"Correct" paint formula.
#2444349
01/31/18 11:32 PM
01/31/18 11:32 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Who does the best job of putting out the right color/hue/pearl in a paint? Like getting a B5 blue in '69 correct? PPG? Does it all depend on the mix? Also, what is the best way to go for a novice painter? Single stage? Base clear? Thanks.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
Re: "Correct" paint formula.
[Re: OhioMopar]
#2444433
02/01/18 02:07 AM
02/01/18 02:07 AM
Posts: 20,900 A collage of whims
topside
A collage of whims
Different paint manufacturers have different color-matching capability, and some systems require more color coats on a 2-stage than others. The chemistry is different, too. For metallics, 2-stage allows the base color to be corrected before applying clear, whereas single-stage metallics require a real touch to avoid problems. I'd recommend a lot of practice before applying single-stage metallics. For some old colors, you need to find a similar newer color and tint/match to get them right. I've seen a lot of "B5" jobs that have too much red in them, as most blues tend to have now; back then, blues tended to be greener. As an example, IIRC, '68 W1 has black, yellow, and sepia toners in it.
[Re: topside]
#2444536
02/01/18 11:24 AM
02/01/18 11:24 AM
Posts: 10,757 North Dakota
6PakBee
North Dakota
IMHO, nobody has an exact off-the shelf color match for the older acrylic enamels. I have an acquaintance who just went through this in BC/CC for 1969 F6 and it took $600 of sprayouts to get an accurate color match.
[Re: 6PakBee]
#2444547
02/01/18 12:17 PM
02/01/18 12:17 PM
Posts: 18,157 Mass
DAYCLONA
Mass
IMHO, nobody has an exact off-the shelf color match for the older acrylic enamels. I have an acquaintance who just went through this in BC/CC for 1969 F6 and it took $600 of sprayouts to get an accurate color match. Agreed, even "back in the day" using the same paint mfg as OEM could not guarantee a paint match as too many variables can effect the final product, one can still have the so called "perfect match", and all it takes is the wrong shade of primer, along with application technique and your a "shade" off, the only "true" match would be to find an original well preserved component in the color you desire, match it with the many techniques available today, then do spray outs simulating the exact technique and mat'ls you intend to employ, and even then it's no guarantee, as I've had the same mixer Fubar the agreed upon finial mix formula after altering mixes to achieve the required results, so due diligence is required right up to the moment of actually spraying the finished product Mike
[Re: OhioMopar]
#2445016
02/02/18 01:56 AM
02/02/18 01:56 AM
OhioMopar
Mt.Gilead, Ohio
Thanks to both of you. Seems I have some research to do.
