Largest 4150 carb? #2443802
01/31/18 12:48 AM
01/31/18 12:48 AM
Houston,Tx.
Lee446 Offline OP
Lee446  Offline OP
Houston,Tx.
I am curious as to what is the biggest 4150 based carb available in true CFM not inflated or misleading hype.
Re: Largest 4150 carb? [Re: Lee446] #2443806
01/31/18 01:00 AM
01/31/18 01:00 AM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
When I was looking the QF 1050 and this Holley had the venturi size, I went with the Holley. Great carb!
https://www.summitracing.com/parts/hly-0-80805hbx/overview/
Have a great day
Iowan
"obsolete is neat"
Re: Largest 4150 carb? [Re: Iowan] #2443810
01/31/18 01:15 AM
01/31/18 01:15 AM
Houston,Tx.
Lee446 Offline OP
Lee446  Offline OP
Houston,Tx.
Thats what provoked my question and what started it all was several years ago when it came out that the Holley HP 950 was closer to 850 cfm. I see carbs rated at 1050 but wonder how many of them really are and that includes Holley.
Re: Largest 4150 carb? [Re: Lee446] #2443837
01/31/18 01:49 AM
01/31/18 01:49 AM
Great Neck,LI,new york
hemi-itis Online content
hemi-itis  Online Content
Biggest single carb is made by Pto Systems,the SV1 can flow over 2500 CFM.
http://www.prosystemsracing.com/svseries.html
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Largest 4150 carb? [Re: Lee446] #2443870
01/31/18 02:33 AM
01/31/18 02:33 AM
The original Holley # 80496 950 CFM rated didn't flow close to that number, I had several of them flowed, they all flow under 900 CFM whiney
I haven't had any of the newer Holley HP flowed but I believe when Quicf Fuel came out with their version of the HP type carbs that did flow as advertised Holley had to keep up shruggy
The early HP carbs., including the HP950, worked great out of the box, including the replacement HP Dominator carbs. with the smooth tops up
Not all the Holley race carbs. work great out of the box, same as other brands like Barry Grant, Carters and Edlebrocks shruggy
Re: Largest 4150 carb? [Re: Lee446] #2443877
01/31/18 02:46 AM
01/31/18 02:46 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
interesting in the linked ad for the Holley there is no mention of venturi or throttle plate size. I would think that would make a difference in how much air it would allow to flow. Braswell B-4825 Series carburetor is offered with venturi sizes from 1.40" up through 1.68", and throttle bores of 1.688", 1.750", or 1.790. Mine happens to have a 1.48 venturi/1.79 throttle bore. I don't have a 4500 intake fitted to my W8 so I bought a 4825 to play with in the mean time.
Re: Largest 4150 carb? [Re: Lee446] #2443881
01/31/18 03:01 AM
01/31/18 03:01 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
The “linked ad” is just the summit page. Go to Holleys website. It’s got all the specs.
Re: Largest 4150 carb? [Re: Lee446] #2443892
01/31/18 03:19 AM
01/31/18 03:19 AM
Canada
RobR Offline
RobR  Offline
Canada
The Quick fuel P series... P1050 flowed 1050
link to picture
https://imgur.com/a/VcnLb
Re: Largest 4150 carb? [Re: Lee446] #2443894
01/31/18 03:22 AM
01/31/18 03:22 AM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I agree, I was just showing you what worked for me. Bit like said its super carb, ran it on the dyno first and only had to set the floats and adjust the idle.......👍
One more thing, my cam has 274/285 @ 050 duration and with this carb I got a clean idle @ 900 rpm and that's something my 850 could not do.
Have a great day
Iowan
"obsolete is neat"
Re: Largest 4150 carb? [Re: J_BODY] #2443918
01/31/18 07:26 AM
01/31/18 07:26 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Wow , that makes you wonder whether like you one of these may be an easier option than a 4500 carb . Save over adapters or more intakes .
What is the ball park $
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Largest 4150 carb? [Re: Lee446] #2443959
01/31/18 11:30 AM
01/31/18 11:30 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I ran a 1000cfm AED on the Arrow for years. Last year I had some issues with it and put my old Ray Murray 850 back on....saw no changes other than I was going rounds again lol
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Largest 4150 carb? [Re: tex013] #2443970
01/31/18 12:01 PM
01/31/18 12:01 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Tex
not sure new.... I picked mine up of Racingjunk. Like I said, I was just looking for something to use as all I had was my BG 750. I should throw that on again one day and see how it runs compared. I only did that once when the combo was brand new. I did put an adapter on it and ran our 4500 1050 on once occasion. Didn't 60 as hard and ran a bit slower due to that. Was an 1/8th mile track though. Maybe top end on a 1/4 track would have shown some improvement. Of course every combo is different. Mines limited by a rather mild camshaft.
Re: Largest 4150 carb? [Re: Lee446] #2444034
01/31/18 01:52 PM
01/31/18 01:52 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If you look at the venturi and throttle bore diameter for both a 4500 and 4150 "1050" it will be readily apparent they aren't going to flow the same.
Re: Largest 4150 carb? [Re: hemi-itis] #2444045
01/31/18 02:20 PM
01/31/18 02:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not a 4150..........The BLP billet 1.610 bore 4150's flow 1040+ and the oval blade stuff I hear flows gobs more but never messed w/one yet. When in doubt go Dominator............. beer
Re: Largest 4150 carb? [Re: fast68plymouth] #2444833
02/01/18 08:24 PM
02/01/18 08:24 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Yep. Mr. Smoke meet Mr. Mirrors... they can't BOTH flow 1050 CFM at the same test pressure.
At least one big-name racing carburetor builder doesn't even give a CFM rating the last I heard: Braswell. It's all about venturi size, throttle plate size, and booster style.
Here's a question for you: Which of the following flows the most? They're ALL 4150 carbs with 1.75" throttle plates.
1. BG Demon RS 1.425 venturi & downleg boosters
2. BG Gold Claw 1.500 venturi & downleg boosters
3. QFT/Proform 1.45 venturi & downleg boosters
4. QFT/Proform 1.52 venturi & downleg boosters
5. QFT/Proform 1.59 venturi & annular boosters
6. Holley Ultra 1.58 venturi & downleg boosters
7. Holley Ultra 1.60 venturi & annular boosters
The answer: It doesn't matter.
What does matter is which carb works the best on the track with a particular combination... at least, IMO.
Re: Largest 4150 carb? [Re: Lee446] #2444848
02/01/18 08:38 PM
02/01/18 08:38 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
^ i'd guess the 1.58 venturi with downleg booster would flow the most.
but for any motor i'd build i'd probably want 1.45 or 1.52 venturi with annular booster...
Re: Largest 4150 carb? [Re: Lee446] #2444853
02/01/18 08:53 PM
02/01/18 08:53 PM
So. Burlington, Vt.
So. Burlington, Vt.
Get that flow bench put back together and you can answer that question wink
Re: Largest 4150 carb? [Re: krautrock] #2444855
02/01/18 08:56 PM
02/01/18 08:56 PM
BradH Offline
BradH  Offline
Originally Posted By krautrock
... 1.45 or 1.52 venturi with annular booster...
Annulars shouldn't be necessary on a carb with venturi that small.
Annular boosters are a bigger obstruction to air flow, which is why most successful applications using annulars that I've seen have been on 1.56" & larger venturi. All those small(er)-venturi annular carbs that Quick Fuel offers make no sense to me...
Re: Largest 4150 carb? [Re: fast68plymouth] #2444856
02/01/18 09:01 PM
02/01/18 09:01 PM
BradH Offline
BradH  Offline
Better than I get the MoPig back together so that I can answer the more important question: How many of my seven (7) carburetors can I sell once I figure out which one(s) work the best ON THE CAR?
I got waaaaayyyy too much $$$ tied up in those things. realcrazy
Re: Largest 4150 carb? [Re: Lee446] #2444874
02/01/18 09:34 PM
02/01/18 09:34 PM
So. Burlington, Vt.
So. Burlington, Vt.
Well, the answer to how many is easy....... 5 or 6........depending if you can get the quickest one to be adequately street friendly or not.
The harder question to answer will be....... Which one or two to keep?
