Re: Question about LCA shaft finish
[Re: Fab64]
#2444700
02/01/18 03:50 PM
02/01/18 03:50 PM
Posts: 43,176 Bend,OR USA
Cab_Burge
The tapered part of the pin slides into the K member and the straight part is press into the bushing. The nut and cotter pin are torque to prevent the pin from rotating making the torsion bar twist and act like a spring to control up and down movement when moving the car down the road
[Re: UCUDANT]
#2444944
02/01/18 11:45 PM
02/01/18 11:45 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
Removing a lower control arm bushing outer shell made easy, if you run a 1-3/8 tap into the shell of the bushing after you press out the pin and remove the rubber you can run the tap into the control arm bushing outer shell and press the tap and shell out just like you did the pin. Thanks to the For A bodies only member who shared this trick, and my friend George who told me.
UCUDANT That would be me. Glad that "trick" worked out for you. I have heard that lots of enthusiasts have benefited by doing it that way, even though there is a welding in a washer method, too. Jim V. hemi71x
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: A727Tflite]
#2444950
02/01/18 11:55 PM
02/01/18 11:55 PM
hemi71x
The tap is not a trick - its in the older service manuals. Yes, that's true, but how many of us have a 1962 maintenance manual, to even know of that method in regards to that bushing shell removal.
[Re: buildanother]
#2444955
02/02/18 12:05 AM
02/02/18 12:05 AM
Posts: 8,138 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
And how many of us have a tap that large laying around.... I bought one off ebay, I have rebuilt a few front ends and removing the lower control arm bushing from the arm is the hardest part, and it was soooooo worth a few bucks to buy the tap. I helped remove Georges bushings and he found the tap idea after, I was very thankful.
[Re: buildanother]
#2444956
02/02/18 12:07 AM
02/02/18 12:07 AM
hemi71x
And how many of us have a tap that large laying around.... lol That's a good point, too. Guess a person goes out and purchases one to get the job done, if he want's to do it that way. I watch ebay, and they show up for as little as $15.00, sometimes. https://www.ebay.com/itm/GREENFIELD-GTD-1-3-8-6-NC-HAND-TAP/311459883236?Here's an $18.00 one. That's a good price, and it says two of them are available, if anyone here is interested.
[Re: Fab64]
#2444957
02/02/18 12:10 AM
02/02/18 12:10 AM
Posts: 3,076 Michigan
A727Tflite
I take an air chisel and push the top step in to the bushing ID after laying a thick washer inside that sleeve. Put it in a press and push on the washer and out the bushing comes. I like the tap as it is faster but haven't come across a deal on one yet. And who has a 62 manual - just us old guys that have been working on these cars for over 50 years.
[Re: Fab64]
#2444975
02/02/18 12:54 AM
02/02/18 12:54 AM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
This part is usually plated so it will resist rust, now it will want to rust up so it needs your help to prevent that. False. The pivot pin is bare metal. And I wouldn't worry about it being blasted.
[Re: Fab64]
#2445144
02/02/18 12:25 PM
02/02/18 12:25 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
They let the whole danged front end rust, most of it is coated to not rust on the shelf, but will on the road. Cosmoline doesn't hold up all that well in use.
[Re: njmopar]
#2445438
02/03/18 12:34 AM
02/03/18 12:34 AM
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
I just put my front end together. Also soaked the shaft in evaporust to clean up. I coated the shaft with Boeshield T9 as I pressed into the new bushing to aid in assembly and to protect. Then I lightly coated the part that goes into the k-frame and the k-frame itself with a layer of grease. Once finally torqued down and in the car, I will then coat the exposed threads and nut with Boeshield again.
I also did the Krylon battery protector deal. I folded over the masking tape to make it look a little more like a soft dip line, then a hard spray line at the end. Here you can see my original cosmoline line
