperutectic pistons are stronger than any cast or forged piston.
I dont think thats being disputed, just the proper application for certain pistons is.
In a 440 application the KB is heavy as an anvil That is not good
[Re: WedgeFED]
#2444959
02/02/18 12:16 AM
02/02/18 12:16 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
. Hyperutectic pistons are stronger than any cast or forged piston. I've seen plenty of cast pistons explode like a hand grenade into tiny little pieces in the bottom of the oil pan when abused when the same amount of abuse to a forged piston didn't do that Have you seen a cast piston come out of a motor that broke off one of the heads of valve with the valve stem or valve head stuck into the piston still? I haven't, but I do have several forged piston in my broken race part boxes that did Build the motor for the intended application and use the parts that you think will live and work the best
