2nd gen sudden hub bearing failure..twice #2443898
01/31/18 03:40 AM
01/31/18 03:40 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
A month ago while towing the right front hub bearing suddenly failed and had to be changed on shoulder of I-55.. cold, snow etc.. the failed bearing was about 2 years old and 10 K miles.. Luckily got it stopped and didn't crash..
That was one month and about 1K miles ago...
Tonight same thing , new bearing failed..on I-80 looks like the races broke.. Again got it stopped before it fell off.
Autozone bearings all three of them..
2001 ram 1500 stock off road edition..
I have had the truck for 12 years, replacing bearings every 2 or three years until now...
Thinking about buying nos Mopar or SKF...
Re: 2nd gen sudden hub bearing failure..twice [Re: sthemi] #2443947
01/31/18 11:04 AM
01/31/18 11:04 AM
Guitar Jones Offline
I think you answered your own question, oh wait, you didn't ask a question. Either way, that's the answer.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 2nd gen sudden hub bearing failure..twice [Re: sthemi] #2443950
01/31/18 11:16 AM
01/31/18 11:16 AM
Or, if you want to eliminate those all together there is always this option.
Free spin kit
Re: 2nd gen sudden hub bearing failure..twice [Re: sthemi] #2444159
01/31/18 06:02 PM
01/31/18 06:02 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Timken is strongly recommended. Should be OEM. Lot cheaper than a mopar NOS.
Next step is how its being installed. Even a little hammering is bad. Gotta use the right method
Re: 2nd gen sudden hub bearing failure..twice [Re: jerseybud] #2444846
02/01/18 08:36 PM
02/01/18 08:36 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
Make sure torque the axle nut to correct torque.
Re: 2nd gen sudden hub bearing failure..twice [Re: sthemi] #2444930
02/01/18 11:28 PM
02/01/18 11:28 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We used only name brands like Timken etc.Installed a few cheap bearings because customer wanted cheap.No warranty and lots went bad in a short time.Rocky
Chrysler Firepower
Re: 2nd gen sudden hub bearing failure..twice [Re: therocks] #2445050
02/02/18 04:14 AM
02/02/18 04:14 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Thanks for the replies,
The first autozone hub bearing got on there because no one had a decent part in stock and I needed it that day.
Now with 2 replacements, it was clearly a bad choice..They did warranty them however..
I will put new set of Timkens on in the spring time and hopefully be good for a few years..
Wife said no new trucks.. so this one needs to last another 10 years..
