Re: New Rotisserie and Plymouth frame cut for Dakota sub-frame.
[Re: Old Ray]
#2444253
01/31/18 09:39 PM
01/31/18 09:39 PM
Posts: 3,920 n.e. pa.
65rbdodge
n.e. pa.
[Re: Old Ray]
#2444282
01/31/18 10:20 PM
01/31/18 10:20 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
What's going to power this beast?
Have a great day Iowan
"obsolete is neat"
[Re: Old Ray]
#2444610
02/01/18 01:45 PM
02/01/18 01:45 PM
Posts: 237 British Columbia, Canada
Old Ray
Thanks moparx. The underside picture is misleading, it was taken after the repair. it was bad. My plan (?) on the FI is I have taken all the electronics off the Donner vehicle and left most of them still connected to the engine, it's not going to be a pretty sight under the hood, and mount them in the Plodge. I am hoping to trick the computer into thinking its still in a Dakota. I will keep you posted as I go along, working on the frame now, contrary to popular belief (mostly mine) the Dakota rear axle (two wheel drive) will work width-wise, with ford deep offset wheels.
[Re: Old Ray]
#2444746
02/01/18 05:22 PM
02/01/18 05:22 PM
Posts: 10,562 Freeport IL USA
poorboy
Freeport IL USA
My 1st EFI swap was the 90 Dakota stuff in my 48 Plymouth coupe. That has worked out pretty well. I used everything from the Dakota. A 92 is a bit more complex then the 90 was, the 92 is OBD2 while the 90 was OBD1. I believe as long as you are using the Dakota stuff it will still work out well, its when you start swapping other stuff in that causes the problems.
My current build is 39 Dodge truck sheet metal on a Dakota Chassis. I'm using a 91 Dakota donor, which is also OBD2. One of my issues is the donor was a V6 5 speed, and the drive train is a 5.9 auto from a 97 truck, so the V6 stick computer won't work. The 97 uses a digital speedometer and came with a Hot Wire harness. The 91 Dakota dash doesn't have a digital speedometer, and the remaining instrument cluster is incompatible with the 97 requirements. The Hot Wire harness is a stand alone unit unit requiring only a few wire connections to the truck harness. I really didn't want to use the Dakota dash anyway....
On top of that, I can't use the Dakota heater system (its too wide and doesn't conform to the firewall), and the steering column is too long and without a tilt I need for my 39 truck cab, so I'm using a different steering column and the wiring doesn't match up. It doesn't help that I don't have a wiring diagram for a 91 Dakota, there has been too many wiring changes from the 87 Dakota FSM I have. I thought I could clean up the under dash wiring harness, but there is this under dash control module causing a problem or 2. If I wasn't cheap (and broke) I'd just buy a $250 wiring kit and be done with the whole mess. I'm having fun now!
It is unfortunate that winter has come and the truck is sitting outside, too far away to be pushed in or out of the garage, and too far away to reach with my electric or air, and I'm a wimp, so its cold out there. Come on spring!
Keep moving forward, its nice to see guys making progress. Gene
[Re: Old Ray]
#2444775
02/01/18 06:28 PM
02/01/18 06:28 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
OBDII didn't become mandatory till 1996 and a couple of manufacturers put it in in 95.
No one had it in production in 92.
I think you are confusing throttle body fuel injection (LA motor) and port fuel injection (magnum engine).
[Re: poorboy]
#2444844
02/01/18 08:33 PM
02/01/18 08:33 PM
Old Ray
It doesn't help that I don't have a wiring diagram for a 91 Dakota, The mixing and matching is the kind of trouble I am trying to avoid. Gene, I think I have a 92 shop manual, I could scan the pertinent wiring diagram page if it would help?
[Re: Old Ray]
#2444963
02/02/18 12:26 AM
02/02/18 12:26 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Nice looking toy. I give you fellas lots of credit. I go the other way and run from the modern electronics. I have a few 60's, & early 70's cars, trucks, & drive trains. I'm still learnin' how that stuff goes together & werks.
I have mechanical Aptitude. I can screw up anything.
[Re: Old Ray]
#2444998
02/02/18 01:26 AM
02/02/18 01:26 AM
poorboy
Freeport IL USA
It doesn't help that I don't have a wiring diagram for a 91 Dakota, The mixing and matching is the kind of trouble I am trying to avoid. Gene, I think I have a 92 shop manual, I could scan the pertinent wiring diagram page if it would help? Old Ray, at this point if I can get a pin out for the rear body harness plug at the firewall for the 92 Dakota, that would help. The 87 didn't have a connector there, and that would save me from undoing all the wiring to the rear of the truck. I've pretty much decided I needed to start at the fuse box and wire everything from there. I have most of the circuits laid out, its just a matter of getting everything in the right place and splice a bunch of wires. Gene
[Re: Supercuda]
#2445002
02/02/18 01:31 AM
02/02/18 01:31 AM
poorboy
Freeport IL USA
I think you are confusing throttle body fuel injection (LA motor) and port fuel injection (magnum engine). Your probably right, but the 92 harness is different from the 90 harness, and both were 3.9 throttle body motors. The 92 also has an underhood fuse box that the 90 does not have. My 93 port injected 3.9 has a different computer then the 90 or the 92, which both appear to be the same. Gene
[Re: bboogieart]
#2445012
02/02/18 01:44 AM
02/02/18 01:44 AM
poorboy
Freeport IL USA
Nice looking toy. I give you fellas lots of credit. I go the other way and run from the modern electronics. I have a few 60's, & early 70's cars, trucks, & drive trains. I'm still learnin' how that stuff goes together & werks. My last hot rod truck was carbed, and it didn't like any brand of carbs. I think I rebuilt or replaced a carb every year. After 12 years of fighting with carbs, I was ready for something that worked. The efi in my 48 Plymouth coupe works well. I would have went with fuel injection way back in the mid 80s if there had been an affordable way to put a system on a Mopar. It still irritates me that there isn't a kit for Mopars to convert over for less then a grand, but you can convert over a GM for less the $500 with all new stuff. Gene
[Re: Old Ray]
#2448899
02/09/18 01:54 AM
02/09/18 01:54 AM
poorboy
Freeport IL USA
Yes, as long as the flip doesn't interfere with the car body, since the shackles and brackets are above the frame. Flipping the rear shackles will change the pinion angle some, as well, which may or may not be a problem. You can flip the front brackets as well, if it would help.
I bought a set of 2" lowering blocks with the U-bolts & nuts, and free shipping included for something like $30 off ebay a few months ago. I looked but, no longer have the link. I did a google search, a generic ebay listing showed up, and I scrawled down the list until I found what I was looking for, make sure there isn't one with a better price a little farther down the list. Gene
