All the way forward on an engine off the choke (off fast idle), and the transmission throttle lever should be held all the way forward too. I would place a spring on it that holds it forward while you develop your linkage. Most hard linkage uses a light spring from the slotted linkage at the carb to pull the whole shebang forward. Later cables use a spring too but down at the trans.
But that's not the whole story - lever ratios are important too - at WOT the throttle pressure lever should be just about all the way back - just before being bottomed out.
There are many different levers so as long as you work towards that end you should be good.
