Adjustable or Non-adjustable Clutch Advise Needed
#2444785
02/01/18 06:47 PM
02/01/18 06:47 PM
Posts: 356 NE
moparpoolman
NE
After seeing the "Soft Lok Thread", I didn't want to hijack so started a new one. I keep breaking the 18 spline A833, blow all the teeth off third gear on the cluster. Broke 3 in the last 8 years only going to the track about 5 times a year. Car is a 68 Plymouth b body, A833 with a centerforce clutch, 420HP to the rear tires with a 4.10 Dana that I don't drive on the street? Is an adjustable clutch my answer? What other adjustable clutches like a McLeod Soft Lok are available? The "clutchtamer" http://clutchtamer.com/ sounds interesting, anyone run one? I'm wondering what I should do?? Different disc? get away from the cenerforce and go with a regular Ram or Mcleod? switch to an adjustable clutch? or maybe try a clutchtamer with it the centerforce??? The more I research it the more confused I'm getting, HELP?
Re: Adjustable or Non-adjustable Clutch Advise Needed
[Re: moparpoolman]
#2444787
02/01/18 06:50 PM
02/01/18 06:50 PM
Posts: 4,457 Washington
madscientist
Washington
I run an adjustable. When I started with a sintered iron disc I couldn't get an adjustable pressure plate.
Would you want a carb you couldn't tune? Clutch is the same. I'd rather have an adjustable clutch.
[Re: moparpoolman]
#2444805
02/01/18 07:24 PM
02/01/18 07:24 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
After seeing the "Soft Lok Thread", I didn't want to hijack so started a new one. I keep breaking the 18 spline A833, blow all the teeth off third gear on the cluster. Broke 3 in the last 8 years only going to the track about 5 times a year. Car is a 68 Plymouth b body, A833 with a centerforce clutch, 420HP to the rear tires with a 4.10 Dana that I don't drive on the street? Is an adjustable clutch my answer? What other adjustable clutches like a McLeod Soft Lok are available? The "clutchtamer" http://clutchtamer.com/ sounds interesting, anyone run one? I'm wondering what I should do?? Different disc? get away from the cenerforce and go with a regular Ram or Mcleod? switch to an adjustable clutch? or maybe try a clutchtamer with it the centerforce??? The more I research it the more confused I'm getting, HELP? I have a '68 Roadrunner with a stock (except slick shifted)18 spline tranny. I also run a Center force. I have NEVER broken a tranny part. I run several races a year(around 7-10). Engine makes around 600+ hp and I also run a Dana but with 4.56 gears. Car weighs in around 3926 with me in it. My car is mostly street driven. I do run slicks when racing.?????????? Plus. How do you shift (granny shift or power shift)? Granny shifting is very hard on gears.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: 68LAR]
#2444847
02/01/18 08:38 PM
02/01/18 08:38 PM
Posts: 356 NE
moparpoolman
NE
After seeing the "Soft Lok Thread", I didn't want to hijack so started a new one. I keep breaking the 18 spline A833, blow all the teeth off third gear on the cluster. Broke 3 in the last 8 years only going to the track about 5 times a year. Car is a 68 Plymouth b body, A833 with a centerforce clutch, 420HP to the rear tires with a 4.10 Dana that I don't drive on the street? Is an adjustable clutch my answer? What other adjustable clutches like a McLeod Soft Lok are available? The "clutchtamer" http://clutchtamer.com/ sounds interesting, anyone run one? I'm wondering what I should do?? Different disc? get away from the cenerforce and go with a regular Ram or Mcleod? switch to an adjustable clutch? or maybe try a clutchtamer with it the centerforce??? The more I research it the more confused I'm getting, HELP? I have a '68 Roadrunner with a stock (except slick shifted)18 spline tranny. I also run a Center force. I have NEVER broken a tranny part. I run several races a year(around 7-10). Engine makes around 600+ hp and I also run a Dana but with 4.56 gears. Car weighs in around 3926 with me in it. My car is mostly street driven. I do run slicks when racing.?????????? Plus. How do you shift (granny shift or power shift)? Granny shifting is very hard on gears. Can you please explain how you granny shift and how you power shift? I always thought power shifting was harder on gears..but maybe I'm doing something wrong...by the way the most recent casualty was a Liberty Pro shift
[Re: moparpoolman]
#2444876
02/01/18 09:41 PM
02/01/18 09:41 PM
68LAR
South Park, Pa.
After seeing the "Soft Lok Thread", I didn't want to hijack so started a new one. I keep breaking the 18 spline A833, blow all the teeth off third gear on the cluster. Broke 3 in the last 8 years only going to the track about 5 times a year. Car is a 68 Plymouth b body, A833 with a centerforce clutch, 420HP to the rear tires with a 4.10 Dana that I don't drive on the street? Is an adjustable clutch my answer? What other adjustable clutches like a McLeod Soft Lok are available? The "clutchtamer" http://clutchtamer.com/ sounds interesting, anyone run one? I'm wondering what I should do?? Different disc? get away from the cenerforce and go with a regular Ram or Mcleod? switch to an adjustable clutch? or maybe try a clutchtamer with it the centerforce??? The more I research it the more confused I'm getting, HELP? I have a '68 Roadrunner with a stock (except slick shifted)18 spline tranny. I also run a Center force. I have NEVER broken a tranny part. I run several races a year(around 7-10). Engine makes around 600+ hp and I also run a Dana but with 4.56 gears. Car weighs in around 3926 with me in it. My car is mostly street driven. I do run slicks when racing.?????????? Plus. How do you shift (granny shift or power shift)? Granny shifting is very hard on gears. Can you please explain how you granny shift and how you power shift? I always thought power shifting was harder on gears..but maybe I'm doing something wrong...by the way the most recent casualty was a Liberty Pro shift These are "old" terms. Granny shifting is very hard on gears because you "unload" and "load" the gears by lifting off the gas between shifts. Power shifting is done by keeping the gas pedal on the floor between shifts. No loading and unloading of the gears..
[Re: moparpoolman]
#2444883
02/01/18 09:57 PM
02/01/18 09:57 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I ran a 600hp 440 in my Cuda weighing close to 3,000 pounds with 32x14 slicks. Used a Hemi box with Liberty lugs. I ran it with a Ram B&B plate, and metallic disc. Never had any issues running as fast as 9.90. I know some guys running heavy pressure plates are using a rag disc to soften the hit. That might be an option for you. If you are tearing up Hemi boxes on a regular basis, you will probably hurt a Nash tranny also. A Long style clutch might help. They are available preset, non adjustable. The problem is using an adjustable clutch in a stock body. To adjust the pressure plate, you have to remove the trans and bellhousing. And it is a constant maintenance item. Clutchtamer might be the answer, although I have always been skeptical on higher hp engines and how fast it would eat up a clutch.
[image][/image]
[Re: sgcuda]
#2444894
02/01/18 10:12 PM
02/01/18 10:12 PM
madscientist
Washington
I ran a 600hp 440 in my Cuda weighing close to 3,000 pounds with 32x14 slicks. Used a Hemi box with Liberty lugs. I ran it with a Ram B&B plate, and metallic disc. Never had any issues running as fast as 9.90. I know some guys running heavy pressure plates are using a rag disc to soften the hit. That might be an option for you. If you are tearing up Hemi boxes on a regular basis, you will probably hurt a Nash tranny also. A Long style clutch might help. They are available preset, non adjustable. The problem is using an adjustable clutch in a stock body. To adjust the pressure plate, you have to remove the trans and bellhousing. And it is a constant maintenance item. Clutchtamer might be the answer, although I have always been skeptical on higher hp engines and how fast it would eat up a clutch. Lakewood and evidently Hyatt will put a window in your bell housing. Then you don't have to pull all that stuff out.
[Re: 68LAR]
#2444911
02/01/18 10:50 PM
02/01/18 10:50 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Power shifting is done by keeping the gas pedal on the floor between shifts. No loading and unloading of the gears.. Interesting. Dan Brewer told me to not power shift 3rd or there would be damage. Apparently 1st and 2nd are fine, just not 3rd.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: 68LAR]
#2444990
02/02/18 01:18 AM
02/02/18 01:18 AM
Posts: 356 NE
moparpoolman
NE
are you using the clutch? fully? or just tapping?
[Re: OhioMopar]
#2445034
02/02/18 02:48 AM
02/02/18 02:48 AM
Posts: 8,356 fredericksburg,va
cudaman1969
fredericksburg,va
Power shifting is done by keeping the gas pedal on the floor between shifts. No loading and unloading of the gears.. Interesting. Dan Brewer told me to not power shift 3rd or there would be damage. Apparently 1st and 2nd are fine, just not 3rd. Third is where the main shaft and imput mesh, slop-flex with those needle bearings. I've thought of using a bushing there instead.
[Re: cudaman1969]
#2445041
02/02/18 03:31 AM
02/02/18 03:31 AM
madscientist
Washington
Power shifting is done by keeping the gas pedal on the floor between shifts. No loading and unloading of the gears.. Interesting. Dan Brewer told me to not power shift 3rd or there would be damage. Apparently 1st and 2nd are fine, just not 3rd. Third is where the main shaft and imput mesh, slop-flex with those needle bearings. I've thought of using a bushing there instead. Did that. Didn't help.
[Re: madscientist]
#2445156
02/02/18 12:45 PM
02/02/18 12:45 PM
cudaman1969
fredericksburg,va
Power shifting is done by keeping the gas pedal on the floor between shifts. No loading and unloading of the gears.. Interesting. Dan Brewer told me to not power shift 3rd or there would be damage. Apparently 1st and 2nd are fine, just not 3rd. Third is where the main shaft and imput mesh, slop-flex with those needle bearings. I've thought of using a bushing there instead. Did that. Didn't help. Do you think the flex is from the main shaft or the input shaft since its riding on a ball bearing?
[Re: moparpoolman]
#2445161
02/02/18 12:51 PM
02/02/18 12:51 PM
68LAR
South Park, Pa.
are you using the clutch? fully? or just tapping? Fully. Can't tap with stock tranny.
[Re: OhioMopar]
#2445312
02/02/18 06:29 PM
02/02/18 06:29 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Power shifting is done by keeping the gas pedal on the floor between shifts. No loading and unloading of the gears.. Interesting. Dan Brewer told me to not power shift 3rd or there would be damage. Apparently 1st and 2nd are fine, just not 3rd. Liberty gears told me the same thing. I hadn't have a problem until I upgraded my engine to 600 hp. Yep, 3rd gear blew out on the 3rd pass. Completely rebuilt the 833 with new bearings and replaced the broken gears . Tried that one more time . The rebuilt trans after 2 runs sounds like a bunch of bolts being shaken in a metal bucket. The power pushes the input and output shaft away from the 3rd gear = BOOM!!!!!!
[Re: RATTRAP]
#2445329
02/02/18 07:16 PM
02/02/18 07:16 PM
madscientist
Washington
What gear ratio is in the trans you keep breaking is it a 2:65 or a 2:44 I've broken the 2.65, 2.44 and a 3.09 boxes. All this crap about flex and not power shifting third is just that. Crap. If you are breaking the gearbox your clutch is doing it. Most guys can run LESS than a 1000 pounds of static and tune with some counter weight and never break 3rd gear.
[Re: RATTRAP]
#2445341
02/02/18 07:42 PM
02/02/18 07:42 PM
madscientist
Washington
I agree. I have learned clutching is every thing, I just hear that the 2:44 ratio is harder on parts, My self I've never damaged the 4 speed in my car but from what I have learned on the forum I will spend the money on an adjustable clutch and have the bell windowed for access. I was told the same thing. So, I prepped a 2.44 box and broke it. I'm as hard headed as an army mule, so I broke 8-9 boxes before I got sick of it and bought a clutch. Damn I'm dumb. And a slow learner.
