A-Body 3 spd 4 spd ? #244484
03/05/09 10:26 PM
03/05/09 10:26 PM
Omaha
DEMONIC Offline OP
DEMONIC  Offline OP
Omaha
I have always had Automatic transmissions so when a friend asked a question I told him I would post it on moparts for him.
Here is the question.
Are A-Body 3 speed and 4 speed Bellhousings interchangeable?
Which is more rare on an A_body a 3 or a 4 speed?
Thanks Guys
Re: A-Body 3 spd 4 spd ? [Re: DEMONIC] #244485
03/05/09 10:36 PM
03/05/09 10:36 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Same bell housing for either. What's more rare depends on what year & model car you have, it's about 50% each on average, 3 speed was the base trans most years so quite a few were made, 4 speed was an extra cost option and most prefer them.
Re: A-Body 3 spd 4 spd ? [Re: ScottSmith_Harms] #244486
03/05/09 11:03 PM
03/05/09 11:03 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
I wouldnt say they are completely interchangable. It would depend on the diameter of the input bearing retainer
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: A-Body 3 spd 4 spd ? [Re: 69L78Nova] #244487
03/05/09 11:04 PM
03/05/09 11:04 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
To clearify, 1970-71 (and possibly later) was what I was talking about.
Re: A-Body 3 spd 4 spd ? [Re: ScottSmith_Harms] #244488
03/05/09 11:30 PM
03/05/09 11:30 PM
IMGTX Offline
IMGTX  Offline
Just to throw a kink in the machine but /6's didn't have the dual bolt pattern bellhousings like the V-8's did until late. Around 76 or later when they started the OD 4 speeds.
He didn't say what engine.
Re: A-Body 3 spd 4 spd ? [Re: IMGTX] #244489
03/05/09 11:47 PM
03/05/09 11:47 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
He didn't say allot of things we'd need to know to really nail down his question
Re: A-Body 3 spd 4 spd ? [Re: ScottSmith_Harms] #244490
03/05/09 11:52 PM
03/05/09 11:52 PM
Slightly off topic, We used an A230 3 speed from a 70's A body(I believe) on our circle burner(9-1 2bbl 360) & nary a problem. Syncho in 1st also.
Re: A-Body 3 spd 4 spd ? [Re: ScottSmith_Harms] #244491
03/06/09 12:20 AM
03/06/09 12:20 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Standard or O.D A-833?
Re: A-Body 3 spd 4 spd ? [Re: ScottSmith_Harms] #244492
03/06/09 02:29 AM
03/06/09 02:29 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Or maybe ask the question before saying no issue, when in fact, it may very well be an issue.
Then employing the motorboat... but but but but
Re: A-Body 3 spd 4 spd ? [Re: RobX4406] #244493
03/06/09 02:50 AM
03/06/09 02:50 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Where's the fun in that?
Re: A-Body 3 spd 4 spd ? [Re: ScottSmith_Harms] #244494
03/06/09 09:14 AM
03/06/09 09:14 AM
Omaha
DEMONIC Offline OP
DEMONIC  Offline OP
Omaha
The friend that asked me has a 1972 Dodge Demon 340 with a 3 speed. He wanted to know if he could put a 4 speed trans in it and still use his same bell housing.
Thanks for the help guys.
Re: A-Body 3 spd 4 spd ? [Re: DEMONIC] #244495
03/06/09 10:28 AM
03/06/09 10:28 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Great, then my assumption paid off, the answer is yes (still) but he'll need to use a 4 speed with the correct front bearing retainer size as mentioned above by another poster.
Re: A-Body 3 spd 4 spd ? [Re: ScottSmith_Harms] #244496
03/06/09 08:31 PM
03/06/09 08:31 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
NOt all bellhousings are dual drilled, both 3 and 4 speed patterns. General rule of thumb, iron bell = not dual drilled, aluminum = dual drilled.
Don't be the exception.
